TR4/4A Need TR4-A trunk lid emblem location?
moe_morin
Member
I'd like to know where the TR4-A emblem is located on the trunk lid. Would appreciate the dimensions from the side and bottom edges, or a layout pattern, if someone has one.
Thanks, Moe Morin
BL50
Bronze
I have a solid axle TR4A that is completely disassembled for restoration. There are two holes in the trunk lid for the "TR4" and two holes for the "A". The two holes for the "A" are 4-1/8" from the right edge of the trunk, and 6-1/4" and 6-7/8" up from the bottom edge. The bottom hole for the "TR4" is 1-1/8" to the left of the bottom "A" hole (oops!) which puts the upper "TR4" hole about 3-15/16" away on center. That hole is also 8-1/8" to the left of the right edge of the trunk.
If none of the above is completely clear to you I would be happy to trace a pattern for you and mail it along before you drill. Just send a pm.
Best regards,
Brian
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
B TR4/4A TR4 Rear Leaf - Do I need distance piece? Triumph 5
T TR4/4A my bad- need tr4 shifter photo Triumph 12
kodanja TR4/4A need a project TR4? Triumph 9
milemarker60 TR4/4A Need some early TR4 Windshield Frame Pics -Please Triumph 0
toysrrus TR4/4A My TR4 got "CRUNCHED" Today!!!!! Need Door!!!!! Triumph 46
pa297pass TR4/4A TR4 wheel identification - need help Triumph 5
TR4nut TR4/4A TR4 suspension rebuild Latest - help need a part! Triumph 0
KVH TR4/4A TR4 A and Need Help Again Triumph 6
B TR4/4A Need color chart for oil cover in TR4 Triumph 4
tr6web TR6 Need advice removing downpipe nuts Triumph 4
giwplay1 Everything you need to know before purchasing an Austin Healey Austin Healey 15
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
K TR2/3/3A Does this fitting need a Whitworth wrench? Triumph 10
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
Gliderman8 TR6 Now I really know why I need new shocks Triumph 11
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
W Need advice on installing new side curtain glass Spridgets 1
AngliaGT General TR You Might Need Snow Tires for This - Drive Your Triumph Day 2023 Triumph 5
M Wanted Need 59 Bugeye Dashboard. LHD. Spridgets Classified 1
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
K TR6 Need help with Mimosa Yellow Paint Triumph 1
T Storing nuts and bolts (so you can find what you need) Austin Healey 7
AngliaGT Need Ideas on Selling Our Midget Spridgets 10
drooartz MGB OD question - need to warm up? MG 8
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 1
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
shadowfever Wanted Need a Sprite Mk II bonnet Spridgets Classified 1
jackq Wanted Need a C Tach MG Classifieds 2
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
apbos New/Old wheels for my Speedwell Sprite. Need Center Caps Spridgets 13
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
AngliaGT I Need to Resist - 1980 Ford Fiesta Other Cars 9
vette Need BugEye Generator Austin Healey 7
vette Need BugEye Generator Spridgets 4
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
J TR2/3/3A Need help with pivot and body bracket for hood Triumph 2
Madflyer For Sale Triumph GT 6 parting out need something Triumph Classifieds 10
KiwiStagguy Re building my power steering 71 Stag . Rust and pitting bad . Need a business name to fix it Triumph Classifieds 0
tinman58 TR2/3/3A Need super charger!! Triumph 7
B Wanted I need a small section of a bugeye bonnet Spridgets Classified 5
volunteer Wanted Need Door Seals, Vent Window Seals and Trunk Seal for Daimler ds420 Limo Jaguar Classifieds 23
Got_All_4 TR5/TR250 Need guidance for replacing steering column bushings Triumph 11
John Turney Need a Better Demister? Austin Healey 5
K TR2/3/3A Need advice on what my TR3A might be worth..... Triumph 10
69MGC MGC Need one MGB/C Splined Hub MG 1
69MGC Wanted Need one MGB/C Splined Hub MG Classifieds 4
