Fuel Tank sender 100/6
Leew
I have just changed my fuel tank sender but it appears I have inadvertently bought and installed the sender for a BJ8 rather than for my BN4
However looking at the Moss pictures the sender for my BN4 looks exactly the same as the BJ8
Does anyone know what the difference may be?
Is it that the BJ8 tank is a lot bigger than the BN4 ( 2.6ltr engine vs 3 litre engine ) and therefore the BJ8 and BN4 although looking identical on the outside would be calibrated differently
Ta
Tank size is the same. Resistance of the senders is the same. The location of the terminal on sender is different from what I can tell.
Swopped out the sender yesterday for the correct model.....Craig you are right, but it is the float position that is reversed. On the early model car and sender the float faces to the rear of the car, on the BJ8 it faces forward
Float has to have room in the lowest part of the tank where the drain plug is. All the six cylinder tanks are the same, so the float position should be the same.
Bob
Bob
It's a mystery then...if the resistance is the same, the float faces the same way and it's just the position of the terminal then why did it not work properly in my BN4?
Bob
Do you have the sender grounded to the frame? I had to put in a small wire from one of the mounting screws to a screw on the front wall of the boot.
Yep me too John:
I took one look at that poor ground path back through the fuel line and added a short ground wire from the sender directly to the car's structure in the boot.
Does it work correctly now?
JPSmit Fuel tank sender - how does it work? Spridgets 4
sim fuel tank sender reading full all the time Spridgets 9
rjc157 Fuel tank sender Austin Healey 13
S Hot tip: seal for fuel tank sender Austin Healey 9
J Orientation of sender in fuel tank Spridgets 2
J Busted Fuel Tank Sender Unit Screws Austin Healey 7
M Fuel Tank Sender? Triumph 2
Morris Fuel tank sender Spridgets 3
ncbugeye Can a Bugeye fuel tank sender be restored? Spridgets 7
Randy Harris Fuel sender gasket - replace w/full Tank? Austin Healey 8
healeynut Ebay Fuel Tank Sender Austin Healey 5
A Fuel tank sender - direction to install? Austin Healey 3
B Fuel Tank Sender Austin Healey 7
SherpaPilot TR6 Preping a New Fuel Tank Triumph 7
Frameman 1949 New Moss Motors Fuel Tank Austin Healey 10
Editor_Reid Fuel Tank Interchangeability Austin Healey 2
BoyRacer Fuel Tank Sending Unit Austin Healey 3
B TR6 Fuel tank replacement Triumph 0
S Large capacity fuel tank Spridgets 1
MGTF1250Dave T-Series MG TF fuel line from tank to pump MG 3
JPSmit Fuel line - gas tank question Restoration & Tools 5
M TR2/3/3A Fuel Line Fitting at the Tank. Triumph 5
Ljohns New Midget/Sprite Fuel Tank Austin Healey Classifieds 1
Michael Oritt Fuel tank safety Austin Healey 18
BoyRacer Fuel tank sealing rubber is too thick Austin Healey 3
R Jensen-Healey Fuel Tank Questions Other British Cars 17
Martinld123 Fuel Tank Cap 100 BN2 Austin Healey 7
F Wanted 1960 Triumph TR3A fuel tank Triumph Classifieds 5
wkilleffer MGB Classic Gold fuel tank drain plug MG 12
SD Bugeye Half capacity of the fuel tank Spridgets 10
B TR2/3/3A Fuel Tank Venting Triumph 8
Zimmycobra For Sale Original 1966 TR4A Fuel Tank Triumph Classifieds 0
L T-Series TD Fuel Tank MG 2
NutmegCT Fuel tank cleaning/restoration Restoration & Tools 47
H Bugeye fuel tank sending unit - repair or replace Spridgets 5
Basil E-Type fuel tank mounting bolts [$&^##$%*!!] Jaguar 16
J Bugye Fuel Tank Leak Austin Healey 4
Basil About to re-install my fuel tank Series I E-Type Jaguar 6
Popeye TR4/4A Found this odd long bolt in my fuel tank... Does anyone know what it is? Triumph 17
T Wanted Jaguar MK2 fuel tank and Radiator Jaguar Classifieds 8
T TR4/4A Fuel tank venting Triumph 1
L 100/6 BN4 Fuel Tank feed Austin Healey 5
Popeye Engine starving for fuel before tank is empty - 2001 Audi TT Other Cars 5
T TR2/3/3A Late Fuel Tank in Pre-TS60000 TR3A Triumph 3
R Fuel tank straps Austin Healey 15
Got_All_4 TR2/3/3A Has anyone tried to rewind/fix a fuel tank sending unit? Triumph 11
Got_All_4 TR2/3/3A Fitting the trunk floor pad & fuel tank cover Triumph 2
K TR4/4A Fuel tank options Triumph 4
O TR2/3/3A Fuel tank vent Triumph 1
