Fuel Injection
healeyblue
That is a COP coil...... they connect directly to each spark plug with a stainless steel spring, each coil is mounted to the head. They fuction as a coil and spark plug wire all in one! its for better timing, fuel emissions. Look on there web site for more info..... I just did!:smile:
For those wondering COP stands for "coil on plug". They are used on cars with computerized ignition and fuel injection. A computer fires each coil individually controlling advance and retard as well, no distributor needed.
andrea
That is a COP coil...... they connect directly to each spark plug with a stainless steel spring, each coil is mounted to the head. They function as a coil and spark plug wire all in one! its for better timing, fuel emissions. Look on there web site for more info..... I just did!:smile:
Theoretically can we add six COP to our AH without shift to ECM control unit and ignition system?
In this case Distributor can give only BT (12 volt) input to COP ?
Chris_Masucci
Andrea, you would have to modify the distributor into a 6 way switch, since 12V would not jump the gap between the rotor and cap. Or, you could fire all 6 COPs at the same time, every time, but I suspect the points would not last very long supplying current to 6 coils concurrently.
Theoretically, yes. However, the advantage/necessity of COP ignitions is that the ECM can fire any plug it wants to, whenever it wants to, giving much more precise control of timing for a greater range of driving conditions (hence better performance, use of different grades of gas, etc.). Also, you don't have to run high tension lines to each plug.
I haven't heard anything lately, but problems were rampant with earlier ECM/COP designs. Some VWs, in particular, had a lot of problems with the COPs. The Lincoln LS was notorious for COP problems. My parents have one, and were about ready to junk the car--they otherwise loved it--until I found a website where a pro mechanic had diagnosed the problem: failing COPs could cause a voltage spike on the primary line which caused the ECM to shut down. My dad--who's 82 but still likes to romp on it when he has an excuse--got shook up when his engine quit while trying to merge on a fast and busy freeway (I5 in California). Changing the occasional bad COP would help in the short term, but the problem wasn't solved until we replaced all 8 COPs with a newer, presumably better, design sourced from NAPA. Note the COP is a small, plastic-encased design that is doing basically the same job as an older, metal-encased and oil-filled coil (I think COPs use a little different circuitry, with some aspects of a capacitive discharge design, but I'm not sure about it).
andrea
Tanks for replies
I continuing my theoretically inquiry:in my opinion EFI, ECM, and Fuel injection system are hard matter for the integration in one oldest cars as AH
only few guys as Steve and Phil have the capacity to solve all the involved problems.
I will find one more simple (and less expensive) solution, and also less invasive for my AH aspect-- and at my capacity limit.
Looking at Phil good solution to hide the six COP.
I have one brainwave, connect my 123 Distributor-point less, One modern electronic evolution, more efficient, of the old distributor-
that have one good curve timing control and a connection to the intake manifold that modify the advance on the base of open throttle position
and connect it to six COP- this probably avoid the problems advanced by Chris - and partially the ECM lack, prospected by Bob .....???!!!
https://picasaweb.google.com/lh/photo/RvSLhahLAsVdg3VBEh4GgtMTjNZETYmyPJy0liipFm0?feat=directlink
Current to COPs is primary--i.e. 12V--electronically switched to each plug by the ECM. The distributor 'switches' high voltage--15,000V and higher--hence the robust contacts. The air gap between the rotor and cap terminals is inconsequential at 15,000 volts and higher; I don't think 12V would switch very well (if at all) through a distributor cap. Plus, you'd need to run small wires to the COPs, not very practical and would look plain silly. If you want to run COPs you need to switch them electronically; i.e. through an ECM. Firing COPs through an ECM is extremely precise, sending high voltage through a distributor cap is less so (depends on when the spark decides to jump the gap).
All the COPs I've seen have 2 wires going to them; I presume one is a ground lead since the coil itself is isolated (same reason your coil works by grounding through points).
Now I've had a brainwave. It would be possible for someone to design and construct a 'smart' distributor cap, with, say, a rotor with a magnet in it. Each of the six (or 4) terminals would have a Hall Effect switch in it that would switch 12V to a pair of wires for each COP. This is similar to how the Pertronix Ignitor works, and is entirely feasible. Basically, each terminal in the cap would be an Ignitor, switching 12V to a COP. The cap would only need a 12V and ground lead (just like Ignitors do). Of course, the cap would probably cost as much as 6 Ignitors!
To be solved would be how to advance/retard the timing with no points.
5
57_BN4
Actually you have answered your own question pretty much since the rotor advances in sync with the points cam so too would the timing if the rotor was triggering the ignition as opposed to 'distributing' the spark.
Modern COPs have the ignitor module built into them so you could just have six hall effect or optical switches in the cap and send a 5V signal to the coils.
Why...? bit of bling maybe? no real advantage on an old plodder over conventional setup.
Andy.
Andy.
Last I checked distributors advance timing by moving the points baseplate, either via weights or a vacuum mechanism, moving the position of the points relative to the cam. You'd have to maybe attach another magnet to the baseplate to inform the 'smart cap' to advance timing.
5
57_BN4
The flyweights advance the [points] cam so yes you'd lose vac advance.
Good point. A performance distributor--not using vacuum advance--would work fine, or you could add another magnet to the baseplate and a pickup in the cap to detect vacuum advance. This is feasible, but I don't know if it's worth the trouble, except you could add other inputs--a MAP or throttle position sensor for instance--and have, in effect, an ECM mounted on your distributor.
Also, the COPs don't have to look like they (usually) do. The long 'neck' is only necessary to reach plugs that are buried deep in the head, usually in OHC engines. You could make a 'rail' of 6 (or 4) small COPs that would fit all the plugs on a Healey, and be supported by brackets that bolted to, say, the tappet covers.
How about that! Someone took my idea and built a product overnight! But, they screwed-up and read 'Honda' instead of 'Healey.'
Theoretically--there's that word again--this could be adapted to a Healey engine. You'd want COPs without the long 'neck,' though (maybe they're necessary to somehow isolate the coil from the plug, but I think it's just because the plugs are buried so deep in modern OHC engines).
andrea
Yes Bob for our AH the better solution is hide the compact COP under the RX wing
as MCS Phil photos, and connect the sparks with good HT wires and pipes as actually applied at our old distributor, we loss a fraction of the spark power,
but long neck COPs are very invasive to see in our engine bay
Lin
Phil,
congrats on getting her together and running! Good feeling isn't it? I will be eager to hear of your Dyno results. Best wishes.
cheers,
Lin
M
MCS
hi Lin,
Thanks , it will interesting to see what kinda of Hp i make
Phil
HealeyPassion
Phil,
Have you had a chance to get to the dyno yet? I liked the video of it running!... sounds good.
Cheers,
Steve
1963 Austin Healey Works Tribute car w/efi
M
MCS
image.jpg Steve,
thanks, will be a few more months, the dyno is last on the list just before the body goes back on . I am driving my neighbours crazy listening to my engine and driving up and down my driveway.
Phil
F TR6 RATCO fuel injection Triumph 4
hondo402000 TR6 TR6 Fuel Injection made easy Triumph 12
6 General TR fuel injection Triumph 4
J Austin Healey 3000 Fuel Injection and Supercharged Austin Healey 4
Feathers Fuel Injection Other British Cars 6
rjc157 Patton fuel injection Austin Healey 0
rjc157 Fuel Injection Austin Healey 7
S Wedge TR7 Fuel injection problem Triumph 3
Got_All_4 Wedge 1980 TR7 Fuel injection questions Triumph 17
K 1977 924 Fuel Injection Other Cars 6
Coyote1 Fuel Injection System on Craigslist Triumph 24
JPSmit Fuel Injection for a B? MG 2
G Wedge TR8 Fuel Injection Triumph 7
G TR6 TR6 Fuel Injection ? Triumph 8
M Fuel Injection Problem on 87 XJ6 with 188,000 mile Jaguar 1
AUSMHLY Youtube, 63 BJ7 with electronic fuel injection Austin Healey 28
S Fuel injection cleaning Triumph 6
newmexTR3 TR2/3/3A TR3 Fuel Injection / Turbo project Latest Triumph 12
DanNagy TBI Fuel Injection Installation Triumph 23
T TR6 TR-6 Fuel Injection Manifold Triumph 8
PAUL161 MGB Fuel injection for MGBs. Added Photo MG 9
G Benefit of fuel injection Triumph 10
glemon 6 Cylinder Fuel Injection Conversion Triumph 22
Glen_B Bugeye Fuel Injection Spridgets 4
mgb4tim Wedge TR7 Fuel Injection/Charging system help. Triumph 2
Sparkie Fuel Injection Help, please TVR 12
B Range Rover Electronic Fuel Injection Rover / Land Rover 0
M Fuel injection system for Healeys now available! Austin Healey 20
mgb4tim Wedge TR7 Fuel Injection Pictures Triumph 1
SCguy Wedge TR8 fuel injection Triumph 5
I TR6 Fuel injection for TR6 Triumph 4
kyreb1862 MGB MGB Fuel Injection? MG 13
TR_Jim MGB MGB Electronic Fuel Injection System MG 15
aeronca65t MGB Fuel Injection-MGB-homebuilt MG 5
H Healey Fuel Injection System Austin Healey 10
TRdynamo Fuel injection Triumph 6
Morris TR6 TR6 Fuel Injection Triumph 21
aeronca65t Homebrew Fuel Injection Restoration & Tools 2
D Mini Fuel Injection British Motor Corp 11
Glennyboy MGB MGB Fuel Injection MG 5
H Fuel Injection on a Healey? Austin Healey 10
philip Carburetor or fuel injection? MG 7
W Fuel injection hose Restoration & Tools 2
MattP Fuel Injection Restoration & Tools 10
philman jetronics fuel injection Triumph 2
J XJ6 SII Fuel Injection- Convert to carbs or rebuild? Jaguar 6
K Fuel Injection? MG 6
AndreL TR6 Conversion to electric fuel pump Triumph 11
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
