TR4/4A square engine mount washer necessary?
Dash
When I lifted the engine from my tr4 it had square mounts so I'm assuming they had been replaced at some point since the round ones were originally used on the 4 and the square used on the 4A but are interchangeable. I already have new square mounts but the Moss diagram is showing a washer on the square that the old mounts didn't have. Of course it was a very long time ago but I don't recall having any problem replacing the belt that I have read some people have using the square mounts. There doesn't seem to be anything special about the washer, just a big washer, so is there any disadvantage to not using one?
Also, I didn't pay much attention to the orientation of the old mounts when I removed them but the ridge down the center of the square mount faces up..right?.. or does that really matter either?
I know it seems like a trite question but even the simple things have variables on these cars it seems.
Geo Hahn
Does your TR4 have a hole in the radiator for a hand crank (early ones did). If yes, then the shims on the mount are part of the adjustment if you want to preserve that function.
I added shims to make it easier (well, possible) to change the belt - but that was using the stock round mounts.
Dash
It's a '63 but no hole though the radiator..so the washers are used on the square mounts because they are a bit shorter than the round ones and are only for shimming then..Hmm, sounds logical as I could see no other useful purpose for them. Anyway, guess I'll play it safe and use washers ( considering the possible belt issue) cause once the engine is mounted I don't wanna have to go back and mess with it. I wouldn't think a thin large diameter washer would do much good so is there a maximum shim thickness limit that can be used?
Pretty sure sq ones were on the early 4s and round ones were on the 4As. Sq ones left over from TR3s. Its not going to hurt to use shims or washers under or on the mounts as long as mounting rubber is in decent shape .
Marv
Geo Hahn
I'm thinking there were 3 mounts used through the series. A rectangular one on the 2s & 3s, a round one on the 4s and then a different rectangle on the 4As. But I only have experience with the first 2 types.
You can shim quite a bit to get belt clearance (I did on the 4) but then you should also shim the radiator to match that so the top hose lines up well. Check bonnet clearance before you try to slam it shut.
BL50
Bronze
I bought my '66 TR4A in 1967 from a guy who got drafted so I know my motor mounts are original to the car. They are the square ones and they had a large, thick washer between the mount and the frame. Here's a pic - don't know why it downloaded upside down!
Ah, yes I remember that motor mount now. So as Geo posted, three different motor mounts. Will be restoring a 67 TR 4a this summer so guess I will be refamiliarizing myself with one then.
Marv
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
S TR2/3/3A ¼ fine square nuts Triumph 7
R Sprite Bonnet Badge 1962 Square Body Spridgets 1
R Luggage Rack for 62 Sprite [Square Body] Austin Healey 1
A Square Body Sprite Starter Motor Issues Austin Healey 2
alanjohnturner TR4/4A pesky right-ange drives , square pegs, round holes Triumph 2
Tinkerman TR2/3/3A 1960 TR 3A square spier nuts on headlight assembly Triumph 2
S Some Square Sprite Goodness Spridgets 6
Scotsman Square Drain Plug Socket Restoration & Tools 7
AN5Sprite RHD square body project car Spridgets 5
AN5Sprite CL square-body Sprite Spridgets 15
S TR2/3/3A square solenoids tr3? Triumph 15
Cottontop DRILLING Square Holes Restoration & Tools 12
regularman Has anyone here put a bugeye front end on a square Spridgets 2
PC power bit to square drive socket adapters Restoration & Tools 3
jsfbond Choke cable [square knob] Triumph 0
Jagboy69 Square Wiper motor needed Triumph 5
T TR2/3/3A TR3 - sloped vs "square" rear floor area Triumph 7
tweety square wheel arch 5.5" wheels will they fit? Spridgets 1
R Toyo R888 on Square Arch Spridget? Racing 4
dklawson Square Wiper Motors - Internals Spridgets 0
dklawson Square Wiper Motors - Internals Triumph 0
Morris Square body foward tilt conversion... Spridgets 3
healeynut Square Ammeter Question Other British Cars 11
abarth69 Square body sprite with Bugeye rear bumpers Spridgets 14
drooartz My favorite square-body Spridget Spridgets 16
S How to seal the square hole in the firewall Triumph 14
Jayrz Bugeye rear onto square sprite? Spridgets 4
regularman Has anybody ever put a square sprite front end on Spridgets 11
George Zeck Square Headed Speciality Bolt ???? Spridgets 1
healeynut FACET Square Body Pump Woes Austin Healey 4
G Captured square nuts Triumph 5
aeronca65t Ariel Square Four British Motorbikes 10
L General Tech Engine id Triumph 8
mctriumph For Sale Tr7 engine Triumph Classifieds 2
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
CARSINC WANTED: 1275 Engine Spridgets 0
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
