Brake swap
algot1901
Bronze
I know this is a really long shot, what cars that have the juice brakes would swap over to the Prefect or Anglia
Bayless
Mine all came from a '58 Prefect, everything, pedals and all. Biggest problem was the 13 inch wheels. Solved that with a set of TR3 wheels. This was in the mid '60s so VW tirees fit and were readily available at a reasonable price. They were also almost exactly the same rolling diameter as the original tires so speedo got right again. The '48 bearings fit the drums. I had to make adapters for the new wheels. It also needed a spacer behind the rear backing plates. Completely happy with the end result. I also converted the clutch to hydraulic to use the new swing pedal like the brakes.
algot1901
algot1901
Bronze
I just heard back from angliabrokers.com and was told there is really no advantage as long as you keep the cable adjusted and I have no idea where I would find a 58 model in the states I thank you for the help.
Bayless
Keeping the mechanicals is certainly the easier way. And they can be made to work but it is not trivial. We drove it a couple of years with the original system. Also, adjustment is an on-going function. I did try first just to convert the originals to hydraulic by replacing the internal expanders with cylinders and matching master from some salvage yard car, a '50s Dodge if I remember right. It did work but was not an improvement. that's when I went for the later Prefect and replaced the whole system.
algot1901
algot1901
Bronze
Help again for rear axle half shaft seal, #4050
(half shaft oil seal, locates halfway along the half shaft inside the axle casing, dimensions approx :- o/d 43.65mm, i/d 23.65mm, thickness 10.90mm)
For the life of me, I cannot come up with anything Stateside
On a better note, I have found the wheel bearings locally and upon further inspection, (removal) they look in really nice shape. The seals are another story as the front wheels do not use a seal they have some kind of stamped metal holder so the grease as it works its way to the inside will fall off into this tray of sorts
Bayless
Glad to hear you found the bearings, and locally even better. I can't help you though on that #4050. I see it on the parts diagram but I've never had my axles out and they have never leaked. How did you happen to find the seal? Did you remove the axle? What sort of seal is it? Also on the front seals, since changing drums I have always wanted to look for a proper seal and I'm sure one can be found. The bottom line though is what it has just works and doesn't seem to leak. I know it doesn't look right but I have put around 30k miles on them.
algot1901
algot1901
Bronze
I do not have my axle apart how I found out about the leaky seal is when I jacked up the right side I get a puddle of axle grease on the wheel dolly and this does not happen on the right side when the left is jacked up.
Bayless
That's interesting Jim. Now I wonder where that thing actually is and how you go about getting to it and what holds it in. I had the rear drums off recently exposing the bearings but didn't know of that seal at the time. I wonder if it is just inside the bearings. Are you changing the rear bearings as well or just the fronts?
algot1901
algot1901
Bronze
The seal is on the inside of the diff or right there in that area, you have to remove the gears to get to it.
Bayless
Ouch, that sounds like a big job.
algot1901
algot1901
Bronze
I have a few other items to do but it does not look like a big job unbolt the radius rods disconnect the tube and springs open the diff and the seal is right there. If this was a repair for a customer I would be looking at a couple of hours but I am just a hobbyist trying to go broke so a couple days.
Cheerio
Jimj
Bayless
Does your diff open on both sides? Mine doesn't.
M_and_P Brake Swap Spridgets 2
tr7andtvr Wedge TR7 Range Rover Master Brake Cylinder Swap? Triumph 1
B MGA Axle Brake line MG 0
6 Brake Fluid Spridgets 4
F Excessive Brake Pedal Travel Austin Healey 3
F Disc Brake Shimming Austin Healey 8
PDIGIO_6x3 TR6 BRAKE TUBING KITS Triumph 6
L Red Rubber Brake Grease Austin Healey 2
Martinld123 Emergency Brake Doesn't Release Austin Healey 9
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
M Brake Servo Austin Healey 2
J MGB BRAKE VALVE ? MG 11
G Brake Light Switch Failure Austin Healey 24
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
J TR2/3/3A Brake Line Flares Triumph 8
Frameman 1949 Brake Bleeding Austin Healey 0
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
L T-Series Another brake prob. ? MG 12
S TR2/3/3A brass fitting from a steel brake line Triumph 2
Sopwith_Camel MGB pulsing brake pedal MG 10
bighealeysource Front Brake Adjusters Austin Healey 0
SherpaPilot TR6 Brake Fluid in Servo? Triumph 0
TAS525 TR2/3/3A Thoughts on Brake Pads Triumph 12
Gundog61 BN2 Brake Drums Austin Healey 5
KVH General TR Rear Brake Shoe Orientation Triumph 12
R TR6 Help: Brake Part Source or …. ? Triumph 1
mezy vauxhll brake pipes Other British Cars 0
KVH General Tech TR4A Brake Bleeding Triumph 5
R Brake Adjustment Spridgets 2
Walter74 Brake Servo Location Austin Healey 6
A 100-6 Brake Lights Austin Healey 2
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
prb51 Girling Brake Fluid Reservoir Cap Austin Healey 6
KVH General Tech Brake Fluid Triumph 5
Lin Brake/Clutch Fluid Austin Healey 11
AUSMHLY Castrol DOT4 Brake Fluid Austin Healey 6
bighealeysource Brake Master Cylinder Austin Healey 27
S TR2/3/3A Lockheed brake system Triumph 7
kodpkd Disc Brake Pad Installation Austin Healey 11
BN6_L1232 Rear Disc Brake Installation Instructions Austin Healey 3
TomMull TR2/3/3A Parking brake: Lesson learned? Triumph 8
