    BCF is a FREE resource for the Little British Car community. I just did a little math and found that less than 1% of the registered members appreciate this forum enough to support us with an account upgrade. We do not "require" you to pay to play here, but if you find BCF helpful, appreciate no pop up ads, and want to ensure we stay online - Consider supporting us with an "optional" low-cost member upgrade. There are some benefits to upgrading!
I need a 1275 head.
regularman
I hope my motor holds together until this winter but even if it does, I need to get another head and get it ready to go. I am just looking for a used head with no known cracks and all the parts still with it, if possible. Not a lot of money to put into it but I have time. I just don't want to pull my head unless I can find another one ready to go on it. Anybody close to me with a junker or a head?
Kim, if you are planning on rebuilding the head yourself (I will probably regret suggesting this) contact Bill Cox in Shelby and ask him if he has a used 12G940 head you can buy.
https://www.montecarlomini.net/avail.htm
There are both big and small valve 12G940 heads.
The ones I have need a complete rework and I would not use without being magnafluxed.
I'm not close, but I've got one. I took it off a running motor about five years ago, but it would need to be cleaned up. Can't guarantee anything, but it's yours for price of shipping if you want it.
Norm Abbott is the eBay guy (mentioned above). I have also bought a number of parts from him over the years. He's a very helpful and fair guy. Bill Cox will be closer if you want to drive to pick up a head. However, the last time I shipped a cylinder head it wasn't too expensive (roughly $30 from California to NC). Norm's in PA so shipping shouldn't be that high.
I have done quite a few heads myself for regular road use. check the valves, seats, guides, and put in new valve seals. I also have an abrasive blaster and some magnaflux spray somewhere downstairs that is supposed to show up cracks, etc. More time than money right now, so I will do my own. There is still the possibility that it is a crack in a cylinder wall, or (pretty unlikely after the 3rd head gasket) still a gasket problem. If it turns out not to be the head then I will have a spare for myself or someone else.
That sounds like exactly what I need right there. One that was working good when removed that needs a good going through. I live in Arden, NC 28704.
That sounds more like a dye system as MagnaFlux requires some additional equipment. We used to use the dye to inspect castings in a previous job. It worked well as long as the part was properly prepared.
Don't forget your local club up there (BCCWNC)
https://www.bccwnc.org/
I know there are some A-series owners in the club. One of them may have a spare head available.
I have a 12G940 that will cost you and one off of a '71 smog plugged, worked well when removed cheap. NYC
PM me if you are interested
Pat
I got quite a few bare heads, mostly 12G1316. The best way to crack check a head is to pressure check it, it always help for checking for cracks if you beadblast the head first, magnfluxing into a carbon filled exhaust port is a uselss effort. 1275 head normally are good to not be cracked, it rare to find a cracked one, but still it's not chance I take.
Here's my first piece of advice, put hardened exhaust seats in the heads, no matter what the exhaust seats look like, the old original seat even if they look good good want hold a seal, we've proved this with leak down test. Chris let me know if I can be of hlep, I got a excellent shop that does the seats, for me, in fact all the Western NC SCCA racers of all sorts of cars come down my way for this kind of work. Give me call if that interest you.
Some of you up there, probably know Tony Kipling of Old English Cars in Hendersonville, his race car, thats my old SCCA FP car, I traded him a street MGB GT he restored for the FP race car, I recently in tha last year or so helped Tony switch over to a limited prep 1275 HP engine, I did the head, crank, rods in that motor for him. Tony is a good guy, does mostly maintainence work on Ladn Rovers and LBCs you also got Gary Nye, Basicly British up there as well, he does good street car work and some restoration work, gary is good guy, ther are a few more up there, but I end my list with Gary and Tony :smile: There00 are few BS artist up there in the hills as well :smile:
Bottom line, we've got better machine shops and engine resources down here than you guys have up there in WNC. OK, OK, Ok you guys have better roads, and colder rivers :smile:
Here's a picture of my old FP car, this was 2002 at the Mid Ohio National championship runoffs. The car pretty much looks thew same now that Tony has it.
Definitely some good folks at the club but I really can't make the meetings with how I work, I went to one meeting and there was one guy with a 74 midget and one guy who owend a bugeye but neither of them seemed to be the type to do much oth their own work. I met that guy that wokr at old english cars, he was driving a 1275 mini pickup truck. I enjoy doing things myself. I will figure this out, eventually.
I don't know if club member Neil Weinmann would have a spare 1275 head or not but I would ask him. He should have contact info at the club web site. You can tell him that I sent you his way.
Bill Cox in Shelby isn't too far either. You have to be careful how you work with Bill as he's a bit "touchy". If he doesn't have a 1275 head down there already he could certainly have one put/placed in one of the cars he brings in from the U.K.
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
DugMoney Need Advice - Moving Temp Gauge Sensor 1275 Spridgets 3
M 1275 to 948 Generator Swap - Need Input Please Spridgets 4
M 1275 need to install water temp bulb. Spridgets 6
T Need advice on a 1275 Spridgets 6
Bruce_B Need as 1275 Camshaft & an introduction Spridgets 12
Banjo in need of a 1275 engine Spridgets 6
Got_All_4 Wedge TR7 Speedo Problems Need a Repair Place Triumph 2
M For Sale 6.0 harmonic balance need rebuilding Jaguar Classifieds 0
tr6web TR6 Need advice removing downpipe nuts Triumph 4
giwplay1 Everything you need to know before purchasing an Austin Healey Austin Healey 15
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 5
K TR2/3/3A Does this fitting need a Whitworth wrench? Triumph 10
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
Gliderman8 TR6 Now I really know why I need new shocks Triumph 11
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
W Need advice on installing new side curtain glass Spridgets 1
AngliaGT General TR You Might Need Snow Tires for This - Drive Your Triumph Day 2023 Triumph 5
M Wanted Need 59 Bugeye Dashboard. LHD. Spridgets Classified 1
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
K TR6 Need help with Mimosa Yellow Paint Triumph 1
T Storing nuts and bolts (so you can find what you need) Austin Healey 7
AngliaGT Need Ideas on Selling Our Midget Spridgets 10
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
drooartz MGB OD question - need to warm up? MG 8
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 1
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
shadowfever Wanted Need a Sprite Mk II bonnet Spridgets Classified 1
jackq Wanted Need a C Tach MG Classifieds 2
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
apbos New/Old wheels for my Speedwell Sprite. Need Center Caps Spridgets 13
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
AngliaGT I Need to Resist - 1980 Ford Fiesta Other Cars 9
vette Need BugEye Generator Austin Healey 7
vette Need BugEye Generator Spridgets 4
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
J TR2/3/3A Need help with pivot and body bracket for hood Triumph 2
Madflyer For Sale Triumph GT 6 parting out need something Triumph Classifieds 10
KiwiStagguy Re building my power steering 71 Stag . Rust and pitting bad . Need a business name to fix it Triumph Classifieds 0
tinman58 TR2/3/3A Need super charger!! Triumph 7
B Wanted I need a small section of a bugeye bonnet Spridgets Classified 5
volunteer Wanted Need Door Seals, Vent Window Seals and Trunk Seal for Daimler ds420 Limo Jaguar Classifieds 23
Got_All_4 TR5/TR250 Need guidance for replacing steering column bushings Triumph 11
John Turney Need a Better Demister? Austin Healey 5
K TR2/3/3A Need advice on what my TR3A might be worth..... Triumph 10
69MGC MGC Need one MGB/C Splined Hub MG 1
69MGC Wanted Need one MGB/C Splined Hub MG Classifieds 4
Gliderman8 General TR Need clarification on Triumph Competition Preparation Manual TR250 TR5 TR6 Triumph 4
