Need BJ7 Seat Belt Bracket Location
HealeyRick
The BJ7 (and I think the BJ8 as well) has two holes drilled for the outboard seat belt bracket (the one with the removable mounting pin). I've done such a great job insulating the top and bottom of my floorboards, I can't find the holes now that it's time to mount the bracket. Can anyone give me some measurements from the inside sill and rear bulkhead so I can start dousing for the holes?
Thanks in advance
Hi Rick,
The document on the Healey6 web site addresses the 3000 4-seater. I roughly checked the measurements against my BJ8 P1 (exactly as your BJ7) and they seemed to match my anchors locations. The measurements in the article should get you close enough to find your exact locations with a needle probe.
Ray (64BJ8P1)
RAC68 said:
Hi Rick,
Ray (64BJ8P1)
Thanks for sticking with me, Ray. I found my error. I was thinking the "B" measurement was taken from the rear bulkhead which would have put the bracket inside the rear side panel. On closer look, I figured the datum point for the B measurement was the rear door shut face. Once I measured from there, had no trouble finding them.
Thanks again, Ray and also a big thanks to John Sims for cataloging all that useful Healey info for us. :cheers:
Schroeders BJ7 Exhaust on a BJ8: do I need downpipes? Austin Healey 10
S Need Engine Block For BJ7 Austin Healey 2
Got_All_4 Wedge TR7 Speedo Problems Need a Repair Place Triumph 2
M For Sale 6.0 harmonic balance need rebuilding Jaguar Classifieds 0
tr6web TR6 Need advice removing downpipe nuts Triumph 4
giwplay1 Everything you need to know before purchasing an Austin Healey Austin Healey 15
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 5
K TR2/3/3A Does this fitting need a Whitworth wrench? Triumph 10
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
Gliderman8 TR6 Now I really know why I need new shocks Triumph 11
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
W Need advice on installing new side curtain glass Spridgets 1
AngliaGT General TR You Might Need Snow Tires for This - Drive Your Triumph Day 2023 Triumph 5
M Wanted Need 59 Bugeye Dashboard. LHD. Spridgets Classified 1
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
K TR6 Need help with Mimosa Yellow Paint Triumph 1
T Storing nuts and bolts (so you can find what you need) Austin Healey 7
AngliaGT Need Ideas on Selling Our Midget Spridgets 10
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
drooartz MGB OD question - need to warm up? MG 8
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 1
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
shadowfever Wanted Need a Sprite Mk II bonnet Spridgets Classified 1
jackq Wanted Need a C Tach MG Classifieds 2
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
apbos New/Old wheels for my Speedwell Sprite. Need Center Caps Spridgets 13
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
AngliaGT I Need to Resist - 1980 Ford Fiesta Other Cars 9
vette Need BugEye Generator Austin Healey 7
vette Need BugEye Generator Spridgets 4
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
J TR2/3/3A Need help with pivot and body bracket for hood Triumph 2
Madflyer For Sale Triumph GT 6 parting out need something Triumph Classifieds 10
KiwiStagguy Re building my power steering 71 Stag . Rust and pitting bad . Need a business name to fix it Triumph Classifieds 0
tinman58 TR2/3/3A Need super charger!! Triumph 7
B Wanted I need a small section of a bugeye bonnet Spridgets Classified 5
volunteer Wanted Need Door Seals, Vent Window Seals and Trunk Seal for Daimler ds420 Limo Jaguar Classifieds 23
Got_All_4 TR5/TR250 Need guidance for replacing steering column bushings Triumph 11
John Turney Need a Better Demister? Austin Healey 5
K TR2/3/3A Need advice on what my TR3A might be worth..... Triumph 10
69MGC MGC Need one MGB/C Splined Hub MG 1
69MGC Wanted Need one MGB/C Splined Hub MG Classifieds 4
Gliderman8 General TR Need clarification on Triumph Competition Preparation Manual TR250 TR5 TR6 Triumph 4
S TR6 Need wisdom on tr6 brake calipers Triumph 6
J MGB Need help identifying these parts MG 6
S TR2/3/3A Need New Battery for TR3A Triumph 9
B MGB-GT Need help with MGB GT rattle MG 0
