TR2/3/3A Need New Battery for TR3A
Skidude
After more than 17 years - my red top Optima battery finally gave up the ghost. Looking at purchasing an Interstate battery from Costco (based on all the positive remarks about that brand of battery on this forum). My TR3A has been converted to Negative ground. Which size battery would be best - the 24 or the 27? Or, should I just go with the larger size battery (the 27) because it has greater cold cranking amps (810 versus 700)?
Based on your 17 year service from the Optima Red Top it is the least expensive on a cost per year basis. The battery tray on all the TR2s through the 4A were designed for the group 27 size. Only problem with the 27 size is the hoisting the back breaking task of putting it in place. Any other size just does't look right to my eyes.
Peel off the Interstate or what ever stickers and replace with a Lucas 4" X 6" sticker from any of our suppliers.
Lou Metelko
Auburn, Indiana
I went in a weight reduction kick when it was time to replace the battery of my TR4 in 2008.
I looked around and settled on the Group 59 Costco battery used in V6 Ford Mustangs and saved 16.4 lbs over the Group 27 battery. That Group 59 battery is still going strong after 12 years.
For comparison:
Group 59, 590 CCA, 32.6 lbs
Group 24, 700 CCA, 42.1 lbs
Group 27, 810 CCA, 49 lbs
Yes, I gave up some CCA, but in my climate that is not a problem even using 20W-50 oil in the dead of winter (I do have a high torque starter).
The only thing I had to do, to fit the Group 59 battery in the TR4, was shortening and cutting some longer threads on the "J" bolts since the battery is that much smaller in size.
M.
I have negative ground. Positive side of battery needs to be on the left - does it matter is the battery posts are located toward the front of the car - or, toward the back (firewall)?
I have negative ground. Positive side of battery needs to be on the left - does it matter is the battery posts are located toward the front of the car - or, toward the back (firewall)? Interstate battery group 24 and 27 batteries posts are located differently. The group 24 would have the battery posts facing the front of the car (toward the hold down bar) - the group 27 battery posts would be at the back of the battery box (next to the firewall) - these two different installs would then place the positive post on the left hand side where the positive battery cable is located.
I also have negative earth on my TR4.
I personally liked the idea of moving the battery posts away from the firewall and toward the engine. I also installed a battery cut-off on the negative terminal for convenience. https://mossmotors.com/switch-battery-cut-off-1
Attached is a pic of the Group 59 battery installed in my TR4, battery posts are toward engine, neg post is at the left side.
M.
I use a Miata battery in my TR4 as part of both the car and owners weight loss program. The car has alternator and an electric cooling fan that runs after shut down. No problems yet
For comparison:
M.
I have owned my 1959 TR3a since 1962. I have owned my 62 Chrysler 300H since 64. I have normally used a size 27 battery in both of them only because I decided the more lead and acid and bigger CC time was better. I actually weighed batteries and it seems to me like the 27 was 75# back then (although my age may be affecting memory!)
Just bought a new Costco Group 27 battery a 3 weeks ago before going on a 2-day rally. It's a great price for a battery these days, and with the 810 CCA, the (original) starter spins much more assertively. I peeled the "Interstate" sticker off the front and stuck it on the back (firewall) side of the battery, then added one of the reproduction "Lucas" stickers to the front side. The modern battery won't fool anyone who looks closeley, but hey, it was fun...
Now that I'm old, it feels like all batteries weigh 75 pounds!
Gliderman8 TR6 Need battery info please for TR6 Triumph 4
58Custom What battery size do I need? Spridgets 8
Got_All_4 Wedge TR7 Speedo Problems Need a Repair Place Triumph 2
M For Sale 6.0 harmonic balance need rebuilding Jaguar Classifieds 0
tr6web TR6 Need advice removing downpipe nuts Triumph 4
giwplay1 Everything you need to know before purchasing an Austin Healey Austin Healey 15
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 5
K TR2/3/3A Does this fitting need a Whitworth wrench? Triumph 10
Gliderman8 TR6 Now I really know why I need new shocks Triumph 11
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
W Need advice on installing new side curtain glass Spridgets 1
AngliaGT General TR You Might Need Snow Tires for This - Drive Your Triumph Day 2023 Triumph 5
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
K TR6 Need help with Mimosa Yellow Paint Triumph 1
T Storing nuts and bolts (so you can find what you need) Austin Healey 7
AngliaGT Need Ideas on Selling Our Midget Spridgets 10
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
drooartz MGB OD question - need to warm up? MG 8
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 1
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
shadowfever Wanted Need a Sprite Mk II bonnet Spridgets Classified 1
jackq Wanted Need a C Tach MG Classifieds 2
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
apbos New/Old wheels for my Speedwell Sprite. Need Center Caps Spridgets 13
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
AngliaGT I Need to Resist - 1980 Ford Fiesta Other Cars 9
vette Need BugEye Generator Austin Healey 7
vette Need BugEye Generator Spridgets 4
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
Madflyer For Sale Triumph GT 6 parting out need something Triumph Classifieds 10
KiwiStagguy Re building my power steering 71 Stag . Rust and pitting bad . Need a business name to fix it Triumph Classifieds 0
tinman58 TR2/3/3A Need super charger!! Triumph 7
B Wanted I need a small section of a bugeye bonnet Spridgets Classified 5
volunteer Wanted Need Door Seals, Vent Window Seals and Trunk Seal for Daimler ds420 Limo Jaguar Classifieds 23
Got_All_4 TR5/TR250 Need guidance for replacing steering column bushings Triumph 11
John Turney Need a Better Demister? Austin Healey 5
K TR2/3/3A Need advice on what my TR3A might be worth..... Triumph 10
69MGC MGC Need one MGB/C Splined Hub MG 1
69MGC Wanted Need one MGB/C Splined Hub MG Classifieds 4
Gliderman8 General TR Need clarification on Triumph Competition Preparation Manual TR250 TR5 TR6 Triumph 4
S TR6 Need wisdom on tr6 brake calipers Triumph 6
J MGB Need help identifying these parts MG 6
B MGB-GT Need help with MGB GT rattle MG 0
AngliaGT MGB Need a GT [or Three]? MG 1
