M
Member 17500
I'm losing brake fluid in my 1966 Austin Healey 3000, but can find no leaks anywhere. I checked all pipes, hoses, junctions, master cylinder, reservoir, calipers, rear brake pistons, and servo. All dry. The car has a replacement Lockheed booster. Thinking that fluid may be being sucked from a leaky booster into the intake manifold, I rebuilt the entire booster. No change. I've read that white smoke is a sign of burning brake fluid, but my car had whitish exhaust (probably incomplete combustion or water vapor) long before this problem appeared. So that's not much help.
Any advice, assistance, or recommendations would be greatly appreciated.
Thank you!
Thank you!
