Synthetic brake fluid again?
karls59tr
Bronze
Has anyone heard of water pooling in brake lines in a car that has been sitting for a long time because the moisture in the line separates from the synthetic fluid?
TR3driver
Great Pumpkin - R.I.P
"Synthetic" ? Or DOT 5 silicone ? They are different things.
"Synthetic" brake fluid is just regular DOT 3/4 with a new marketing term pasted on the label. Kind of like "fresh frozen" fish, the term is basically meaningless. Water will never separate from DOT 3/4, but the mixture does turn very corrosive over time. I lost a TR3A once because the long hard line under the car had basically rotted through from the inside. This is an extreme example, but shows the kind of corrosion that DOT 3/4 can cause (the yellow fluffy stuff is the corroded aluminum)
Water pooling in the lines is a common criticism of DOT 5. Not a matter of separating, just that water will totally not mix with DOT 5. So any liquid water that gets into the MC (like if you remove the top in the rain) will stay separate. But, at least in my limited experiments, the water also remains as a bead, surrounded by silicone (much like the way water beads up on a good wax job). In fact, silicone is what they add for the "wax job" in a do-it-yourself car wash. So since the water is not in contact with the metal, it doesn't cause corrosion.
K
karls59tr
Bronze
So if a car with silicone brake fluid had been sitting for an extended period of time with suspended water in it ,would this possibly cause a spongy pedal?
TR3driver
No, I don't believe so. However, I have heard stories of air coming out of solution much later, so there might be an air bubble somewhere.
Bruce_B Fluid for MC Brake and Clutch?? Synthetic--REgular Spridgets 4
LuckyLuke Synthetic vs Regular Brake Fluid Austin Healey 3
R Synthetic brake fluid Austin Healey 28
B MGA Synthetic oil?? MG 10
RAC68 Synthetic Oil Escape Austin Healey 8
M Can synthetic oil be cause of leaks? Spridgets 5
H What are the pros and cons for full synthetic oil in a 948cc engine Spridgets 5
Jim_Gruber Castrol GTLMA - Full Synthetic Spridgets 4
PeterK Castrol Edge full synthetic Triumph 2
M synthetic fluid in a toyota 5 speed? Triumph 20
kodanja Synthetic oil ? Triumph 48
dklawson Transmission Gear Oil - Synthetic? Triumph 7
theleisure Silicone or Synthetic, How to Tell Spridgets 5
K Switch to Synthetic Oil...Does Engine need to be.. Triumph 2
2wrench Synthetic oil used in placing pistons...opinions Triumph 6
Dave Richards Synthetic Fluids Austin Healey 3
Musicman Oil - Regular vs. Synthetic Triumph 19
Paulus Synthetic oils Triumph 14
B Mobil 1 Synthetic 5W30 in Overdrive/Trans Austin Healey 7
W Synthetic Oil MG 5
Dave Russell Synthetic oils or additives Jaguar 3
G Synthetic oils MG 20
S Synthetic Engine Oil? Austin Healey 7
M Synthetic Oil V-12 XJS Jaguar 9
T Mobil 1 synthetic oil Restoration & Tools 6
B MGA Axle Brake line MG 0
6 Brake Fluid Spridgets 4
F Excessive Brake Pedal Travel Austin Healey 3
F Disc Brake Shimming Austin Healey 8
PDIGIO_6x3 TR6 BRAKE TUBING KITS Triumph 6
L Red Rubber Brake Grease Austin Healey 2
Martinld123 Emergency Brake Doesn't Release Austin Healey 9
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
M Brake Servo Austin Healey 2
J MGB BRAKE VALVE ? MG 11
G Brake Light Switch Failure Austin Healey 24
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
J TR2/3/3A Brake Line Flares Triumph 8
Frameman 1949 Brake Bleeding Austin Healey 0
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
L T-Series Another brake prob. ? MG 12
S TR2/3/3A brass fitting from a steel brake line Triumph 2
