Fuel Injection
MattP
https://www.bgsoflex.com/megasquirt.html
I read about this system in Car Craft Magazine. It is a DIY kit for a fuel injection computer that can be programmed for 1 to 8 cylinders.
I remember someone on the forum a year ago or so working on (I think) fuel injecting an A-series and thought they might find this useful.
Baxter
Megasquirt is a big big thing now for DIY injection, or to replace some stock systems. Lot of control over your fuel/air mixture. Unfortunately, it doesn't work well with siamesed heads, so the B-series is pretty much out unless you've got a x-flow.
Although I have to wonder about TBI and a supercharger. Wicked!
MattP
MattP
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by Baxter:
<hr></blockquote>
Never afraid to learn. What does "siamesed heads" mean? It sounds a head made of more than one part, but I am guessing.
Dave Russell
Yoda - R.I.P
I think he ment siamesed ports. A single port branches to two valves.
[ 02-24-2004: Message edited by: Dave Russell ]</p>
Mark Beiser
Looks interesting. I want distributorless ignition, traction control and launch control though, so I'll stick with the plan for the $1500 DTA system. =x
Its definatly got potential if you were wanting to do some performance mods to a fuel injected TR7 or TR8.
MattP
MattP
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by Dave Russell:
<hr></blockquote>
Would doing it as a two injector using the cases of a couple of SU's as throttle bodies maybe help? Using throttle body injection would more closely imitate the normal state of these cars and might compensate for the port issue? WAG there.
Baxter
The problem is one of timing. Modern injectors shoot out the fuel in pulses, and the siamesed ports end up robbing the pulse from the adjoining cylinder (or something like that).
Run a google for megasquirt and siamesed and something will turn up. Those guys document everything.
The problem could, in theory, be avoided, by going to the old-school K-jet injection, which wasn't pulsed. But there's really no point in that, since you can't precisely control fuel maps in K-jet.
PC
I don't see why the MegaSquirt controller would have a problem with Siamese ports (I can see why some installations would).
Siamese ports are problematic for sequential FI systems where injection volume and timing are intended for an individual cylinder. Heads with Siamese ports don't share the intake charge evenly and an injector at the common manifold port can't give each individual cylinder what it needs when it needs it.
MegaSquirt is programmable to operate as either batch fired or bank fired. This type of system is well suited to a throttle body installation where the injectors are far enough upstream to provide a uniform air/fuel mixture before the ports.
MegaSquirt is also very flexible in its programming allowing you to tailor it to many different installation configurations. I suspect that this broad flexibility also makes it easy to get lost when attempting to set one up.
PC
Baxter
Pulled from the Megasquirt Yahoo group:
You tell MS how many events to expect per rotation, and it squirts
once per N events. You cannot control which event is used as a
trigger for the injection events, either, so on one start up MS
might use the cylinder 1 signal to fire and on another startup it
might use cylinder 3 or 4.
This is not a problem, except for possibly siamesed ports, such
as are seen on BL A-series motors (Minis, Spridgets et al) or on
TBI installations on 45 v-twins and such. (In these cases, the
injected fuel might be "stolen" by one cylinder's intake pulse...)
If you've got individual injectors per cylinder, don't worry about
odd fire injector timing.
G
Moss is coming out with a TBI fuel injection system for the B this spring. $1400 and no problems, even California legal. I'd rather have the Blower
F TR6 RATCO fuel injection Triumph 4
hondo402000 TR6 TR6 Fuel Injection made easy Triumph 12
6 General TR fuel injection Triumph 4
J Austin Healey 3000 Fuel Injection and Supercharged Austin Healey 4
Feathers Fuel Injection Other British Cars 6
M Fuel Injection Austin Healey 51
rjc157 Patton fuel injection Austin Healey 0
rjc157 Fuel Injection Austin Healey 7
S Wedge TR7 Fuel injection problem Triumph 3
Got_All_4 Wedge 1980 TR7 Fuel injection questions Triumph 17
K 1977 924 Fuel Injection Other Cars 6
Coyote1 Fuel Injection System on Craigslist Triumph 24
JPSmit Fuel Injection for a B? MG 2
G Wedge TR8 Fuel Injection Triumph 7
G TR6 TR6 Fuel Injection ? Triumph 8
M Fuel Injection Problem on 87 XJ6 with 188,000 mile Jaguar 1
AUSMHLY Youtube, 63 BJ7 with electronic fuel injection Austin Healey 28
S Fuel injection cleaning Triumph 6
newmexTR3 TR2/3/3A TR3 Fuel Injection / Turbo project Latest Triumph 12
DanNagy TBI Fuel Injection Installation Triumph 23
T TR6 TR-6 Fuel Injection Manifold Triumph 8
PAUL161 MGB Fuel injection for MGBs. Added Photo MG 9
G Benefit of fuel injection Triumph 10
glemon 6 Cylinder Fuel Injection Conversion Triumph 22
Glen_B Bugeye Fuel Injection Spridgets 4
mgb4tim Wedge TR7 Fuel Injection/Charging system help. Triumph 2
Sparkie Fuel Injection Help, please TVR 12
B Range Rover Electronic Fuel Injection Rover / Land Rover 0
M Fuel injection system for Healeys now available! Austin Healey 20
mgb4tim Wedge TR7 Fuel Injection Pictures Triumph 1
SCguy Wedge TR8 fuel injection Triumph 5
I TR6 Fuel injection for TR6 Triumph 4
kyreb1862 MGB MGB Fuel Injection? MG 13
TR_Jim MGB MGB Electronic Fuel Injection System MG 15
aeronca65t MGB Fuel Injection-MGB-homebuilt MG 5
H Healey Fuel Injection System Austin Healey 10
TRdynamo Fuel injection Triumph 6
Morris TR6 TR6 Fuel Injection Triumph 21
aeronca65t Homebrew Fuel Injection Restoration & Tools 2
D Mini Fuel Injection British Motor Corp 11
Glennyboy MGB MGB Fuel Injection MG 5
H Fuel Injection on a Healey? Austin Healey 10
philip Carburetor or fuel injection? MG 7
W Fuel injection hose Restoration & Tools 2
philman jetronics fuel injection Triumph 2
J XJ6 SII Fuel Injection- Convert to carbs or rebuild? Jaguar 6
K Fuel Injection? MG 6
R TR2/3/3A Fuel pump? Triumph 8
AndreL TR6 Conversion to electric fuel pump Triumph 14
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
