MGB Fuel sender '71 MGB
GaryBeu
Banned
Hi guys and gals:
I just got a new fuel sender from VB and hope to install it tomorrow. It has a rubber gasket and a locking ring to hold it in. Before I take the old one out I'd like to understand how the locking ring holds it. Any explaination assistance?? Thanks.
Gary
JPSmit
Gary, assuming it is the same as the Midget, it is just a friction fit, you tap out the old ring by essentially turning about 1/8 to the left, you tap in the new one same way. That's the easy part.
Not sure how big 'B tanks are, but, one of my "to do" jobs on Ms Triss is to drop the tank and bend the arm on the sender as it touches the bottom of the tank too soon. This means the car is empty and 1/4 tank. Also, make sure everything is well grounded and this is a PITA to do twice.
G
GaryBeu
Banned
Thanks JP...I'm not really sure what you mean by "tap out the old ring and tap in the new one" but I guess "tap" means the turning out and in...right? Then the sender sort of "attaches" to the ring?
JPSmit
The send goes in the hole, the ring covers it and slides under the notches on the tank. Think of it as how you take the top off a smoke detector, turn, and pull. It is essentially a friction fit.
G
GaryBeu
Banned
Thanks JP...it was easier than I expected. Just curious about one thing...any idea what the purpose of the little rubber gasket-looking thingy on the float is?
Platinum
Keeps the float from thumping/lying on the tank bottom, making noise and abrading the float.
G
GaryBeu
Banned
Thanks Doc...AND I now have a working fuel gauge !! This is great. Very simple install.
JPSmit
woo hoo, Gary has gas and he knows it!
G
GaryBeu
Banned
Ya...knowing you have gas (in a car !) is good.
DNK
Having a working gauge is no certainty of that.
See my post last month on my Wedge
FlyingCat Spitfire Fuel Sender Unit Triumph 2
JPSmit Fuel tank sender - how does it work? Spridgets 4
Healey Nut Fuel Sender Austin Healey 3
Lutz Kramer Fuel gauge and sender unit for BJ8 Austin Healey 2
J Fuel sender, fuel gauge 100 4 Austin Healey 6
sim fuel tank sender reading full all the time Spridgets 9
R Fuel sender internal wire Austin Healey 13
H TR2/3/3A Fuel sender or gauge? Triumph 8
L Fuel Tank sender 100/6 Austin Healey 8
S fuel sender Austin Healey 7
rjc157 Fuel tank sender Austin Healey 13
S Hot tip: seal for fuel tank sender Austin Healey 9
T TR2/3/3A fuel sender Triumph 12
J Orientation of sender in fuel tank Spridgets 2
T Fuel Gauge & Sender Unit Austin Healey 5
I Fuel sender unit testing Triumph 2
Jeepster New fuel sender unit Austin Healey 9
J Busted Fuel Tank Sender Unit Screws Austin Healey 7
M Fuel sender unit float leaks Triumph 8
martx-5 TR2/3/3A TR3 Fuel Sender From Moss Triumph 8
T TR6 Bolt size/thread count for fuel sender TR4/TR6 Triumph 16
pjsmetana Fuel Level Sender needed... Triumph 5
T How best to test a fuel sender off the car? Triumph 10
M Fuel Tank Sender? Triumph 2
Morris Fuel tank sender Spridgets 3
newmexTR3 fuel gauge/sender wiring Triumph 7
ncbugeye Can a Bugeye fuel tank sender be restored? Spridgets 7
NutmegCT TR2/3/3A fuel gauge / sender TR3A Triumph 25
Randy Harris Fuel sender gasket - replace w/full Tank? Austin Healey 8
healeynut Ebay Fuel Tank Sender Austin Healey 5
jhorton3 Fuel Gauge Sender Spridgets 4
T TR6 Repair or replace TR6 fuel level sender unit Triumph 4
G TR6 Fuel sender resistance for TR6 Triumph 1
A Fuel tank sender - direction to install? Austin Healey 3
dklawson TR4/4A TR4-TR4A Fuel Sender Resistance? Triumph 3
L Fuel sender specs... inaccurate gauge?? Spridgets 4
B Fuel Tank Sender Austin Healey 7
TypeRboy Fuel guage sender for Elans Lotus 0
R TR2/3/3A Fuel pump? Triumph 16
AndreL TR6 Conversion to electric fuel pump Triumph 14
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
A TR2/3/3A Those round fuel line clips Triumph 2
SherpaPilot TR6 Preping a New Fuel Tank Triumph 7
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
G MGB ugh.....the fuel gauge went to *** again! MG 8
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
J MGB Jet Tube to Float Chamber Fuel Leak MG 7
