Synthetic oil used in placing pistons...opinions
2wrench
I attended a Boy Scout meeting tonight. My son Tommy
got a little ahead of me and built and placed a couple
pistons into the block.
As lubrication, he used some synthetic oil from the garage.
I have read it is not good to run synthetic oil in your
engine during break-in.
Should I go to the trouble to remove the pistons and wipe
it all down or do I put the rest of the pistons in with the
proper oil and not worry about it?
Also, should I go to a break-in oil to use to put it together?
Thanks,
Re: Synthetic oil used in placing pistons...opinio
No need to bother, the amount of oil there is so small as to be totally irrelevant. In any case, by the time the engine starts most of it will be washed away be the gas fumes.
:iagree: No need to redo, it won't hurt anything. (Of course, I'm not convinced synthetic will interfere with break-in anyway ... it's just wasteful to use it for oil you're going to throw away in 500 miles IMO.)
I'm also not convinced about ZDDP and the reputed lack thereof ... but I do vouch for Valvoline Racing oil; and the "Not Street Legal" stuff still has lots of ZDDP. That's actually what I used the last time I did a full rebuild, and that engine ran like stink right up until the car lost it's brakes and the ensuing discussion with a brick wall.
2Wrench, almost forgot, my son just made tenderfoot. He's excited to work on second class. Is this pard of his Automotive merit badge?
Yours in Scouting
Colin
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]an like stink right up until the car lost it's brakes and the ensuing discussion with a brick wall.[/QUOTE]
:lol:
Those are typically one sided discussions.
Yours in Scouting
Colin
Not sure Colin-
God and Country, Order of the Arrow and I'm ten thumbs when it comes to
auto mechanics. Best wishes to your son. The code of honor he is learning
will carry him well in manhood.
d
B MGA Synthetic oil?? MG 10
RAC68 Synthetic Oil Escape Austin Healey 8
M Can synthetic oil be cause of leaks? Spridgets 5
H What are the pros and cons for full synthetic oil in a 948cc engine Spridgets 5
kodanja Synthetic oil ? Triumph 48
dklawson Transmission Gear Oil - Synthetic? Triumph 7
K Switch to Synthetic Oil...Does Engine need to be.. Triumph 2
Musicman Oil - Regular vs. Synthetic Triumph 19
W Synthetic Oil MG 5
S Synthetic Engine Oil? Austin Healey 7
M Synthetic Oil V-12 XJS Jaguar 9
T Mobil 1 synthetic oil Restoration & Tools 6
K Synthetic brake fluid again? Triumph 3
Jim_Gruber Castrol GTLMA - Full Synthetic Spridgets 4
PeterK Castrol Edge full synthetic Triumph 2
M synthetic fluid in a toyota 5 speed? Triumph 20
theleisure Silicone or Synthetic, How to Tell Spridgets 5
Bruce_B Fluid for MC Brake and Clutch?? Synthetic--REgular Spridgets 4
LuckyLuke Synthetic vs Regular Brake Fluid Austin Healey 3
Dave Richards Synthetic Fluids Austin Healey 3
Paulus Synthetic oils Triumph 14
B Mobil 1 Synthetic 5W30 in Overdrive/Trans Austin Healey 7
R Synthetic brake fluid Austin Healey 28
Dave Russell Synthetic oils or additives Jaguar 3
G Synthetic oils MG 20
T TR2/3/3A fuel pump oil leak Triumph 7
D T-Series MGTD Oil Leak? MG 2
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 2
Carlbanan56 MGB MGB oil consumption MG 5
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
af3683 TR2/3/3A Recommended Oil Filter Cartridge for Purolator Triumph 8
R oil pressure Spridgets 2
RickPA Overdrive Oil Pressure Austin Healey 8
6 Valve Oil Seals Spridgets 10
RJS TR4/4A Smiths Oil Temp Gauge Triumph 11
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
Lotuswins Dry Spin-On Oil Filter Austin Healey 14
Todd78d Oil Spridgets 6
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
G Right-Side Shock Weeping Oil Austin Healey 1
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
G High Oil Pressure Austin Healey 2
Bayless What oil for Datsun 5 speed? Spridgets 7
T Spin-On Oil Filters Anti-Drain Back Valves Austin Healey 0
T Spin-On Oil Filters Austin Healey 1
K TR2/3/3A Old school penetrating oil? Triumph 24
