TR2/3/3A Brake fluid identification by colour.
DavidApp
On the TR3B I a working on for a friend I plan to replace the brake fluid but he was not sure what is in it. I sucked a littlr out and it looks clear with a slight green tint. DOT3?
It needs a new Clutch MC. as the old one does nothing. The clutch peddle just hangs lose and the MC is stuck in.
David
Graham H
I only use dot 3 and it has a green tint, I don't know what colour dot 4 is and I believe they should not be mixed.
Graham
auprichard
If you are still not sure, mix a little of the brake fluid with an equal amount of water. If it is DOT 3 or 4 the two will mix: is it is DOT 5 they will separate. DOT 5 is usually purple, but not always. And I believe you can mix 3 and 4 - it is just their boiling points which differ.
mctriumph
You are all quite bonkers!! Dot 3 will rot the seals quickly I suggest Castrol LMA dot 4 synthetic .
Always flush out an old system of unknow fluid , any signs of problems with master/slaves is
cause for a complete overhaul!!! For safety sake.
MD(mad dog)
6 Brake Fluid Spridgets 4
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
SherpaPilot TR6 Brake Fluid in Servo? Triumph 0
prb51 Girling Brake Fluid Reservoir Cap Austin Healey 6
KVH General Tech Brake Fluid Triumph 5
Lin Brake/Clutch Fluid Austin Healey 11
AUSMHLY Castrol DOT4 Brake Fluid Austin Healey 6
craigshealey3000 Castrol Girling Amber Brake Fluid vs. Silicone Austin Healey 14
P TR6 Brake fluid leak? Triumph 6
F Girling Brake Fluid Reservoirs Leaking Austin Healey 12
D TR2/3/3A Why it is important to change brake fluid Triumph 4
R TR2/3/3A DOT 5 Brake Fluid Triumph 5
Martinld123 Brake Fluid Austin Healey 49
Bayless Brake fluid recommendations Restoration & Tools 6
fpstude TR4/4A Brake / Clutch Fluid for TR-4A Triumph 8
C DOT 5 Silicone-Based Brake Fluid Austin Healey 10
KVH General TR Dot 4 Brake Fluid Triumph 7
NutmegCT Brake fluid - flush and replace. Why? Restoration & Tools 8
tahoe healey Brake Fluid Austin Healey 6
2 TR2/3/3A DOT5 brake fluid Triumph 3
Got_All_4 General TR Someone asked where to get DOT5 silicon brake fluid a while back Triumph 4
M Brake fluid on tire - cylinder need replaced? Spridgets 19
B General MG Brake fluid MG 7
R TR2/3/3A Brake Fluid Triumph 6
glemon General Tech Follow up on Master Cylinder and Brake Fluid Triumph 11
G Brake fluid missing Austin Healey 6
Joe Schlosser Brake Fluid Spridgets 5
steveg Silicone brake fluid conversion - existing system Austin Healey 41
simon1966 Brake fluid Canister on a RHD 100 Austin Healey 10
Rut Brake fluid Spridgets 11
M TR2/3/3A Intermix of Silicone and Dot 3 brake fluid Triumph 7
L 100/6 BN4 Brake fluid Austin Healey 17
M Losing Brake Fluid Austin Healey 8
H Adviced asked on unscrewing lid brake fluid reservoir Austin Healey 9
petnatcar BRAKE FLUID CONTAINER for BT7 Austin Healey 0
GTP1960 TR2/3/3A Recommended brake fluid for a 3A? Triumph 16
F Replacing brake master cylinder, fluid reservoir and flexible brake pipes - order? Austin Healey 4
tomshobby brake fluid leak? Spridgets 1
S Clutch Fluid / Brake Fluid consumption Spridgets 3
B TR2/3/3A Gaskets for Brake/Clutch Fluid Reservoir? Triumph 15
C Brake fluid? Austin Healey 10
C TR6 TR6 with dot 5 brake fluid Triumph 8
K TR2/3/3A TR3 brake fluid reservoir outlet at the bottom..... Triumph 0
DNK Copper in Brake Fluid Other Cars 2
PatGalvin TR2/3/3A Brake Master Cylinder Fluid Reservoir Bracket needed, TR3A Triumph 6
Crankshaft TR2/3/3A Brake/Clutch fluid question Triumph 6
nevets Replacing the brake/clutch fluid reservoir Austin Healey 21
vette Silicone DOT-5 Brake & Clutch Fluid Austin Healey 17
Jim_Newman brake/clutch fluid reservoir Austin Healey 4
K Synthetic brake fluid again? Triumph 3
