Rear Axel Socket Size?
Obtong
Hello Folks,
I wanted to check on my rear axel's level, and perhaps drain and refill it. The trouble is that none of my sockets will work! The 1/2" is too big and the 3/8" is too small.
Does anyone know what the correct socket size is, or is there a special tool? I've checked the Moss and V.B. catalogues but have found no info on the subject. My Haynes manual doesn't mention socket size either.
Thanks,
Obtong
[ 08-18-2003: Message edited by: Obtong ]</p>
i saw the answer to that on here somewhere but cant find it now....i believe you will find its 7/16 , i got a piece of bar stock from work. and used a large crescent wrench. you only needa short piece. you also could use an old 1/2in extension and grind down 2 of the sides carefully till it fits
Mark
Obtong
Obtong
Thanks for the info, Mark. I'm going to see if I have an old 1/2" socket I can file down. That's a good idea.
I did look through the forum for the axel info but I guess I was using the wrong search words.
Obtong
Carlbanan56 MGB Rear axel torque? MG 4
J Ajustment of rear axel? Austin Healey 10
J Rear Axel/Bearing & Axle Seal.\ BJ8 . Austin Healey 5
R Rear axel o-ring Spridgets 8
TR3Dad TR2/3/3A TR3A Loud Buzz & Rear Axel Triumph 3
B Rear axel seal MG 4
vping Welding to a rear axel tube. Can you? MG 17
R Tightening rear axel nuts Austin Healey 4
S TR2/3/3A Tr3 rear axel oil seal and shim Triumph 0
L Rear Axel Drain Plug Tool? Austin Healey 4
L Rear Axel Question Austin Healey 8
F where can I get a rear axel?? MG 10
J SOLD!! Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 1
petnatcar Rear View Mirror Relocation Austin Healey 0
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Carlbanan56 MGB Rear wheelbearing clicking MG 8
Carlbanan56 MGB MGB rear break rebuild MG 6
bigjones TR2/3/3A Rear tail light not budging Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
Michael Oritt Rear Crank Seal Kit Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
O Jaguar rear window trim repair Jaguar 1
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
S Leaking HD6 Rear Carb Austin Healey 10
Joel Lester TR2/3/3A Do rear leaf springs wear out? Triumph 11
J TR2/3/3A Rear Fuel Line Clips Triumph 3
60BN7 Rear Wheel Opening Austin Healey 9
S TR2/3/3A rear wheel cylinder Triumph 1
T Rear/Differential "Clunk" Austin Healey 2
J 3000 Rear Seats Austin Healey 6
KVH General TR Rear Brake Shoe Orientation Triumph 12
Popeye TR4/4A Rear fender attachment: wing to lamp housing clip? Triumph 7
KVH General Tech Rear Brakes and Solid Axle Triumph 2
P Rear Springs Austin Healey 2
K TR2/3/3A Rear leaf spring brass and Delrin bushings ? Triumph 4
J Rear Main Seal Kit Austin Healey 1
af3683 TR2/3/3A TR-2 / TR-3 Rear Bumper Wrap Around Fender Guards Identification Triumph 0
