Desperately Need a Pair of Hood Stays for Bugeye
Mike_in_CA
I knew when i bought my Bugeye that the hood stays that hold up hodd while working under it were missing. I figured i would just convert to front tilt. Now after looking at it closer, i find that all the front support box on the front of the bonnet are gone. It was probably hit in the front and they just removed it. So there is nothing to hold open the bonnet and it can not be converted. Right now i am just using a piece of wood, but all that would have to ahppen is it slips out while i am under it and i am going to loose my head. So if anyone that has conveerted to front tilt still has their hood stays and would be willing to sell them, PLEASE let me know.
Thanks
Mike
Jim_Gruber
Mike,
On my BE Front end most of that was rusted out. I rebuilt, reinforced, and reengineered to make fit. A little time with a MIG and in my case time with pop rivet gun, angle iron, a saw, Dremel tool, and a drill and it bcame fully servicable.
The early '58 sprites did not have the box duct work. I made my own.
M
Mike_in_CA
Well I let a friend know I was looking for the stays and he has the pair he removed for the front tilt conversion. I am picking them up tomorrow. I could weld in a new shroud box, but it would ruin the paint and it is just too nice to have it repainted at this point. On a possible note. I unexpectedly won a car on Ebay yesterday. It is a 65' Sunbeam Alpine. So the wife is giving me the word that one or the other has to go. Depending on the condition of the Alpine, I may decide to let the Bugeye go. If anyone is interested, let me know. It is a 59' with a 1098 and a rib case trans. It runs good and looks good, but needs a bit of love. I was planning on using it as a daily driver while slowly sprucing it up, but I can afford to do that with two cars, so one will have to go. The seats are useable, but need to be recovered. Dash has newer tach and speedo, but stock otherwise. I also have a set of front disc brakes for it as well. I have $5100 into it and would be willing to let it go for that or best offer. Body is straight. Contact me for more info.
Mike
L Engine build problems. Desperately need help :,[ Spridgets 34
356roadster BN1: Reverse gear plunger desperately needed Austin Healey 4
N Desperately seeking service - Long Island/NYC Jaguar 2
G Desperately seeking sympathy... Triumph 14
tr6web TR6 Need advice removing downpipe nuts Triumph 4
giwplay1 Everything you need to know before purchasing an Austin Healey Austin Healey 15
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
K TR2/3/3A Does this fitting need a Whitworth wrench? Triumph 10
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
Gliderman8 TR6 Now I really know why I need new shocks Triumph 11
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
W Need advice on installing new side curtain glass Spridgets 1
AngliaGT General TR You Might Need Snow Tires for This - Drive Your Triumph Day 2023 Triumph 5
M Wanted Need 59 Bugeye Dashboard. LHD. Spridgets Classified 1
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
K TR6 Need help with Mimosa Yellow Paint Triumph 1
T Storing nuts and bolts (so you can find what you need) Austin Healey 7
AngliaGT Need Ideas on Selling Our Midget Spridgets 10
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
drooartz MGB OD question - need to warm up? MG 8
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 1
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
shadowfever Wanted Need a Sprite Mk II bonnet Spridgets Classified 1
jackq Wanted Need a C Tach MG Classifieds 2
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
apbos New/Old wheels for my Speedwell Sprite. Need Center Caps Spridgets 13
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
AngliaGT I Need to Resist - 1980 Ford Fiesta Other Cars 9
vette Need BugEye Generator Austin Healey 7
vette Need BugEye Generator Spridgets 4
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
J TR2/3/3A Need help with pivot and body bracket for hood Triumph 2
Madflyer For Sale Triumph GT 6 parting out need something Triumph Classifieds 10
KiwiStagguy Re building my power steering 71 Stag . Rust and pitting bad . Need a business name to fix it Triumph Classifieds 0
tinman58 TR2/3/3A Need super charger!! Triumph 7
B Wanted I need a small section of a bugeye bonnet Spridgets Classified 5
volunteer Wanted Need Door Seals, Vent Window Seals and Trunk Seal for Daimler ds420 Limo Jaguar Classifieds 23
Got_All_4 TR5/TR250 Need guidance for replacing steering column bushings Triumph 11
John Turney Need a Better Demister? Austin Healey 5
K TR2/3/3A Need advice on what my TR3A might be worth..... Triumph 10
69MGC MGC Need one MGB/C Splined Hub MG 1
69MGC Wanted Need one MGB/C Splined Hub MG Classifieds 4
Gliderman8 General TR Need clarification on Triumph Competition Preparation Manual TR250 TR5 TR6 Triumph 4
S TR6 Need wisdom on tr6 brake calipers Triumph 6
J MGB Need help identifying these parts MG 6
S TR2/3/3A Need New Battery for TR3A Triumph 9
B MGB-GT Need help with MGB GT rattle MG 0
