General MG Brake fluid
Bob Branson
Member
We all know what DOT3 brake fluid does to the live rubber seals originally used in BMC cars. While I'm still a good while from needing brakes, I'm wondering if the new rebuild kits and after-market wheel and master cylinders still use live rubber (not likely, methinks.) And if they use the synthetic stuff like American cars, is brake fluid still even an issue? I know Gastrol Girling Crimson is extinct, and I seem to remember reading that the silicone fluid is an acceptable replacement. I just don't want to ruin the new parts I have yet to buy. TIA
dklawson
You will find tons and tons of threads on this board and others discussing the pros and cons of silicone (DOT-5) brake fluid. I won't be the one to open that discussion in this thread.
In response to your direct/initial inquiry, it is my understanding that rubber used on British cars or rebuild seals/components since the mid- to late-1960s is compatible with DOT-3 and DOT-4. However, for 100% compatibility you should replace all the rubber bits (including flex hoses, all cylinder seals, servo internals, and PDWA seals).
JPSmit
As mentioned, there are many conversations and few conclusions on this topic. FWIW I use DOT-5 and have been pleased. The rubber is fine. The issue I had is that DOT-5 is very viscous and was "sliding" past the seals. If you go the DOT route - go to the store and shake all the cans and buy the thickest you can get.
Grantura_MKI
NOT a good practice......ok, let's fill the fluid with air bubbles! Should make for easy bleeding of the system????
dklawson
You are correct. You don't want to shake the bottle right before bleeding the brakes. However, letting the bottle sit undisturbed over night is sufficient to get the bubbles back out.
I personally have had no problem with seal leakage with any of the DOT-5 I have used. Until recently I bought Cartel brand fluid from Moss. The last time I bought I opted for a quart sold by a guy on eBay who was selling discount military grade DOT-5. It was almost identical to Cartel in appearance and thickness.
bobhustead
Wouldn't Boyles law or some similar principle drive the bubbles out of the fluid rather quickly on applying pedal pressure?Bob
dklawson
No. Boyle's Law won't drive the gas bubbles out. However, it does describe what happens with the bubbles.
If there are bubbles in the fluid and you apply pressure, the bubbles collapse giving the pedal the "springy" feel (high pressure = low volume). When pedal pressure is removed, the bubbles return to their normal size (low pressure = higher volume) The process repeats next time you apply brake pressure.
That's why it is very important with DOT-5 fluid to avoid bubbles as much as possible.
6 Brake Fluid Spridgets 4
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
SherpaPilot TR6 Brake Fluid in Servo? Triumph 0
prb51 Girling Brake Fluid Reservoir Cap Austin Healey 6
KVH General Tech Brake Fluid Triumph 5
Lin Brake/Clutch Fluid Austin Healey 11
AUSMHLY Castrol DOT4 Brake Fluid Austin Healey 6
craigshealey3000 Castrol Girling Amber Brake Fluid vs. Silicone Austin Healey 14
P TR6 Brake fluid leak? Triumph 6
F Girling Brake Fluid Reservoirs Leaking Austin Healey 12
D TR2/3/3A Why it is important to change brake fluid Triumph 4
D TR2/3/3A Brake fluid identification by colour. Triumph 4
R TR2/3/3A DOT 5 Brake Fluid Triumph 5
Martinld123 Brake Fluid Austin Healey 49
Bayless Brake fluid recommendations Restoration & Tools 6
fpstude TR4/4A Brake / Clutch Fluid for TR-4A Triumph 8
C DOT 5 Silicone-Based Brake Fluid Austin Healey 10
KVH General TR Dot 4 Brake Fluid Triumph 7
NutmegCT Brake fluid - flush and replace. Why? Restoration & Tools 8
tahoe healey Brake Fluid Austin Healey 6
2 TR2/3/3A DOT5 brake fluid Triumph 3
Got_All_4 General TR Someone asked where to get DOT5 silicon brake fluid a while back Triumph 4
M Brake fluid on tire - cylinder need replaced? Spridgets 19
R TR2/3/3A Brake Fluid Triumph 6
glemon General Tech Follow up on Master Cylinder and Brake Fluid Triumph 11
G Brake fluid missing Austin Healey 6
Joe Schlosser Brake Fluid Spridgets 5
steveg Silicone brake fluid conversion - existing system Austin Healey 41
simon1966 Brake fluid Canister on a RHD 100 Austin Healey 10
Rut Brake fluid Spridgets 11
M TR2/3/3A Intermix of Silicone and Dot 3 brake fluid Triumph 7
L 100/6 BN4 Brake fluid Austin Healey 17
M Losing Brake Fluid Austin Healey 8
H Adviced asked on unscrewing lid brake fluid reservoir Austin Healey 9
petnatcar BRAKE FLUID CONTAINER for BT7 Austin Healey 0
GTP1960 TR2/3/3A Recommended brake fluid for a 3A? Triumph 16
F Replacing brake master cylinder, fluid reservoir and flexible brake pipes - order? Austin Healey 4
tomshobby brake fluid leak? Spridgets 1
S Clutch Fluid / Brake Fluid consumption Spridgets 3
B TR2/3/3A Gaskets for Brake/Clutch Fluid Reservoir? Triumph 15
C Brake fluid? Austin Healey 10
C TR6 TR6 with dot 5 brake fluid Triumph 8
K TR2/3/3A TR3 brake fluid reservoir outlet at the bottom..... Triumph 0
DNK Copper in Brake Fluid Other Cars 2
PatGalvin TR2/3/3A Brake Master Cylinder Fluid Reservoir Bracket needed, TR3A Triumph 6
Crankshaft TR2/3/3A Brake/Clutch fluid question Triumph 6
nevets Replacing the brake/clutch fluid reservoir Austin Healey 21
vette Silicone DOT-5 Brake & Clutch Fluid Austin Healey 17
Jim_Newman brake/clutch fluid reservoir Austin Healey 4
K Synthetic brake fluid again? Triumph 3
