TR2/3/3A DOT5 brake fluid
2liter4cyl
Bronze
I saw a note from Rock Auto wherein Dot 5 must never used with ABS brakes. The rapid stroking makes foam. Only bad news. Another note, my brake lite switch failed and if Silicone was the problem, I opened the switch to find the diaphragm intact and functional. It is to press a brass disc against the back ends of the 2 terminals. It looked like it closed one but not both terminals. one about "dirty". One suggestion is an air bubble formed at switch and not enough pressure could be made. I spent $10 for a new switch and now all's well. Le T.
TR3driver
Great Pumpkin - R.I.P
An air bubble shouldn't keep the switch from working; even with the bubble, the pressure is the same throughout the system.
But many of us have had similar problems with the TR3 style switch. The "dirt" on the contacts appears to be burned brake fluid. Silicone has a reputation for "creeping", and it seems like somehow it manages to creep into the cavity where the contacts are.
Not everyone has the problem, so it probably varies from switch to switch; but I've had several failures of both original switches and replacements from several different sources (including one sold by FLAPS for an old Ford pickup truck). I eventually got frustrated and converted to a mechanically operated switch instead. Since I didn't like having it exposed under the hood on my previous TR3A, I put it under the dash on the TR3.
The switch shown did malfunction after a few years, mostly I think because I had a MC leak and some of the DOT 5 ran down the pedal and found it's way into the switch. But I replaced that with a TR6 type switch (which also fits Stags) from TRF, and it has been working fine ever since.
I've also heard rumors that there is a Harley Davidson motorcycle switch that will fit in place of the original TR3 switch, and stand up to DOT 5. But I've never investigated any further than that.
dklawson
The hydraulic switch problem is not unique to TRs. It seems to happen to a large number of people who convert their cars to DOT-5.
The Harley Davidson switch is mentioned a lot as a solid replacement. However, I have also seen a number of threads that warn that only the OEM Harley switch is "good" and that their aftermarket switches also fail.
Like Randall, on a couple of my cars I have made the change to a pedal actuated switch.
CJD
I converted 2 cars to DOT5. On one the switch began leaking within a month and got replaced. It never leaked again for 5 years until I sold the car. The second car...even older!...is on it's second year after the conversion with no issues with the original 1955 switch. I personally think this is like converting your engine to synthetic and having the seals all drip. If the switch was marginal to begin with, the silicone will kill it. If the switch is fully intact, it is not an issue.
Got_All_4 General TR Someone asked where to get DOT5 silicon brake fluid a while back Triumph 4
Scott_Hower DOT5 brake fluid leak FINALLY fixed ! MG 11
Geo Hahn General Tech Tip for DOT5 Users Triumph 9
T TR2/3/3A Napa dot5 ok Triumph 4
prb51 Conversion to DOT5 Triumph 20
M brake servo Austin Healey 0
B MGA Axle Brake line MG 0
6 Brake Fluid Spridgets 4
F Excessive Brake Pedal Travel Austin Healey 3
F Disc Brake Shimming Austin Healey 8
PDIGIO_6x3 TR6 BRAKE TUBING KITS Triumph 6
L Red Rubber Brake Grease Austin Healey 2
Martinld123 Emergency Brake Doesn't Release Austin Healey 9
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
M Brake Servo Austin Healey 2
J MGB BRAKE VALVE ? MG 11
G Brake Light Switch Failure Austin Healey 24
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
J TR2/3/3A Brake Line Flares Triumph 8
Frameman 1949 Brake Bleeding Austin Healey 0
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
L T-Series Another brake prob. ? MG 12
S TR2/3/3A brass fitting from a steel brake line Triumph 2
Sopwith_Camel MGB pulsing brake pedal MG 10
bighealeysource Front Brake Adjusters Austin Healey 0
SherpaPilot TR6 Brake Fluid in Servo? Triumph 0
TAS525 TR2/3/3A Thoughts on Brake Pads Triumph 12
Gundog61 BN2 Brake Drums Austin Healey 5
KVH General TR Rear Brake Shoe Orientation Triumph 12
R TR6 Help: Brake Part Source or …. ? Triumph 1
mezy vauxhll brake pipes Other British Cars 0
KVH General Tech TR4A Brake Bleeding Triumph 5
R Brake Adjustment Spridgets 2
Walter74 Brake Servo Location Austin Healey 6
A 100-6 Brake Lights Austin Healey 2
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
prb51 Girling Brake Fluid Reservoir Cap Austin Healey 6
KVH General Tech Brake Fluid Triumph 5
Lin Brake/Clutch Fluid Austin Healey 11
AUSMHLY Castrol DOT4 Brake Fluid Austin Healey 6
bighealeysource Brake Master Cylinder Austin Healey 27
