Spitfire Spitfire losing power
tomgt6
I have a mk 3 early 1300 spitfire engine.
It starts great, runs great for about 10 miles and then starts to lose power.
If I give it more pedal I don't get any more power, feather the pedal and no more power.
What should I be looking at? or what do you think could be causing the issue?
Well, just off the top of my head, I'd think the fuel pump may be failing. Can't keep the bowls filled.
Could also be a failing ignition condenser and/or coil. As they heat up, the spark gets weaker.
My two cents.
Tom
Make sure you don't have a suction leak in the fuel line before the pump! At idle it'll fill the carbs, but on acceleration, not enough fuel will be supplied. I wonder how I know that! A shielded flex line on our car had a very small crack in the rubber and the car did exactly the same thing as yours. It would run great for a couple miles and then slowly die. PJ
Tom I had that happen on a 65 Spit that I used to own. It started just after I filled the gas tank. It turned out to be a bad batch of gas that had water or something in it. After trying about everything I could think of I ended up removing the gas tank and flushing it out. That took care of the problem.
Open the gas cap and see if the engine will pick up power.
+1 on opening the gas filler cap as a test.
Also, when this power loss starts, what is the tachometer doing?
EDIT: Nevermind the tach. I forgot you said this is a Mk3 and therefore it will have a cable driven tach. I was thinking of the later cars with electronic tachs. You can see symptoms of some ignition related problems in the behavior of an electronic tach.
I'd go the fuel, condenser, coil route. I had a similar problem a couple of years ago with a MKIV. Turned out to be the condenser. Good luck.
Here is what I have tried:
1. Fuel filter and gas cap open (mk 1 gas tank)
2. Switched out fuel pump
3. Traded coil out for another one
I guess the next item I will try is the condenser. Thanks for the help.
C Wanted Spitfire 1500 diff rebuild Triumph Classifieds 0
L Spitfire New Acquisition, 1976 Spitfire Triumph 5
motzart007 Wanted In search of used seats for 1969 Triumph Spitfire MKIII Triumph Classifieds 1
B For Sale GT6/Spitfire License Plate Light Assembly Triumph Classifieds 0
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
A Spitfire Spitfire Diff Pinion Seal? Triumph 2
3798j General TR Spitfire up in the Tree Triumph 2
E Spitfire '69 Spitfire hard top Triumph 2
D For Sale 1966 Spitfire 4 MK 2 for sale, Triumph Classifieds 1
R For Sale Spitfire MKIII projects Triumph Classifieds 0
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
G Spitfire Spitfire 1500 differential whining Triumph 6
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
A Spitfire Spitfire Fuel pump issues Triumph 5
P Spitfire 1979 Triumph Spitfire starts then runs rough Triumph 2
Lairhead52 Wanted 78 Spitfire instrument panel lights / lenses Triumph Classifieds 3
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
W Spitfire 1975 Spitfire 1500 shifting problems when hot Triumph 8
K Spitfire 1978 Spitfire possible Vapor Lock? Triumph 16
R Spitfire Turn signal wiring Spitfire Triumph 5
S Spitfire Spitfire 1296 engines Triumph 1
D Wanted WTB: Late Triumph Spitfire Top Frame Triumph Classifieds 8
C Spitfire 1967 Triumph Spitfire Triumph 2
Dnickels Spitfire Spitfire mk2 front suspension too soft Triumph 2
T For Sale One Owner 1969 Spitfire for sale Triumph Classifieds 0
Dnickels Spitfire Spitfire lighting issues Triumph 4
SteveTheBrewer Spitfire Spitfire Rebuild Update Triumph 5
Basil Spitfire 74 Spitfire Barn Find Triumph 1
I Spitfire Triumph Spitfire 1500 refuses to awake after 10 year hibernation Triumph 6
I Spitfire spitfire 1500 refuses to awake after 10 years Triumph 2
B Spitfire Mk3 seat rails Triumph Classifieds 0
M Spitfire 1500 LH Door Triumph Classifieds 0
P Spitfire Bits Triumph Classifieds 1
M 1976 Spitfire 1500 (RHD) Triumph Classifieds 2
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
FlyingCat Wanted 1980 Spitfire Rear Bumper Triumph Classifieds 2
SteveTheBrewer Spitfire Triumph Spitfire Restoration Blog Triumph 22
R Spitfire Spitfire 1500 Triumph 3
T Spitfire Spitfire lights Triumph 7
Basil Spitfire How do I adjust SU carbs on my Spitfire? Triumph 5
F Spitfire No output from coil HELP!! 1972 Spitfire 1.3L Accusspark Triumph 19
glemon Spitfire Spitfire Questions Triumph 7
tr6nitjulius General TR TR6*8 TR4*2 GT6 Spitfire Triumph 2
J For Sale 1974 Spitfire for sale Triumph Classifieds 0
F Spitfire Triumph Spitfire , what fuel to run Her on with no engine history? Triumph 11
J Spitfire 1979 Spitfire Running rough [sputtering, exhaust poping] at start up Triumph 2
eschneider Spitfire Float height - '64 spitfire w/ dual HS2 Triumph 1
S For Sale Triumph Spitfire Workshop Manual on CD/ROM - 1962 - 1978 Triumph Classifieds 0
