Rear shocker for 1976 Eclat
Terry_02594
Hi all
I have a 1976 Eclat 201 that needs a new rear shocker. Lotus want £120 each and S J Sportscars want £60. As we know Lotus use every one elses parts so does any one know whose shocks Lotus used as they are bound to be cheaper.
I was hoping there would be an alternative parts list but it does not seem to exist.
Hope you can help
all the best
Terry
Administrator
Boss
Terry, welcome to the forum! We don't have a lot of Lotus guys (yet), but always welcome a new Lotus driver! I'll ask around some of my connections on this side of the pond and see if anyone I know can answer your question. Do you have any pics of your Lotus (We have a mambers gallery here).
Welcome again (and if you have any Lotus pals over there, tell them about our forum -- we need more Lotus representation here!)
Cheers,
JBsC5
I can't help you out on the shocks but wanted to tell you I think the Eclat is a very cool car!
Other than the shocks hows it run?
Can you go aftermarket for the shock instead of through lotus?
J SOLD!! Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 1
petnatcar Rear View Mirror Relocation Austin Healey 0
Carlbanan56 MGB Rear axel torque? MG 4
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Carlbanan56 MGB Rear wheelbearing clicking MG 8
Carlbanan56 MGB MGB rear break rebuild MG 6
bigjones TR2/3/3A Rear tail light not budging Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
Michael Oritt Rear Crank Seal Kit Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
O Jaguar rear window trim repair Jaguar 1
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
S Leaking HD6 Rear Carb Austin Healey 10
Joel Lester TR2/3/3A Do rear leaf springs wear out? Triumph 11
J TR2/3/3A Rear Fuel Line Clips Triumph 3
60BN7 Rear Wheel Opening Austin Healey 9
S TR2/3/3A rear wheel cylinder Triumph 1
T Rear/Differential "Clunk" Austin Healey 2
J 3000 Rear Seats Austin Healey 6
KVH General TR Rear Brake Shoe Orientation Triumph 12
Popeye TR4/4A Rear fender attachment: wing to lamp housing clip? Triumph 7
KVH General Tech Rear Brakes and Solid Axle Triumph 2
P Rear Springs Austin Healey 2
K TR2/3/3A Rear leaf spring brass and Delrin bushings ? Triumph 4
J Rear Main Seal Kit Austin Healey 1
af3683 TR2/3/3A TR-2 / TR-3 Rear Bumper Wrap Around Fender Guards Identification Triumph 0
T Looking for "BillMs rear transmission mount" Spridgets 2
BN6_L1232 Rear Disc Brake Installation Instructions Austin Healey 3
Ed Foster T-Series MG-TD leaf rear leaf spring. MG 0
bighealeysource Burning Smell from Left Rear Wheel Austin Healey 14
R BJ7 Rear Axle Maintenance Austin Healey 5
J Wanted MGA Coupe rear window glass center section MG Classifieds 0
D MG Midget 1275 rear oil seal. Spridgets 0
