Fuel injection system for Healeys now available!
Dave Russell
Yoda - R.I.P
With the stage one kit priced at over 4,200 GBP, I would certainly hope that it made "some" improvement. 10% torque increase is certainly beneficial.
However, I'm sure that your two inch carbs made a similar power increase at considerably less cost.
Dave Richards
wow, that was awesome, altough my employees didn't appreciate me watching an internet video at work!
M
Money_Pit
Dave
Almost makes the cost of an Aluminum head look reasonable. Would their be any benefit of changing heads with this system?
DT
Dave Russell
Yoda - R.I.P
Re: Fuel injection system for Healeys now availabl
Money_Pit said:
Dave,
DT
On the Sixes there would certainly be some benefit of optimum porting, valve sizes, guide materials, etc. Also better cooling if you wanted to raise the compression ratio a lot. I doubt if there would be THAT much benefit though on a more conservative engine. Possibly yes, if you are going for major engine power increases with the accompanying modifications.
The "bling" factor is hard to set a price on.
The reason that I used an aluminum head on the Four is that the original heads are very prone to cracking, have poor port layouts/flow, & a thin bottom deck. The aluminum head is the only practical way to overcome these major problems. Since I'm going for major rpm & power increases, the aluminum head is a necessity.
M
Money_Pit
Dave
I'll bet your hoping they'll just make a Fuel injected system for the Four? Somehow I think you wouldn't need it anyway as I'm sure you've got that engine of yours worked pretty good now!
DT
Dave Russell
Yoda - R.I.P
Fuel injection doesn't work very well on my cylinder head design, or any other four that has siamesed intake ports. Two cylinders sharing one port as many BMC engines do.
If the injector squirt is timed correctly for one of the pair of cylinders it is way off for the other shared cylinder. Two oddly timed squirts for the two cylinders on the same port doesn't help much. The mixture still gets all screwed up with one cylinder getting too much fuel & the other, not enough. A few folks have tried, but not much success.
Carbs give a premixed charge that doesn't have so many problems, although they still have some cylinder to cylinder charge differences.
Years ago, mid 80s maybe, Haltech introduced a stand alone fuel injection system with throttle bodies based on the Weber 45 DCOE footprint. PC-laptop programable software, high pressure pump & fuel rail.
All I'd have to do is unbolt the Webers...
Keoke
Volvo did it on the B20 Four clyinder engine and it works a treat Dave.---Keoke
Dave Russell
Yoda - R.I.P
Hi Keoke,
You overlooked my entire point. The B20 has four separate intake ports & would work fine with fuel injection, as will any of the engines with individual intake ports per cylinder.
Several of the BMC engines had siamesed intake ports - one port for two cylinders - & port type fuel injection does not work very well at all.
Throttle body injection will work because the fuel/air is already mixed before it gets to the siamesed intake ports. Of course I don't consider TBI to be much better than carbs & certainly harder to get the same power out of.
Keoke
Yes I understand that but Volvo put the injectors directly into the cylinder not in a manifold. The 164,6 cylinder, however, did use the throttle body set up.-Keoke
OK I see what you are saying now yeh we have separate intake ports in the head-Keoke- /bcforum/images/%%GRAEMLIN_URL%%/blush.gif
GregW
Over $9000 US to my door? 13%/11% horsepower/torque increase? No thank you. I’ll stick with my triple Mikunis. /bcforum/images/%%GRAEMLIN_URL%%/eek.gif
Keoke
Oooooh me too Greg! I was wondering about the Bling value of FI until I calculated the price in US$. Man I could think of all kinda things to do with that ~ 10K so I just Bling forgot it!!.---Keoke- /bcforum/images/%%GRAEMLIN_URL%%/laugh.gif
Ed_K
Moss has been selling some kind of supercharger / blower kit for some of the other LBCs. If one of these became available for big Healeys, how would the performance improve as compared to the $10,000 FI kit ? The price of the FI kit would certainly move it off of most people's radar in my opinion.
Dave Russell
Yoda - R.I.P
Hi Ed,
A blower would be kind of hard to just add to the already fairly high compression Sixes. I would guess that it could be done though.
Supercharged engines still require very accurate fuel management to get good power & not self destruct. Overall, not a project for the unwary.
I'm guessing that boost would need to be limited to less than 6 - 8 psi. Without intercooling, the power gain would probably be in the neighborhood of 20 - 30%.
With a lower compression ratio, charge cooling, & very good fuel management such as fuel injection, higher power gains would be available. Then you run up against mechanical strength limitations. In the end the cost would be quite high.
It seems to me that the cost and customized effort needed to put a supercharger or fuel injection onto a Healey are overkill given the basic design of the engine. I think if I wanted that much more performance the small V-8 nasty boy route would be the one to take, or even a more modern 6....
But I'm going to keep the Healey engine, and massage it a little (or a lot) when that time comes....
Dave Russell
Yoda - R.I.P
Been there, did the V8 thing a loooong time ago.
Dealing with engine compartment & passenger compartment heat is a MAJOR issue with a V8. As is finding places for the exhaust system.
Coyote1 Fuel Injection System on Craigslist Triumph 24
mgb4tim Wedge TR7 Fuel Injection/Charging system help. Triumph 2
TR_Jim MGB MGB Electronic Fuel Injection System MG 15
H Healey Fuel Injection System Austin Healey 10
F TR6 RATCO fuel injection Triumph 4
hondo402000 TR6 TR6 Fuel Injection made easy Triumph 12
6 General TR fuel injection Triumph 4
J Austin Healey 3000 Fuel Injection and Supercharged Austin Healey 4
Feathers Fuel Injection Other British Cars 6
M Fuel Injection Austin Healey 51
rjc157 Patton fuel injection Austin Healey 0
rjc157 Fuel Injection Austin Healey 7
S Wedge TR7 Fuel injection problem Triumph 3
Got_All_4 Wedge 1980 TR7 Fuel injection questions Triumph 17
K 1977 924 Fuel Injection Other Cars 6
JPSmit Fuel Injection for a B? MG 2
G Wedge TR8 Fuel Injection Triumph 7
G TR6 TR6 Fuel Injection ? Triumph 8
M Fuel Injection Problem on 87 XJ6 with 188,000 mile Jaguar 1
AUSMHLY Youtube, 63 BJ7 with electronic fuel injection Austin Healey 28
S Fuel injection cleaning Triumph 6
newmexTR3 TR2/3/3A TR3 Fuel Injection / Turbo project Latest Triumph 12
DanNagy TBI Fuel Injection Installation Triumph 23
T TR6 TR-6 Fuel Injection Manifold Triumph 8
PAUL161 MGB Fuel injection for MGBs. Added Photo MG 9
G Benefit of fuel injection Triumph 10
glemon 6 Cylinder Fuel Injection Conversion Triumph 22
Glen_B Bugeye Fuel Injection Spridgets 4
Sparkie Fuel Injection Help, please TVR 12
B Range Rover Electronic Fuel Injection Rover / Land Rover 0
mgb4tim Wedge TR7 Fuel Injection Pictures Triumph 1
SCguy Wedge TR8 fuel injection Triumph 5
I TR6 Fuel injection for TR6 Triumph 4
kyreb1862 MGB MGB Fuel Injection? MG 13
aeronca65t MGB Fuel Injection-MGB-homebuilt MG 5
TRdynamo Fuel injection Triumph 6
Morris TR6 TR6 Fuel Injection Triumph 21
aeronca65t Homebrew Fuel Injection Restoration & Tools 2
D Mini Fuel Injection British Motor Corp 11
Glennyboy MGB MGB Fuel Injection MG 5
H Fuel Injection on a Healey? Austin Healey 10
philip Carburetor or fuel injection? MG 7
W Fuel injection hose Restoration & Tools 2
MattP Fuel Injection Restoration & Tools 10
philman jetronics fuel injection Triumph 2
J XJ6 SII Fuel Injection- Convert to carbs or rebuild? Jaguar 6
K Fuel Injection? MG 6
R TR2/3/3A Fuel pump? Triumph 16
AndreL TR6 Conversion to electric fuel pump Triumph 14
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
