Rear Speaker Placement E Type
Jeff
Any suggestions for rear speakers to fit behind the seats of a 68 OTS? Don't want to do any cutting.
Jeff,
Like you, I wanted the installation to be reversible...so I made two plywood boxes with open bottoms and sides contoured to fit the panel above the bulkhead behind the seats, and a slightly recessed front panel large enough to accept 6" x 9" speakers, and covered them in vinyl that matches the interior trim. I did drill two small holes on each side of the rear bulkhead to secure the boxes by means of screws inserted from the boot, but this disfigurement was about the least I could get away with.
The speakers sound pretty good, although the boxes aren't large enough to provide "bass reflex" volume. The positioning of the boxes makes getting to the boot release less convenient, but certainly not impossible; and obviously there's less room behind the seats to carry the odd item of luggage. The speakers fall just below the hood boot when it's fitted, so the sound isn't blocked off.
I went to one of those big displays in an electronics store and found speakers that fit the original space that sounded adequate to me. They don't supply the currently popular sound but I don't like that anyway!
I bolted two small spkr boxes with good quality spkrs by using the two chrome thumbnail screws that hold the divider between back of seats and storage area (coupe)upright to hold brackets.
Worked great and held spkrs high enough to project forward over seats at the outer corners of the seats.
I had a similar problem with my Mini many
years ago. I got a pair of "box" speakers,
designed to be placed under the seats.
I remember they sounded great and if they
fit under Mini seats they'd fit under almost
anything, I reckon. I have no idea about make,
but there must be something like it on the market
somewhere.
Moose33 rear speaker MG 15
5 Wanted Looking for a Rear Cockpit Molding for a BN2 Austin Healey Classifieds 0
J SOLD!! Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 1
petnatcar Rear View Mirror Relocation Austin Healey 0
Carlbanan56 MGB Rear axel torque? MG 4
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Carlbanan56 MGB Rear wheelbearing clicking MG 8
Carlbanan56 MGB MGB rear break rebuild MG 6
bigjones TR2/3/3A Rear tail light not budging Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
Michael Oritt Rear Crank Seal Kit Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
O Jaguar rear window trim repair Jaguar 1
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
S Leaking HD6 Rear Carb Austin Healey 10
Joel Lester TR2/3/3A Do rear leaf springs wear out? Triumph 11
J TR2/3/3A Rear Fuel Line Clips Triumph 3
60BN7 Rear Wheel Opening Austin Healey 9
S TR2/3/3A rear wheel cylinder Triumph 1
T Rear/Differential "Clunk" Austin Healey 2
J 3000 Rear Seats Austin Healey 6
KVH General TR Rear Brake Shoe Orientation Triumph 12
Popeye TR4/4A Rear fender attachment: wing to lamp housing clip? Triumph 7
KVH General Tech Rear Brakes and Solid Axle Triumph 2
P Rear Springs Austin Healey 2
K TR2/3/3A Rear leaf spring brass and Delrin bushings ? Triumph 4
J Rear Main Seal Kit Austin Healey 1
af3683 TR2/3/3A TR-2 / TR-3 Rear Bumper Wrap Around Fender Guards Identification Triumph 0
T Looking for "BillMs rear transmission mount" Spridgets 2
BN6_L1232 Rear Disc Brake Installation Instructions Austin Healey 3
Ed Foster T-Series MG-TD leaf rear leaf spring. MG 0
bighealeysource Burning Smell from Left Rear Wheel Austin Healey 14
R BJ7 Rear Axle Maintenance Austin Healey 5
