Header Ceramic Coating
Lin
I just got my Bugeye header back from Swain Tech Coatings. Of course, the proof is always in the pudding, but I went with them rather than "Jet-Hot" because they advertise "at least a 50% reduction in radiant heat for their "White Lightning" product. I may use them for the big healey pipes also.
The pipes are an oyster color (silver gray) and the finish is rough but the appearance is pleasing I think. "Because this is a true ceramic insulating coating and not a high temperature paint, it is not available in colors. However, the coating can easily be painted with a good high temperature paint." It will be several weeks before I have the car running again so I don't know if the temp. assurances will pan out, but I am pleased with the uniformity of the coating application and the overall appearance. "White Lightning is a three layer permanent coating that is applied approximately .015" thick."
My pipes were slightly rusted with paint flaking off. the pipes were cleaned up and coated for $150.00.
Anyone have experience with the product?
No financial interest - just a pleased customer - so far.
You can look at the physical appearance of the pipes here:
https://homepage.mac.com/linwoodrose/PhotoAlbum7.html
You can look at Swain's web site here:
www.swaintech.com
Lin Rose
1960 BT7 in restoration
1959 Bugeye
They look good, I might try them for a set of (factory) headers for my soon to be supercharged 99 M Rdstr.
I used Jet Hot for the Healey and have no complaints.
ThomP
I "Jet Hotted" the header for my Mini. Three years later, it still looks good.
danstr6 Ceramic Coating for Header Triumph 14
K TR2/3/3A Using header wrap on a street car? Triumph 5
C LCB header with 1500 single carb inlet manifold Spridgets 1
K TR2/3/3A Intake header crossover passage..... Triumph 4
CARSINC Please Identify this Exhaust Header Spridgets 2
K TR2/3/3A Time to replace the exhaust header wrap.... Triumph 2
JFS TR2/3/3A Exhaust Header Fitment Triumph 13
P For Sale Weber carb/intake, header Spridgets Classified 2
J For Sale Header, hub caps Spridgets Classified 1
M Muffler Options with Exhaust Header Spridgets 1
bugedd Free header Spridgets 0
MadMarx Wedge Custom Header IMSA TR8 Triumph 14
Rut TR4/4A Header seal attachment Triumph 0
Rut TR4/4A Header seal Triumph 3
R TR6 tr-6 header Triumph 0
B Advice on Wooden Header and Side Trim Rails for a BJ7 Convertible Top Austin Healey 9
D TR4/4A General header question Triumph 6
T HP Impact of a Toyota transmission, or a header/2" exhaust ??? Austin Healey 16
Joe Reed General Tech VHT Flame Proof Header Paint MG 17
tomshobby Header Rail Seal Spridgets 4
H TR4/4A Header Rail Assembly Triumph 2
K TR2/3/3A TR3 Exhaust header's proximity to rear of generator? Triumph 4
Jim_Gruber Looking for header and rear BE Top bars Spridgets 18
N Recommend a header? Spridgets 4
D BJ7-8 header seal retainer Austin Healey 3
Boggsy64 MGB Three port exhaust header? MG 6
B TR6 TR6 decision on header/manifold/exhaust Triumph 4
V early BN4 question - top & header rail Austin Healey 3
B Header rail weatherstriping Austin Healey 6
G Long center branch header for 1500? Spridgets 0
L Tubular header to ss exhaust pipe Spridgets 12
Coyote1 TR6 TR6 Header Rail Question Triumph 4
johnrip Wedge TR7 pacesetter header connection to stock exhaust Triumph 2
JPSmit Header and muffler connected Spridgets 16
JPSmit Header Question Spridgets 2
GBRandy Wedge TR8 Header Install Triumph 42
bthompson Hood header rail gasket Spridgets 9
glemon Best Glue for Header Rail Triumph 8
7 Spitfire Spitfire Header Triumph 6
JPSmit Header Question Spridgets 9
tahoe healey header rail cover Austin Healey 0
DNK Header Bolts Triumph 17
mjobrien Top cross section at the front header / bow Austin Healey 0
doates Spitfire Spitfire Windshield Frame Header Triumph 5
PSJ Hardtop front header seal Spridgets 4
T Back to original, cast iron header. Triumph 16
T Need exhaust header advice/source for Amos Triumph 49
PAUL161 Hap-- Exhaust manifold/header paint? MG 2
drooartz View of the header faces Spridgets 47
RJS Header/ Exhaust Manifold Wrap Triumph 2
