How to install Stone Guards on driving lights?
Chet Zerlin
Hi All,
I should probably have entitled this one "silly question #293".......:D
I bought a set of 7" stone guards to put on my 7" driving lights. I must be missing something but I don't see how they would mount on the lights using the included hardware (see picture below). Do I disassemble the lights and somehow put those mounts in between the lens and the light or the lens and the light bracket...or?
Before I break anything (which I have been known to inadvertently do...) does anyone know the "right way" to do this?
Thanks!
Chet
The headlight ones come with a kit that has some stainless steel tabs in . Remove the chrome ring (carefully) then install the stainless tabs under three screw at 2/6/10 oclock . Refit the chrome ring and the tabs are pointed forward out the gap between the ring and glass the stone gaurd then clips onto the protruding tab point .
Do you have the 7" Lucas Flamethrowers?
If so, you can bend those clips to go between the ring that holds the light and the light itself. The bucket has 4 cutouts that you don't see when the light is assembled: one for aligning the light and 3 for some other purpose, but those 3 are at 120 degree angles, starting at 60 degrees from the top. The clips go in those 3 cutouts. I would take a clip out to show you the bend, but it takes a couple more hands than I've got to easily put it back together.
Thanks John, that's exactly what I needed to know. I have the 7" Lucas driving lights sold by XKsUnlimited. (picture below) so I'll give it a try! Thanks everyone!
Chet
Some more photos to help install.
First photo: The outer shell has four cutouts in the rim, the one on the upper left in the photo matches a bracket on the light so the lens is upright. The other three are spaced at 120 deg and are where the clips go.
The second and third photos show how the clips are bent to match the rim of the light. The tab that normally has a screw that holds the clip in place when putting the guard on a headlight can be bent flat or left as is.
The fourth photo shows how you put the clamp ring on the light, slip the clips in the gap and rotate the clamp ring around until all the clips are held next to the lamp in their approximate positions.
Now, you put the bulb in the lamp (don't touch the bulb glass), connect the bulb holder and slip the bulb in the housing with the clamp ring on the outside, align the bulb with its cutout and the clips with their cutouts and tighten. Before tightening completely, put the wire guard in the clips and finish tightening.
I have the Lucas driving lights that have the logo on the top. I do not believe those notches are present on them but I have not had to get into them in many years so this is only from memory.
I had the stone guards on the head lamps for a while but took them off because it was a PIA to get the bugs out. They did not remove easily.
These stone guards are for the 7” driving lights. Getting bugs out is easier, and cheaper, than replacing a broken lens.
C TR4/4A Install after jet gland replacement SU H6 in TR4 Triumph 2
Celtic 77 MGB Rerouting heather pipe after Weber install. MG 13
angelfj1 TR2/3/3A TR3A Boot Millboard Install Triumph 7
E Heater install Spridgets 2
algot1901 Roof install Other British Cars 16
A Spitfire Install fan Triumph 1
S Install drain cock in radiator. MG 2
Popeye TR4/4A Accelerator shaft install - location of bushing plates? Triumph 2
AUSMHLY BJ8 transmission mainshaft bearing force needed to install/remove Austin Healey 1
6 Master Cylinder Install Spridgets 5
S MGB Transmission cross member re-install MG 14
K TR2/3/3A The guide bolts to help gearbox install? Triumph 19
K TR2/3/3A Brake caliper piston install? Triumph 18
EWD TR6 Top Install Triumph 3
J TR4/4A Seat install, Spring clip Triumph 0
R side light install Spridgets 2
R TR2/3/3A Install new wiring harness in steering column Triumph 16
Joel Lester TR2/3/3A Any advice for new floor install on my TR3? Triumph 9
L TR6 Rear Brakes Shoe Repair and Install Triumph 2
71TR6 TR2/3/3A TR3A Front Sway bar- how to install? Triumph 5
J Tips for quarter elliiptic spring install Spridgets 3
T Pertronix distributor install into Austin Healey 100/6 Austin Healey 12
SherpaPilot TR6 Difficulty with New Seat Diaphragm Install Triumph 6
EWD TR6 Trunion Install Triumph 0
A TR2/3/3A Interior rear panel covering gas tank and rear seat bottom install. Triumph 7
66healey BJ8 shifter spring install Austin Healey 2
K TR2/3/3A Steering box install again...the collar with the pinch bolt? Triumph 9
GeorgeC Intake / exhaust manifold gasket install goop? Spridgets 2
F Heater valve/tap gasket- Install dry? Austin Healey 10
Csarneson BN4 Cam Gear Install Austin Healey 3
Rut 5 speed install Spridgets 14
R More Shroud to Scuttle install Austin Healey 4
R Dash Install questions Austin Healey 31
S TR2/3/3A how to install a gas tank in an early tr3 Triumph 8
P BJ7 Carpet Install Questions Austin Healey 29
J TR2/3/3A Trunnion Install Triumph 3
B TR2/3/3A Cigarette Lighter Install Triumph 7
D Prepping to install engine Spridgets 2
P BN2 new wood steering wheel install Austin Healey 5
C MGB Paint first or install mechanics MG 10
T TR4/4A Rear Seatback/Hoodstick [Top] cover install Triumph 0
D BT7 Timing chain install Austin Healey 2
CessnaTPA Tonneau Install Question Austin Healey 13
G TR4/4A Interior Install...and other random questions. Triumph 11
S TR2/3/3A install the OD relay Triumph 3
steveg Wiper motor install error - warning Austin Healey 9
55modified Anyone install one of these [100S Kilmartin pieces] for fresh air in your footbox? Austin Healey 14
Jim_Gruber Need your ideas on a How To Do it - SpeedHut Gauge Install Spridgets 11
G TR4/4A Interior Install Steps Triumph 3
