TR2/3/3A Question about size of Clutch Alignment Tool
2billydavies
Hi everyone... me again.
So I got my package with all my new parts yesterday from Moss. Almost ready to put the engine back in.
One thing.... I ordered a clutch alignment tool from them and they either forgot to put it in the box, didn't see that I ordered it for some reason online, or I simply thought I ordered it but really didn't and I'm just trying to blameshift for my screw up (more than likely, it's the last one.)
In any case... does anyone know what size the clutch alignment tools are? I was thinking maybe they have one in the size I need at the local auto parts stores around me (probably not.... and if they do, it would be the first time ever that I found something locally for my car). Anyone know what size they are? I guess I need the teeth size. Not sure how standard they were back in the day.
thanks a ton! Any suggestions on getting around the use of one of these would be appreciated... if that's even possible.
~ Billy
TR3driver
Great Pumpkin - R.I.P
In a pinch, I've skipped the alignment tool and just used my finger. Feel the gap between the bore through the clutch plate and the hole in the flywheel. If the gap is the same all the way around, the plate is aligned. Install the bolts just finger-tight at first, so you can tap the plate around until it's lined up; then tighten the bolts and recheck.
BTW, the tool I got from Moss years ago was so badly undersize as to be useless. I use an old input shaft instead.
The minor diameter of the hole through the friction plate is 1" nominal, but I don't recall the pilot bearing diameter offhand. `10 splines, major diameter is 1.25" nominal. (The shaft & tool are roughly .005" undersize, to allow easy movement.)
TomMull
Pilot bush is 1/2". Also second the old input shaft but not everyone has one. I've used the finger approach too but found it quite tedious. Perhaps just don't have the right touch.
Tom
Local parts store should have a generic clutch alignment tool that can rented or loaned out. The plastic ones that Moss and others have will work but the old input shaft is best.
marv
CJD
PM me if you run into trouble...I'll send you the best pilot, an old input shaft.
doc50
I agree with Randall about his use of the (my term) 'Houniak Method' of using one's finger to get clutch alignment right.
I was out in the garage the other day and noticed my old 'clutch alignment tool'.....a piece of dowel I had hammered into the clutch plate a couple inches.
The crenelations of the clutch plate easily 'machined' the dowel and I just pressed the 'self-lathed-by-eyeball small end' of that dowel into the crank hole (as I recall, been a couple years now).
Worked great, first time. I believe store bought 'clutch alignment tools' have always been a bit over-rated. JMHO, BOE
Thom
1959 TR3
TS34909L(O)
CJD
I haven't used the finger method since I was 15, and for good reason. It's hard enough getting the splines engaged when the disc alignment is perfect...I don't need the extra frustration of popping the clutch loose several times in the process.
titanic
One of my TR4 manuals mentions using a 6" piece of 1"dia. stock with a 2" section turned to 1/2" to fit the pilot bushing.
Berry
G TR2/3/3A TR3 Windshield size question Triumph 2
jhorton3 Wheels Size Question Spridgets 5
Dave Richards Yet Another Tire Size Question Austin Healey 11
JPSmit tonight's question Tap size Spridgets 9
RickB MGB Quick tire size question - MGB MG 10
BLG Question on Size MG 7
tony barnhill T-Series MG TD Tire Size Question MG 25
Steve_S Bolt Size Question MG 6
B TR6 Yes.....another TR6 tire size question Triumph 7
B TR6 Question about tire size options on a TR6 Triumph 3
C Question on purchase [motor size] British Motor Corp 1
M MGB Disributor clamp question MG 1
K TR2/3/3A Cylinder head stud height question? Triumph 4
DonC1948 TR6 A "CLASSIC" question. Triumph 6
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
D TR2/3/3A TR2 Flying Mile question Triumph 11
M New Member with an HD8 Carb Question Austin Healey 1
Gliderman8 TR6 New shocks (damper) question Triumph 4
D TR2/3/3A Windshield assembly question Triumph 6
T MGB Quick question about something that don't really matter just want to know. MG 9
CARSINC Throttle linkage question Spridgets 1
S TR6 Steering question you will not hear every day Triumph 1
JPSmit Hypothetical Question of sorts - wheel bolts Restoration & Tools 12
E TR6 TR6 flip-up bonnet question Triumph 4
D TR2/3/3A headlight question Triumph 8
D A distributer question on the 1275 engine. Spridgets 7
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
SherpaPilot TR6 Ignition Switch Question Triumph 13
SherpaPilot TR6 Engine Mounting Question Triumph 3
5 TR2/3/3A TR3 fender patch panel question Triumph 10
WHT Oil Sump Question For Dougie Austin Healey 0
LD-Ordie Series II gear lube question Rover / Land Rover 3
T TR2/3/3A TR3A Windshield Question Triumph 4
Celtic 77 MGB factory hardtop question... MG 10
D Cam Timing question. Spridgets 11
jfarris TR2/3/3A Exhaust Hanger Question Triumph 4
T TR2/3/3A TR3A Disk Brake Question Triumph 10
JPSmit Distributor question Spridgets 0
Bayless Door seal question Spridgets 3
M T-Series TD/TF Steering Free Play Question MG 6
