TR2/3/3A Need TR3B front and rear apron, sidescreens
Bruce100
Hi all,
My front apron is twisted and a bit mangled from a front end collision, and if I can pick up another one reasonably I think it would be worthwhile. I am looking for one that only needs minor repair and has the "lip" that the later TR3s had.
I am also looking for a rear apron. The one that came with my tub is a bondo nightmare with chicken wire, etc. on the lower portions.
I am also looking for a pair of rebuildable sidescreens (Duzie style), as mine came with cheap aftermarket aluminum ones.
I am in the Charlotte NC area.
thanks!
B
Bruce100
I am talking to him now already actually. And am trying to see if anyone can stop by to verify. Long haul from Charlotte
vivdownunder
A correct TR3B front apron will have the hole pattern for the smooth TRIUMPH nose letters used from very late TR3A's onwards. An earlier TR3A apron will need the ribbed letter holes welded up then re-drilled for smooth letters, or just use ribbed letters if originality is not a problem.
A post TS60000 rear apron will be needed with the later radius cornered single lip water seal, not the earlier square cornered channel type seal.
Viv.
TFB
According to Moss catalog an easy way to tell would be look at the first letter T-Early ribbed has 2 holes,rumph have 2 horizontal holeseach about 1/4" apart
late T smooth has 3 holes.
Tom
B
Bruce100
Jedi, I am not sure how to picture what you are saying regarding the rear apron and the seal. You mean the seal on the boot compartment?
vivdownunder
That's it - the seal for the boot lid.
The later rear apron you need has rounded corners for the rubber seal.
The early one that won't match your car has squared corners.
Viv.
B
Bruce100
hopefully this is the one :smile:... I bought it and shipped it home
I bought the sidescreens. They were NOS, and he sewed in new windows (the PO used to rebuild sidescreens as a sideline, nice job...)
DNK
This the pic?
B
Bruce100
I am still looking for a front apron. I spent yet more time over the weekend very carefully bumping out the low spots in the one I have, and it IS slowly coming back into shape. But I can't imagine how many hours I have into it now...
M TR2/3/3A Need Help With Carb ID On My TR3B Triumph 8
B TR2/3/3A Need pictures of TR3B for reference Triumph 9
B TR2/3/3A Need advice TR3b inner sill replacement Triumph 16
M For Sale 6.0 harmonic balance need rebuilding Jaguar Classifieds 0
tr6web TR6 Need advice removing downpipe nuts Triumph 4
giwplay1 Everything you need to know before purchasing an Austin Healey Austin Healey 15
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 5
K TR2/3/3A Does this fitting need a Whitworth wrench? Triumph 10
Gliderman8 TR6 Now I really know why I need new shocks Triumph 11
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
W Need advice on installing new side curtain glass Spridgets 1
AngliaGT General TR You Might Need Snow Tires for This - Drive Your Triumph Day 2023 Triumph 5
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
K TR6 Need help with Mimosa Yellow Paint Triumph 1
T Storing nuts and bolts (so you can find what you need) Austin Healey 7
AngliaGT Need Ideas on Selling Our Midget Spridgets 10
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
drooartz MGB OD question - need to warm up? MG 8
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 1
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
shadowfever Wanted Need a Sprite Mk II bonnet Spridgets Classified 1
jackq Wanted Need a C Tach MG Classifieds 2
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
apbos New/Old wheels for my Speedwell Sprite. Need Center Caps Spridgets 13
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
AngliaGT I Need to Resist - 1980 Ford Fiesta Other Cars 9
vette Need BugEye Generator Austin Healey 7
vette Need BugEye Generator Spridgets 4
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
Madflyer For Sale Triumph GT 6 parting out need something Triumph Classifieds 10
KiwiStagguy Re building my power steering 71 Stag . Rust and pitting bad . Need a business name to fix it Triumph Classifieds 0
tinman58 TR2/3/3A Need super charger!! Triumph 7
B Wanted I need a small section of a bugeye bonnet Spridgets Classified 5
volunteer Wanted Need Door Seals, Vent Window Seals and Trunk Seal for Daimler ds420 Limo Jaguar Classifieds 23
Got_All_4 TR5/TR250 Need guidance for replacing steering column bushings Triumph 11
John Turney Need a Better Demister? Austin Healey 5
K TR2/3/3A Need advice on what my TR3A might be worth..... Triumph 10
69MGC MGC Need one MGB/C Splined Hub MG 1
69MGC Wanted Need one MGB/C Splined Hub MG Classifieds 4
Gliderman8 General TR Need clarification on Triumph Competition Preparation Manual TR250 TR5 TR6 Triumph 4
S TR6 Need wisdom on tr6 brake calipers Triumph 6
J MGB Need help identifying these parts MG 6
S TR2/3/3A Need New Battery for TR3A Triumph 9
B MGB-GT Need help with MGB GT rattle MG 0
