TR2/3/3A DOT 5 Brake Fluid
Redoakboo
Is there a difference between DOT 5 and DOT 5.1? Most of these are synthetic, will these work O.K. in a 54 TR-2 brake system?
Dick
ed_h
Yes, pretty big difference between 5 and 5.1. Former is silicone, later is glycol based. It's an odd numbering system.
Ed
TuffTR250
It is my understanding that Dot 5 will NOT take paint off, whereas DOT 5.1 will take paint off. I like DOT 5 and use it in both my TR250 and my TR3.
Bob
Got_All_4
Can't mix DOT 5 & 5.1. Advantage of DOT 5 is it is silicone and will not absorb moisture and like Bob said it won't take the paint of if you spill it. 5.1 has a higher boiling point and will absorb moisture. Not a good thing for our cars.
I have it in my TR3As system. Love it! Also in my TR250 however I kept have an issue with the clutch slave cylinder. The DOT5 would leak out if I didn't drive it for a while. From what I understand is that the molecules in silicone are smaller and can get past the rubber seals. So recently I rebuilt my slave cylinder and will be running DOT4 in it. I'm in Ohio so it will be some time yet before we get LBC weather around here.
svtmikey
I have used DOT5 in my GT6 for years, and have never had a leak of any kind so not sure if I am just lucky or what. I don't see a reason that it would leak though. Definitively it does not damage the paint as I spilled a bunch by accident.
Hope that helps
C DOT 5 Silicone-Based Brake Fluid Austin Healey 10
KVH General TR Dot 4 Brake Fluid Triumph 7
M TR2/3/3A Intermix of Silicone and Dot 3 brake fluid Triumph 7
C TR6 TR6 with dot 5 brake fluid Triumph 8
vette Silicone DOT-5 Brake & Clutch Fluid Austin Healey 17
Q TR2/3/3A Using DOT 5 Brake Fluid On TR3A Triumph 34
CJD DOT 5 Brake Fluid Triumph 38
Jim_Gruber Brake Fluid - Castrol LMA Dot 3 or Dot 4? Spridgets 2
dklawson New Brake MC & Warranty with DOT-5 Fluid? Triumph 41
J dot 4 brake fluid Other Cars 4
M Dot brake fluid, question Spridgets 10
GTP1960 TR2/3/3A Question on replacing brake lines & converting to Dot 5 Triumph 9
S dot 5 brake switch Triumph 14
S DOT 3 or DOT4 Brake Fliud Triumph 44
AUSMHLY Castrol DOT 4 vs Other Brands Austin Healey 6
R TR2/3/3A Dot 5 Triumph 8
jfarris TR2/3/3A Loose Lift the Dot Stud Triumph 7
Rhodyspit75 DOT 5 and DOT 5.1 Spridgets 1
A TR2/3/3A Lift-a-dot studs [for wood] Triumph 5
M TR6 Tonneau cover strap lift-the-dot stud location Triumph 8
S TR2/3/3A Question on the lift dot fastener, Triumph 3
jfarris TR2/3/3A Problem with lift-the-dot fastener on door Triumph 4
T TR2/3/3A Lift the Dot question Triumph 4
TulsaFred Timing Gears dot to dot Spridgets 9
K TR2/3/3A Repair ripped tonneau cover at a Lift-a-Dot? Triumph 3
Vila TR4/4A TR4 carpet Lift-The-Dot question Triumph 0
NutmegCT brakes: DOT 3 or DOT 4? Restoration & Tools 2
C TR6 Dot 5 in a TR6 rebuild Triumph 17
M Tennax and Lift A Dot? Spridgets 2
M Lift-the-dot peg Triumph 3
Tinkerman TR2/3/3A TR 3A Lift The Dot Studs Triumph 3
C Converting to DOT 5 Triumph 6
Steve_S The New M.G. Nuts dot com MG 1
M Removing Lift-the-Dot Fasteners Triumph 8
tahoe healey DOT 5 going away? Austin Healey 8
luke44 TR2/3/3A TR3 Lift the Dot Studs - 2 styles? Triumph 4
bighealeysource Push the Dot post on dash of BN6/BN7 Austin Healey 1
Johnny Tenax and "Lift-the-dot" fasteners, plus Austin Healey 4
C "Lift-a-dot" studs Austin Healey 9
ekamm lift-a-dot studs Triumph 8
Brosky Stag Trimph TransAmerican Stag pics added to DOT Triumph 24
davidk Flushing DOT 5 Fluid Triumph 5
H TR2/3/3A TR3A - HOW MANY LIFT THE DOT PEGS ON CAR Triumph 4
dklawson A-Series Dot-to-Dot Cam Setting [TDC?] Spridgets 3
Brooklands Lift the dot fasteners Restoration & Tools 8
Brosky Silicone vs Dot 4/5 in new CLUTCH hydraulics? Triumph 17
Harry_Ward Lift the dot stud type for tonneau cover? Triumph 13
Trevor Jessie 4 year old dot dissappointed with steering wheel Spridgets 4
G Dot Snaps Triumph 2
C DOT 4 vs DOT 5 Triumph 14
