Need suggestions for fastening aftermarket hardtop for BN1.
55modified
Bought a nice old top and need to secure it to windshield. I contacted Farmer and Nigel but their hardware requires drilling into windshield frame. Isn't there some way I can secure to soft top "posts" on vertical windshield frame? This would be ideal as I don't want to drill or cut on this car anymore than I have to.
55modified
55modified
Healey 100
My BN1 aftermarket top uses the same clamps as the soft top, joining the top to those pegs on the outside of the windshield header. No modification to the windshield is needed. There is a small strip of aluminum that offsets the clamp about a half inch lower relative to the side of the fiberglass top. I can send pix of the detail once I get home later in the week.
Michael Oritt
I have a NICAL top and the machined L-shaped bracket you refer to is attached to the windshield stantions with two small screws on the stantion's after face. I don't think that anyone but you will know the holes are there if you chose to remove the bracket when you take off the top (which is not necessary as it does not interfere with the soft top). You would also need to purchase the corresponding swing bolt that fastens to the top and holds it down to the brackets via knurled nuts.
I had thought about using a pair of soft top clamps but decided not to as I felt they would detract from the top's appearance and also would not exert the amount of clamping force that the bracket/swing bolt offers.
55modified
55modified
That's what I was worried about, would it be secure enough? I had to remove my soft top as it was too uncomfortable due to position in put the seats in while folded behind the seat. I have moved my seat back for comfort and it just wasn't fitting.
Could you post up or send a photo of the how it attaches? Thanks, John
55modified
55modified
Yes Bill please send or post pic. Have you ever been concerned about it flying off at speed or do you feel that it is plenty secured? Thansk, John
Michael Oritt
John--
I'll put a picture of the NICAL fastening system up tomorrow.
I also have a stay made of 1/8" diameter SS 1 x 19 wire that runs from the center of the scuttle to the header bar of the soft top or inside edge of the front of the hardtop, whichever is mounted.
The stay attaches at its upper end to the center triangular buffer via a forked terminal that is swedged onto the wire and a threaded terminal at the other end passes through a small hole (3/16" diameter) drilled into the scuttle, just in front of the rear-view mirror. A knurled nut under the scuttle threads onto the terminal and exerts downward pull upon the top giving a good weather-tight seal between windshield and top.
The concept is similar to the rod stay that was found on MB 190 SL's, Porsche 356's and some Miatas and though it may sound Rube Goldberg-ish it is really quite simple and unobtrusive. I'll post a picture of this stay as well.
John Turney
My hardtop uses the same clamps as the soft top and I've never been concerned about it flying off at speed.
Michael Oritt
Here's a pic of the bracket and swingbolt supplied by NICAL for my hardtop. I am quite sure they can be purchased separately from a hardtop.
Note--due to a tap breaking off in the stantion when I was drilling/tapping the mounting holes I had to go to one size larger screw than originally supplied.
Edit--looks like BCF has again decided to invert the image 180 degrees as the pic now appears upside down. The bracket attaches to the top of the stantion....
Michael Oritt
Yesterday I tried to describe the stay I fabricated that attaches to the header bar of the soft top or inside front lip of the hardtop and runs through the scuttle just forward of the rear view mirror. It allows me to exert a strong downward pull on either top giving a good weather seal against the top of the windshield frame.
I have attached two picture of the stay, the first in its "deployed" position with the stay projecting through the scuttle. Not shown is the thumbscrew that attaches to the stay's bottom end under the scuttle and behind the dashboard which, when tightened, pulls the top down against the windshield. The second pic simply shows the stay pulled out of the hole.
I purchased the 1/8" diameter 1 x 19 stainless wire and the upper forked and lower stud terminals at a West Marine store. The parts are in the rigging department and the terminals may easily be swedged onto the wire using a die and vise supplied for use at the store. Once I had the correct measurement for the wire's length, allowing for the depth of the blind holes in the terminals, it took but about 15 minutes to make up the piece.
If the stay looks somewhat obtrusive in the pictures it is not in real life. As I said in yesterday's post several cars--MB 190 SL's, Porsche 356's and some Miatas used solid rods to keep the windshield frame from distorting and the look is the same here.
55modified
55modified
I have attached two picture of the stay, the first in its "deployed" position with the stay projecting through the scuttle. Not shown is the thumbscrew that attaches to the stay's bottom end under the scuttle and behind the dashboard which, when tightened, pulls the top down against the windshield. The second pic simply shows the stay pulled out of the hole..
Thanks Michael, That is interesting as I had not thought of a center mount like yours. On teh Nigal part for the swing bolt, do the bolt heads show from the outside? I hate to drill into this old fiberglass top of mine to make those holes.
Michael Oritt
Nothing shows on the outside. I don't know what kind of top you have but must imagine that the material at the corner is thick and heavy enough to allow the use of a blind fastener. Fiberglass is not always the best material in which to cut threads with a tapping screw or the like and you may want to use a threaded insert that you can epoxy into the top material which would allow the use of machine screws for the swing bolt, etc.
Healey 100
Here is the arrangement mine uses. It has been this way for the 40+ years I've owned the car. There is a crude spacer made of flat sheet metal to lower the clamp just a bit. We have driven it with the top on 30K or more miles, top hasn't flown off yet. It leaks rain under the header. It is fairly rattle free. It tends to scar the paint under the lower top to body gasket. That gasket is badly worn and it is hard to find a decent replacement for it.
55modified
55modified
Thank you. I will probably do something like this to start. Pete Farmer sells a kit as well. Looks to be high quality. Here is a photo:
J General TR D Type overdrive not working need suggestions Triumph 5
J rear brake rubbing, need suggestions Triumph 12
BugeyeNJ58 Need new ignition switch..Suggestions? Spridgets 3
B I need some advice/suggestions.... Triumph 10
Rick_Neves Big Healey Frame Repair - I need some suggestions Austin Healey 3
T Need to ship parts car WV to VA, any suggestions? Triumph 8
Wana Need suggestions regarding exhaust system Austin Healey 23
vping Suggestions - Need Help Spridgets 15
A Spitfire Bad carb on 78 Spit-need suggestions Triumph 2
A Hasn't run in 10 years, need suggestions Triumph 15
M For Sale 6.0 harmonic balance need rebuilding Jaguar Classifieds 0
tr6web TR6 Need advice removing downpipe nuts Triumph 4
giwplay1 Everything you need to know before purchasing an Austin Healey Austin Healey 15
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 5
K TR2/3/3A Does this fitting need a Whitworth wrench? Triumph 10
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
Gliderman8 TR6 Now I really know why I need new shocks Triumph 11
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
W Need advice on installing new side curtain glass Spridgets 1
AngliaGT General TR You Might Need Snow Tires for This - Drive Your Triumph Day 2023 Triumph 5
M Wanted Need 59 Bugeye Dashboard. LHD. Spridgets Classified 1
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
K TR6 Need help with Mimosa Yellow Paint Triumph 1
T Storing nuts and bolts (so you can find what you need) Austin Healey 7
AngliaGT Need Ideas on Selling Our Midget Spridgets 10
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
drooartz MGB OD question - need to warm up? MG 8
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 1
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
shadowfever Wanted Need a Sprite Mk II bonnet Spridgets Classified 1
jackq Wanted Need a C Tach MG Classifieds 2
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
apbos New/Old wheels for my Speedwell Sprite. Need Center Caps Spridgets 13
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
AngliaGT I Need to Resist - 1980 Ford Fiesta Other Cars 9
vette Need BugEye Generator Austin Healey 7
vette Need BugEye Generator Spridgets 4
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
J TR2/3/3A Need help with pivot and body bracket for hood Triumph 2
Madflyer For Sale Triumph GT 6 parting out need something Triumph Classifieds 10
KiwiStagguy Re building my power steering 71 Stag . Rust and pitting bad . Need a business name to fix it Triumph Classifieds 0
tinman58 TR2/3/3A Need super charger!! Triumph 7
B Wanted I need a small section of a bugeye bonnet Spridgets Classified 5
volunteer Wanted Need Door Seals, Vent Window Seals and Trunk Seal for Daimler ds420 Limo Jaguar Classifieds 23
Got_All_4 TR5/TR250 Need guidance for replacing steering column bushings Triumph 11
John Turney Need a Better Demister? Austin Healey 5
K TR2/3/3A Need advice on what my TR3A might be worth..... Triumph 10
