MGB MGB Fuel Injection?
kyreb1862
Has anybody had any experience with trying to fuel inject an MGB? I know Moss is marketing a fuel injection kit but, has anyone done any experimenting with a home made setup? Are there any advantages to using the Moss kit? I mean besides the obvious advantage of easy starting. /ubbthreads/images/graemlins/grin.gif /ubbthreads/images/graemlins/driving.gif
ccougill
the major advantage, imho, is that the moss kit is a legal alternative to the z/s carb in California
Nunyas
I believe Bret is planning on installing said kit on his 78, but i'm not sure on his progress with it. I think he's also planning on some non-visible mods to help boost power output of the engine. I'm curious to know if he still manages to pass smog with his hopped up engine.
tony barnhill
Great Pumpkin - R.I.P
I've sold only 1 Moss kit & it went to California.
kyreb1862
kyreb1862
Is there any performance advantage? What got me thinking about the whole concept was an old VW Scirroco I had once. I always wondered if any one had tried to home engineer fuel injection using VW components. it always looked possible since the Scirocco had a 1.8 Liter engine also. /ubbthreads/images/graemlins/driving.gif
The main problem with fuel injecting a MGB is that it has siamesed intake ports.... cylinders 1 & 2 get fuel and air from the same port, and cylinders 3 & 4 from the same port. So you can't do a more modern port injected FI system unless you've blown the $2-3K quid on a crossflow 4-port head. The only answer is a CFI (central fuel injection) unit. That means one large fuel injector sitting over a single throttle body. Another problem is that there aren't many if any aftermarket FI computer guys that sell a programmable CFI computer. Most of them sell programmable fuel curve computers based on an injector over each cylinder.
Engine size doesn't play a game at all, unless it has similar valve train timing, siamesed intake ports, and fuel curves designed to meet the needs of an engine of almost exact design as a MGB 1800 engine.
Sorry to break the news... but almost anything not designed around MOSS's new unit (or at minumum a programmable CFI) will not be useful to anyone wanting to modernly inject a MGB engine. It has been done, but with way more problems and money than the MOSS system sells for.
Just my 2¢ worth. /ubbthreads/images/graemlins/grin.gif
kyreb1862
kyreb1862
Your 2 cents is worth as much as the next guys. Sometimes I just like to let my mind wander and speculate on things. I guess its the gunsmith in me I just love to tinker. /ubbthreads/images/graemlins/driving.gif
Nunyas
Throttle body fuel injection is by far the easiest way to adapt fuel injection to "late model" MGBs, ala Moss's kit or something similar. As for whether or not there's any noticeable power gains, I've no clue. I've yet to hear first hand experiences from anyone that's installed the kit on their car. However, I don't expect there to be much improvement on an engine that's other wise stock.
However, I'd like to play devil's advocate here, and say that you CAN adapt multi-port fuel injection to an MGB despite the siamese ports on a stock head. You'd just have to over come that obstacle by either putting two injectors on each port or by putting a single injector in each port and sending multiple injection pulses (2 per revolution) to the injector.
Granted, like Kenny said, it'd be a lot easier to do multi-port injection with one of those high dollar cross flow heads.
At the BMTA this year Kalvin Doods of Moss and I talked about MGB FI kit. He said it not meant to be a performance upgrade and was originally design with emmisons in mind, however people have been going this route to increase reliabilty according to Kalvin, they even had a customer who put one on a MGA, and said his MGA never cranked and ran so smoothly ever before.
swift6
A local club member has adapted a Ford Tempo throttle body to the MGB single Zenith Manifold and runs it with a megasquirt computer. He's using this system in a rubber bumper BGT. So far he reports excellent driveability and reliability.
Nunyas
I think I saw pics of the RB B GT on the Mega Squirt site.
My dream engine would be a multiport injected crossflow head, with a crank triggered CDI ignition system (one coil for each plug). Or if Moss would bolt up their CFI injection onto the supercharger (still with the CDI ignition)... Then the 1800 B series engine would be brought into the new millenium. Twin cam would be nice too. No... wait... that's an Alfa /ubbthreads/images/graemlins/jester.gif
kyreb1862
kyreb1862
The system I had always thought of using was the Bosch CIS Injection. This was a type of mechanical injection. I always kind of thought this was more doable since there was a minimum of electronics involved. I think I'll visit my local auto salvage yard and gather up a few items and try this project this winter /ubbthreads/images/graemlins/grin.gif.
PC
I always thought the opposite. I never figured out how to go about matching the fuel delivery of a Bosch (K-Jetronic) mechanical CIS system to a given engine.
EFI using fully programmable ECU's like Megasquirt allow you to make adjustments to fuel delivery easily, instantly and, if you like, on the fly (on a dyno or even while driving around).
In the Bosch system the "black magic" happens inside the fuel distributor assembly and is further tweaked by a variety of parasitic gizmos. You can't just jack in your laptop and keystroke adjustments like an EFI. As far as I know you can't swap out sequential, incrementally calibrated bits like you can with Webers. I've never read a good description of how it's done by car manufacturers when they set up systems for different cars. I always assumed it meant trial and error machining on little fiddly bits.
PC.
TR_Jim MGB MGB Electronic Fuel Injection System MG 15
aeronca65t MGB Fuel Injection-MGB-homebuilt MG 5
Glennyboy MGB MGB Fuel Injection MG 5
Erica MGB Carburetion and MGB fuel economy. MG 0
wkilleffer MGB 1974 MGB SU fuel pump voltage issue MG 11
E MGB 1965 mgb fuel pump removal MG 2
P MGB Early MGB fuel tanks MG 4
Flash_Harry MGB MGB '74 B-GT with fuel problem - SOLVED [I think!] MG 4
O MGB 1975 MGB No Fuel to the filter MG 2
M MGB MGB fuel pump issue MG 17
G MGB Fuel sender '71 MGB MG 9
rggav MGB 65 MGB fuel filter MG 3
G MGB '71 MGB fuel pump MG 21
wkilleffer MGB Insulating MGB fuel lines MG 4
M MGB MGB fuel tank/ VIN number MG 5
S MGB-GT MGB GT ingition or fuel issue MG 1
Jayrz MGB Fuel Guage Inop, 64 MGB MG 3
C MGB Fuel guage '78 MGB MG 8
R6MGS MGB MGB Fuel backing up into charcoal canister MG 16
S MGB-GT MGB GT fuel problem MG 1
boxofparts MGB 79 MGB Fuel Level Sending Unit MG 6
tony barnhill Roll Cage & Fuel Cell in MGB GT Racing 10
Camshaft MGB-GT MGB/GT Fuel Problems MG 11
don62 MGB MGB 76 lack of power/fuel consumption MG 21
philman MGB mgb fuel guage MG 6
sonuvagunsmith MGB 72 MGB Fuel and temp guages MG 8
P MGB 1980 mgb fuel pump MG 3
R6MGS T-Series Late MGB fuel cut off switch MG 5
Bret MGB "Finally, A Fuel-Injected MGB" MG 18
M MGB 72 MGB Fuel Pump MG 5
P MGB 1979 MGB NEWBIE fuel tank replacement MG 7
8 MGB Locking Fuel cap for MGB MG 8
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 8
M MGB Ground polarity '67 MGB MG 2
M For Sale 1978 MGB MG Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
A Wanted 1970 MGB - Emissions Parts MG Classifieds 3
C MGB Re strapping a MGB seat bottom MG 2
Simmo MGB Re Engined MGB MG 4
Carlbanan56 MGB MGB rear break rebuild MG 6
C Wanted Early MGB soft top and/or tonneaus, condition not very important MG Classifieds 0
Carlbanan56 MGB Mgb turn signals MG 17
J MGB 1970 MGB Steering Lubrication MG 1
C Wanted Wanted: 1977 to 1980 MGB Dashboard MG Classifieds 0
L SOLD!! For Sale MGB Hardtop MG Classifieds 3
EvansClassicCars For Sale 1980 MGB for sale MG Classifieds 0
J MGB Tire pressure for 1980 MGB MG 14
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
I MGB Purchase of 1972 MGB Roadster MG 3
C MGB-GT MGB-GT Front Ride Height MG 0
