    BCF is a resource offered at no cost to the Little British Car community. We do not require you to pay to play here. However, if you find BCF a useful resource, appreciate not having ads pop up all over the place and you want to ensure we can stay online - Please support the forum with an "optional" low-cost (less than many car club dues) annual upgrade. There are some benefits to upgrading!
Fuel tank sender - direction to install?
Andrew1
Hello gang.
I am replacing a defective fuel tank sender that was not providing proper resistance readings through the trvel of the unit's float.
I've been research all my sources and cannot find reference as to which direction in the tank the unit should be installed. Float facing the front, back side?
I honestly can't remember which way I took it off!
-Andrew-
Keoke
Re: fuek tank sender - direction to install?
HI Andrew, the arm and the float face the front of the car.---Fwiw---Keoke
Dave Russell
Yoda - R.I.P
Hi Andrew,
The experts say that the float should face the front. I have tried it both ways & the gage jumps around less with the float facing toward the back. This is likely because with the float closer to the fore - aft center of the tank, the fuel sloshes cause less level change at this location.
There is a procedure to adjust the magnetic shunts in the dash unit to get the overall calibration pretty close. Note that two good grounds are required, one at the sender & one at the gage. A bad ground at the gage can cause about 3/8 of the scale change. Start here & follow it through:
https://mgaguru.com/mgtech/electric/fg_01.htm
The MGA gage is the same as the AH gage.
when i bought my car may 12 05 [my birthday]fuel guage was crazy just flipped it around[float facing fwd]and it worked just fine,they all have a bit of a 'slosh factor'its not as stable as say your average chevy impala!
JPSmit Fuel tank sender - how does it work? Spridgets 4
sim fuel tank sender reading full all the time Spridgets 9
L Fuel Tank sender 100/6 Austin Healey 8
rjc157 Fuel tank sender Austin Healey 13
S Hot tip: seal for fuel tank sender Austin Healey 9
J Orientation of sender in fuel tank Spridgets 2
J Busted Fuel Tank Sender Unit Screws Austin Healey 7
M Fuel Tank Sender? Triumph 2
Morris Fuel tank sender Spridgets 3
ncbugeye Can a Bugeye fuel tank sender be restored? Spridgets 7
Randy Harris Fuel sender gasket - replace w/full Tank? Austin Healey 8
healeynut Ebay Fuel Tank Sender Austin Healey 5
B Fuel Tank Sender Austin Healey 7
SherpaPilot TR6 Preping a New Fuel Tank Triumph 7
Frameman 1949 New Moss Motors Fuel Tank Austin Healey 10
Editor_Reid Fuel Tank Interchangeability Austin Healey 2
BoyRacer Fuel Tank Sending Unit Austin Healey 3
B TR6 Fuel tank replacement Triumph 0
S Large capacity fuel tank Spridgets 1
MGTF1250Dave T-Series MG TF fuel line from tank to pump MG 3
JPSmit Fuel line - gas tank question Restoration & Tools 5
M TR2/3/3A Fuel Line Fitting at the Tank. Triumph 5
Ljohns New Midget/Sprite Fuel Tank Austin Healey Classifieds 1
Michael Oritt Fuel tank safety Austin Healey 18
BoyRacer Fuel tank sealing rubber is too thick Austin Healey 3
R Jensen-Healey Fuel Tank Questions Other British Cars 17
Martinld123 Fuel Tank Cap 100 BN2 Austin Healey 7
F Wanted 1960 Triumph TR3A fuel tank Triumph Classifieds 5
wkilleffer MGB Classic Gold fuel tank drain plug MG 12
SD Bugeye Half capacity of the fuel tank Spridgets 10
B TR2/3/3A Fuel Tank Venting Triumph 8
Zimmycobra For Sale Original 1966 TR4A Fuel Tank Triumph Classifieds 0
L T-Series TD Fuel Tank MG 2
NutmegCT Fuel tank cleaning/restoration Restoration & Tools 47
H Bugeye fuel tank sending unit - repair or replace Spridgets 5
Basil E-Type fuel tank mounting bolts [$&^##$%*!!] Jaguar 16
J Bugye Fuel Tank Leak Austin Healey 4
Basil About to re-install my fuel tank Series I E-Type Jaguar 6
Popeye TR4/4A Found this odd long bolt in my fuel tank... Does anyone know what it is? Triumph 17
T Wanted Jaguar MK2 fuel tank and Radiator Jaguar Classifieds 8
T TR4/4A Fuel tank venting Triumph 1
L 100/6 BN4 Fuel Tank feed Austin Healey 5
Popeye Engine starving for fuel before tank is empty - 2001 Audi TT Other Cars 5
T TR2/3/3A Late Fuel Tank in Pre-TS60000 TR3A Triumph 3
R Fuel tank straps Austin Healey 15
Got_All_4 TR2/3/3A Has anyone tried to rewind/fix a fuel tank sending unit? Triumph 11
Got_All_4 TR2/3/3A Fitting the trunk floor pad & fuel tank cover Triumph 2
K TR4/4A Fuel tank options Triumph 4
O TR2/3/3A Fuel tank vent Triumph 1
