BN6_2197
Gents,
with help of this forum I was able to remove the coil spring of my BN6. Now I want to get access to the swivel pin, concretely to the swivel pin oil nipple. Currently I am not able to put any grease there.
My idea is to loose the swivel pin only at the top wishbone arms and not to disassemble the swivel pin at the lower wishbone arms. By this I think I can get access to the swivel pin oil nipple without disassembling the more complex lower mechanism. For this I already disconnected the back plate from the brake pipes and removed the coil spring.
Is there a procedure just to remove the swivel pin from the upper wishbone arms to get access to the swivel pin oil nipple?
Note that my technical terms are taken from Fig. L.3 of the workshop manual.
Cheers,
Volker
Cheers,
Volker
