Bugeye Fuel Injection
Glen_B
I finished the welding and grinding on the new intake manifold and installed it Sunday night. With a mower can of gas on the garage floor and the fuel system bodged together externally (pump/pressure regulator), I got the motor to fire up and run for 2 minutes. Enough "proof of concept" to carry on with the next step of adding the return fuel line and installing the new pump/filter/pressure regulator in a more permanent fashion.
The Megasquirt worked well, and the injectors must have worked as planned as the motor ran strong and sounded great. Much tuning to follow.
2pvnfh
Breifly, Rayjay turbocharger, two 44lb/hr Lucas injectors, MSD fuel pump, Ford 1.9 throttle body, Megasquirt v.1
Glen Byrns
Glen_B
Glen_B
I tried to minimize "the smell of the fuel" by mocking up the fuel assembly out of the car, on the garage floor. The "tank", pump, filter, injectors mounted in the manifold with the homemade fuel rail in place, and the pressure regulator were all hooked together and pressure tested several times. Its amazing how tiny a hole can be and still rocket fuel into the air. After four tries on the floor, some remedial welding and grinding, the leaks were cured enough to put the stuff onto the motor.
I knew there would be leaks, I just figured, better on the floor than my treasured toy. And yes, the fire extinguisher was right by my side.
Glen
B Fluctuating Fuel Gauge 1960 Bugeye Spridgets 4
T Wanted Smiths fuel gauge for Mk 1 Bugeye Sprite [FG2530/31] Spridgets Classified 1
S Wanted 1959 Bugeye Fuel Gauge Austin Healey Classifieds 0
Tim Hollister Wanted Need Fuel Gauge for 1959 Bugeye Spridgets Classified 2
I Bugeye fuel fitting Spridgets 3
H Bugeye fuel tank sending unit - repair or replace Spridgets 5
I Bugeye fuel pump help Spridgets 2
Rut Bugeye fuel gauge Spridgets 14
BlueMax Bugeye Fuel Gauge Spridgets 3
P Herko kd8016 fuel pump in bugeye??? Spridgets 5
P Bugeye fuel line? Spridgets 3
drooartz Later fuel tank in a Bugeye Spridgets 11
AN5Sprite Anybody Have A Bugeye Fuel Gauge Core To Spare? Spridgets 3
Ohiobugeye Bugeye Fuel Line Nut & Sleeve For Gas Tank Spridgets 12
ncbugeye Push SU fuel pump in Bugeye Spridgets 8
athenssprite Fuel tank - 1960 Bugeye Spridgets 12
drooartz eBay Bugeye fuel tanks, recent experience? Spridgets 8
ncbugeye Bugeye Fuel Tank Spridgets 8
ncbugeye Can a Bugeye fuel tank sender be restored? Spridgets 7
msoylemez Bugeye Fuel Gauge Spridgets 3
P Electric Fuel Pump for Bugeye??? Spridgets 12
ncbugeye Need immediate help with Bugeye fuel tank Spridgets 10
B Electric fuel pump for a bugeye - Questions. Spridgets 13
B Bugeye Fuel Pump Austin Healey 1
G Bugeye fuel pump Austin Healey 4
R Bugeye ignition switch Spridgets 2
T Music Video with a Bugeye, plus a hill climb video Spridgets 1
D For Sale 1958 A-H Bugeye Sprite Austin Healey Classifieds 3
Todd78d Bugeye carpet Spridgets 7
L For Sale original Bugeye SU H1-1 1/8 Carbs Spridgets Classified 0
Todd78d Bugeye choke linkage Spridgets 5
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
R Wanted Bugeye ignition switch Spridgets Classified 2
drooartz Replacing Bugeye windshield rubber Spridgets 6
CARSINC 1965 Sprite Bugeye Spridgets 5
drooartz The great Gordon Murray has a Bugeye! Spridgets 0
W Bugeye Tudor Wash Bottle Decal Spridgets 0
R Bugeye drum brakes Spridgets 7
SNClocks Bugeye Alignment Spridgets 4
S For Sale Bugeye wheels, steel with round holes set of 5 available Spridgets Classified 0
D Wanted Bugeye bonnet (hood) fiberglass or steel Austin Healey Classifieds 0
M Wanted Need 59 Bugeye Dashboard. LHD. Spridgets Classified 1
drooartz Restoring Penny the Bugeye Spridgets 22
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
SNClocks Bugeye axle limit straps Spridgets 5
R Wanted BUGEYE SHIFT LEVER Spridgets Classified 6
