Engine starving for fuel before tank is empty - 2001 Audi TT
Popeye
Bronze
Hi all,
My wife's car will not drive all the way to an empty gas tank. The engine will be fuel starved with about 1.2 gallons left in the tank. (Intermittent starvation)
The car is a base 2001 Audi TT (non-quattro, smaller engine). Same platform as the Mk 4 VW Golf. Fuel tank capacity is listed as 14.5 gallons. This morning after some hesitation on the freeway (talk about pucker factor), I filled up to 13.0 gallons when the fuel nozzle clicked off, then pumped a few more clicks to 13.3 gallons. I'm missing 1.2 gallons.
Most cars I can run all the way to essentially empty. A little history on the TT: the fuel gauge recently became a little wonky, i.e. it now reads empty with about 3 gallons of gas left in the tank (was previously accurate). Per an internet search, the reason for this is varnish on the sensor, so I've added fuel cleaner (Chevron Techron) to the past two fill-ups (and the reason why I want to drive it until most of the gas is out.)
Bottom line, I don't aim to drive the car until the last drop. But I am curious, why would the engine be fuel starved when the tank has a fair amount of gas left? Previously the car ran fine all the way to "empty". She has had the car since new, well-maintained. It is 15 years old and just shy of 40k miles. Is this the result of 15 year's crud accumulation in the tank?
Curious if folks here might know. I am posting on VWVortex as well, and will gladly share feedback.
JPSmit
No input on the Audi but, my last car, a Mazda 6 really would not let me drive past a quarter tank. I never really found out why but, I think, it was because there was no baffle in the tank and the gas would slosh away from the pump causing dry pumping for brief moments. I could carefully drive below 1/4 but it was just as easy - and likely better on the pump - to refill earlier. Just one of many things I came to hate about Mazda ownership.
Popeye
Popeye
Bronze
Thanks John-Peter.
From the VW / Audi forums, a theory is the fuel pump housing may be cracked, and sucking at a higher point in the fuel tank.
Sounds like I have a winter project!!
Deleted member 8987
No idea on Audi Doodies, but a whole lot of newer cars have two fuel pumps. The one in the tank is a "pusher", and the one outside the tank is a "puller".
We used to get cars into the shop all the time where they would quit or run ragged under 1/4 tank or so. The tank pump pushed the fuel to the frame pump...frame pump couldn't pull the "head" to get the bottom of the tank.
When is the last time you changed the fuel filter?
Popeye
Popeye
Bronze
Fuel filter is a great suggestion - was also on the VW Vortex site. I do not believe it has ever been changed... I am "Guilty!" with a capital G.
LarryK
Most fuel injection pumps are protected from running out of fuel. Makes for a hot pump and explosion. There is usually spare room for pump and area away from any sediment in the tank which is why you cannot completely empty tank. Not like the old carb tanks where you could run them out to see where the gauge reads. 2001 might be old enough for new pump.
mctriumph For Sale Tr7 engine Triumph Classifieds 2
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
CARSINC WANTED: 1275 Engine Spridgets 0
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
B Engine Stalls When Warmed Up Austin Healey 6
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
R For Sale 100 engine block w/head Austin Healey Classifieds 3
P General TR What color is original for engine parts? Triumph 7
AUSMHLY Clutch Stalls Engine Austin Healey 16
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
MikeAH100M High Temp Engine Miss Austin Healey 2
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
KVH General Tech Engine Misses Only at 2200 rpm Triumph 12
J For Sale Hoist and engine stand Triumph Classifieds 0
S TR2/3/3A engine and trans are stuck together pretty well Triumph 8
Carlbanan56 MGB No spark and engine cranking slow MG 10
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
tr6nitjulius General TR Waterless, easy/peasy, engine cleaning Triumph 2
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
D A distributer question on the 1275 engine. Spridgets 7
SherpaPilot TR6 Engine Mounting Question Triumph 3
KVH General Tech Loud Metallic Click Pop Every Time After Engine Off Triumph 11
AUSMHLY Engine Flush After Head Gasket Leak Austin Healey 19
Joel Lester TR2/3/3A Priming new engine with oil Triumph 9
BoyRacer Austin A90 mystery engine British Motor Corp 2
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
M General MG MG 1500 engine 4-91 or 4-110 MG 3
kodpkd 1961 BT7 engine oil Austin Healey 31
S TR2/3/3A engine removal Triumph 12
R TR2/3/3A Engine stalling and backfiring Triumph 25
M Engine ID Austin Healey 2
JMACENGINESHOP BJ7 Engine Rebuilding Austin Healey 23
KVH TR4/4A Engine Installation Triumph 28
P Spitfire Going up-Engine with my Herald Triumph 6
