Captured square nuts
Greg_Blake
Anyone have a good resource for the 1/4-28 square nuts our cars seem to offer u to the corrosion gods so liberly?
TRF thinks they are gold
CN1/NUTNut,square, captive10.40 .40
martx-5
I went on McMaster's site, and found 1/4"-28 captive nuts in the cage...part # 90955A113. I found them under "weld nuts". I've used these. They aren't quite original looking, but work actually better then the originals. They are $5.78/10 pack.
I then looked for just the square nuts, and they didn't list any in 1/4"-28. I do remember purchasing some from somewhere, but the width of the square was smaller then the OE's, and the the fit in the cage was too loose. Unless you want the whole assembly, I'm afraid you might have to pay the piper unless somone else can come up with a source.
Besides, there are only about 458 of them in the car. /bcforum/images/%%GRAEMLIN_URL%%/jester.gif
Don Elliott
I paid a machine shop $1.00 each for them to make me all the ones I needed when I did my TR3A restoration from 1987 to 1990. They are made out of stainless steel and all my bolts are stainless as well. The nuts were made the proper size not to rotate and after 94,000 miles since 1990, I took off my front bumper and valance in a little over an hour. It's nice to have bolts that un-bolt so easily. I used them all over. For example, I can remove all the flat-head screws holding a door in about 3 minutes.
G
Are capture nuts and cage nuts one and the same? Most cities have a specialty store that carries such. I get everything from a shop in Lafayette, LA, A-1 Bolt, that has every conceivable fastener know to man. I just bought a large handful of grade-8 fasteners for less than 5 bucks.
On the subject of fasteners, my new gear reduction starter has two long, thin recessed fasteners that hold the adapter plate onto the body of the starter. I brought these to A-1 to see if I could find some 5mm longer so that I could use a nut backup. These bolts the counter-guy told me were indeed grade 12.5, the strongest made. I find it curious that such a strong bolt would have fine threads and be threading into aluminum yet. Hmmmm. I guess it is the shear strength that they want, and not the elongation, as the aluminum would certainly give way before the bolt. Was advised to us high-strength Locktite to keep them from backing out. That is why I wanted backup nuts. (they were out of stock)
PeterK
TRF often has them on sale for $.40 each instead of $1. A little bit cheaper anyway.
PC two wild, one captured Spotted 1
D Sway bar - BT7 - loose captured nuts Austin Healey 18
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
S TR2/3/3A ¼ fine square nuts Triumph 7
R Sprite Bonnet Badge 1962 Square Body Spridgets 1
R Luggage Rack for 62 Sprite [Square Body] Austin Healey 1
D TR4/4A square engine mount washer necessary? Triumph 6
A Square Body Sprite Starter Motor Issues Austin Healey 2
alanjohnturner TR4/4A pesky right-ange drives , square pegs, round holes Triumph 2
Tinkerman TR2/3/3A 1960 TR 3A square spier nuts on headlight assembly Triumph 2
S Some Square Sprite Goodness Spridgets 6
Scotsman Square Drain Plug Socket Restoration & Tools 7
AN5Sprite RHD square body project car Spridgets 5
AN5Sprite CL square-body Sprite Spridgets 15
S TR2/3/3A square solenoids tr3? Triumph 15
Cottontop DRILLING Square Holes Restoration & Tools 12
regularman Has anyone here put a bugeye front end on a square Spridgets 2
PC power bit to square drive socket adapters Restoration & Tools 3
jsfbond Choke cable [square knob] Triumph 0
Jagboy69 Square Wiper motor needed Triumph 5
T TR2/3/3A TR3 - sloped vs "square" rear floor area Triumph 7
tweety square wheel arch 5.5" wheels will they fit? Spridgets 1
R Toyo R888 on Square Arch Spridget? Racing 4
dklawson Square Wiper Motors - Internals Spridgets 0
dklawson Square Wiper Motors - Internals Triumph 0
Morris Square body foward tilt conversion... Spridgets 3
healeynut Square Ammeter Question Other British Cars 11
abarth69 Square body sprite with Bugeye rear bumpers Spridgets 14
drooartz My favorite square-body Spridget Spridgets 16
S How to seal the square hole in the firewall Triumph 14
Jayrz Bugeye rear onto square sprite? Spridgets 4
regularman Has anybody ever put a square sprite front end on Spridgets 11
George Zeck Square Headed Speciality Bolt ???? Spridgets 1
healeynut FACET Square Body Pump Woes Austin Healey 4
aeronca65t Ariel Square Four British Motorbikes 10
tr6web TR6 Need advice removing downpipe nuts Triumph 4
petnatcar Cylinder Head Nuts - Tightening Sequence Austin Healey 2
Scotsman TR4/4A Chimney nuts, where do they go Triumph 5
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
shadowfever Midget seat nuts and bolts Spridgets 2
A BN7 Front Hub Stud Nuts Austin Healey 5
T Storing nuts and bolts (so you can find what you need) Austin Healey 7
Z Lug nuts for Minitor rims Spridgets 1
HighAltitudeTR3 T-Series Why are there nuts in my core plugs?! MG 8
D Rear Brake Drum Nuts Austin Healey 15
Lin Water Pump torque value for nuts on studs Austin Healey 1
steveg TR6 Loose wheel nuts after torquing Triumph 2
D TR2/3/3A Wing nuts for gauge panel on TR 3 Triumph 10
