Brake Fluid
I have been unable to find Castrol LMA brake fluid anywhere. I have always used it and now my problem is what to use, Dot 3 or 4? I know they are compatible/comparable. If they are the same, why make two types? I bought some Dot 3 as it is on sale but can exchange it.
dklawson
Re: brake fluid
I am sure there are lots of threads discussing this but I'll provide a fast and loose explanation. Others will correct and expand as necessary.
DOT-3 and DOT-4 are similar but different types of brake fluid (chemical composition, boiling point, etc.) DOT-3 has been used for decades in American cars and is fully compatible with those old American car brake seals. DOT-4, particularly the LMA (low moisture absorption) formula was used in British cars (among others). American cars had brake systems made of a particular type of rubber that was compatible with DOT-3. British cars used seals made of natural rubber and those seals were only compatible with DOT-4. So, American cars typically used DOT-3 and British cars used DOT-4.
Sometime in the 1970s British braking systems started using different sealing materials which were compatible with both DOT-3 and DOT-4. New hydraulic parts and rebuild kits started using the different sealing material. Since that time, later British cars could use either fluid.
What remains is a risk factor. If you do not know your car's brake history (what has been rebuilt and/or replaced) stick with the DOT-4 fluid. DOT-4 will work with new seals and older ones made of natural rubber. If on the other hand you know that ALL the brake seals and rubber parts are new or have been replaced since the 1980s (seals, flex lines, PDWA, proportioning valve internal bits...) then use either brake fluid. You do not have to use the LMA formulation if you want to stick with DOT-4. Just change your brake fluid regularly which you should be doing anyway.
John Turney
Re: brake fluid
And if your brake system hasn't been rebuilt since the 1980's (30 to 40 years ago), it's overdue.
Keoke
6 Brake Fluid Spridgets 4
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
SherpaPilot TR6 Brake Fluid in Servo? Triumph 0
prb51 Girling Brake Fluid Reservoir Cap Austin Healey 6
KVH General Tech Brake Fluid Triumph 5
Lin Brake/Clutch Fluid Austin Healey 11
AUSMHLY Castrol DOT4 Brake Fluid Austin Healey 6
craigshealey3000 Castrol Girling Amber Brake Fluid vs. Silicone Austin Healey 14
P TR6 Brake fluid leak? Triumph 6
F Girling Brake Fluid Reservoirs Leaking Austin Healey 12
D TR2/3/3A Why it is important to change brake fluid Triumph 4
D TR2/3/3A Brake fluid identification by colour. Triumph 4
R TR2/3/3A DOT 5 Brake Fluid Triumph 5
Martinld123 Brake Fluid Austin Healey 49
Bayless Brake fluid recommendations Restoration & Tools 6
fpstude TR4/4A Brake / Clutch Fluid for TR-4A Triumph 8
C DOT 5 Silicone-Based Brake Fluid Austin Healey 10
KVH General TR Dot 4 Brake Fluid Triumph 7
NutmegCT Brake fluid - flush and replace. Why? Restoration & Tools 8
2 TR2/3/3A DOT5 brake fluid Triumph 3
Got_All_4 General TR Someone asked where to get DOT5 silicon brake fluid a while back Triumph 4
M Brake fluid on tire - cylinder need replaced? Spridgets 19
B General MG Brake fluid MG 7
R TR2/3/3A Brake Fluid Triumph 6
glemon General Tech Follow up on Master Cylinder and Brake Fluid Triumph 11
G Brake fluid missing Austin Healey 6
Joe Schlosser Brake Fluid Spridgets 5
steveg Silicone brake fluid conversion - existing system Austin Healey 41
simon1966 Brake fluid Canister on a RHD 100 Austin Healey 10
Rut Brake fluid Spridgets 11
M TR2/3/3A Intermix of Silicone and Dot 3 brake fluid Triumph 7
L 100/6 BN4 Brake fluid Austin Healey 17
M Losing Brake Fluid Austin Healey 8
H Adviced asked on unscrewing lid brake fluid reservoir Austin Healey 9
petnatcar BRAKE FLUID CONTAINER for BT7 Austin Healey 0
GTP1960 TR2/3/3A Recommended brake fluid for a 3A? Triumph 16
F Replacing brake master cylinder, fluid reservoir and flexible brake pipes - order? Austin Healey 4
tomshobby brake fluid leak? Spridgets 1
S Clutch Fluid / Brake Fluid consumption Spridgets 3
B TR2/3/3A Gaskets for Brake/Clutch Fluid Reservoir? Triumph 15
C Brake fluid? Austin Healey 10
C TR6 TR6 with dot 5 brake fluid Triumph 8
K TR2/3/3A TR3 brake fluid reservoir outlet at the bottom..... Triumph 0
DNK Copper in Brake Fluid Other Cars 2
PatGalvin TR2/3/3A Brake Master Cylinder Fluid Reservoir Bracket needed, TR3A Triumph 6
Crankshaft TR2/3/3A Brake/Clutch fluid question Triumph 6
nevets Replacing the brake/clutch fluid reservoir Austin Healey 21
vette Silicone DOT-5 Brake & Clutch Fluid Austin Healey 17
Jim_Newman brake/clutch fluid reservoir Austin Healey 4
K Synthetic brake fluid again? Triumph 3
