MGB Rear axel torque?
Carlbanan56
Carlbanan56
Hi, I have a simple question. What should I torque these to? I don't know what they are called so could not google.
YakkoWarner
It has been an ongoing source of confusion with my friends who are used to working on American cars (where pretty much every fastner has a published torque specification) to see that the older British cars leave much to the mechanics judgement, with only some of the key components specified.
J Ajustment of rear axel? Austin Healey 10
J Rear Axel/Bearing & Axle Seal.\ BJ8 . Austin Healey 5
R Rear axel o-ring Spridgets 8
TR3Dad TR2/3/3A TR3A Loud Buzz & Rear Axel Triumph 3
B Rear axel seal MG 4
vping Welding to a rear axel tube. Can you? MG 17
R Tightening rear axel nuts Austin Healey 4
S TR2/3/3A Tr3 rear axel oil seal and shim Triumph 0
L Rear Axel Drain Plug Tool? Austin Healey 4
L Rear Axel Question Austin Healey 8
Obtong Rear Axel Socket Size? MG 3
F where can I get a rear axel?? MG 10
J SOLD!! Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 1
petnatcar Rear View Mirror Relocation Austin Healey 0
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Carlbanan56 MGB Rear wheelbearing clicking MG 8
Carlbanan56 MGB MGB rear break rebuild MG 6
bigjones TR2/3/3A Rear tail light not budging Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
Michael Oritt Rear Crank Seal Kit Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
O Jaguar rear window trim repair Jaguar 1
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
S Leaking HD6 Rear Carb Austin Healey 10
B Rear Brake Cylinders Austin Healey 4
Joel Lester TR2/3/3A Do rear leaf springs wear out? Triumph 11
J TR2/3/3A Rear Fuel Line Clips Triumph 3
apbos New long term project. Sprite powered rear engined race car. Spridgets 9
60BN7 Rear Wheel Opening Austin Healey 9
S TR2/3/3A rear wheel cylinder Triumph 1
K TR2/3/3A Rear tire pressure when there is an anti roll bar at the front of the car? Triumph 1
T Rear/Differential "Clunk" Austin Healey 2
jfarris For Sale TR3 Rear Sway Bar Triumph Classifieds 0
J 3000 Rear Seats Austin Healey 6
KVH General TR Rear Brake Shoe Orientation Triumph 12
Popeye TR4/4A Rear fender attachment: wing to lamp housing clip? Triumph 7
KVH General Tech Rear Brakes and Solid Axle Triumph 2
P Rear Springs Austin Healey 2
K TR2/3/3A Rear leaf spring brass and Delrin bushings ? Triumph 4
KVH General Tech Jacking Up The Rear of TR4 Triumph 5
J Rear Main Seal Kit Austin Healey 1
af3683 TR2/3/3A TR-2 / TR-3 Rear Bumper Wrap Around Fender Guards Identification Triumph 0
