Brake fluid recommendations
Bayless
It is about time to add fluid to the brakes and clutch on my '67 Sprite project. I know the usual suggestion is Castrol LMA and I have always used it in the Prefect, so far with good luck. I put silicone in the VW years ago, however, and it has performed flawlessly. I would like to at least consider if for the Sprite mostly because it doesn't eat paint if there are any leaks. What is your thinking?
John Turney
I put silicone in my 100-6 for the same reason - doesn't eat paint. I found that after not rebuilding my brakes for 15 years, the rubber parts were still good and the metal pieces looked like new.
Bayless
Bayless
Thanks for the info John. That's been my experience with the VW too.
JPSmit
I have only used silicone in the Midget - the only issue I had was a viscosity issue where it was seeping past a seal. I went and found the thickest fluid I could find and problem solved.
Bayless
Bayless
I won't take much to convince me to go that way. What fluid did you finally use JP?
JPSmit
N Brake fluid recommendations Triumph 18
6 Brake Fluid Spridgets 4
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
SherpaPilot TR6 Brake Fluid in Servo? Triumph 0
prb51 Girling Brake Fluid Reservoir Cap Austin Healey 6
KVH General Tech Brake Fluid Triumph 5
Lin Brake/Clutch Fluid Austin Healey 11
AUSMHLY Castrol DOT4 Brake Fluid Austin Healey 6
craigshealey3000 Castrol Girling Amber Brake Fluid vs. Silicone Austin Healey 14
P TR6 Brake fluid leak? Triumph 6
F Girling Brake Fluid Reservoirs Leaking Austin Healey 12
D TR2/3/3A Why it is important to change brake fluid Triumph 4
D TR2/3/3A Brake fluid identification by colour. Triumph 4
R TR2/3/3A DOT 5 Brake Fluid Triumph 5
Martinld123 Brake Fluid Austin Healey 49
fpstude TR4/4A Brake / Clutch Fluid for TR-4A Triumph 8
C DOT 5 Silicone-Based Brake Fluid Austin Healey 10
KVH General TR Dot 4 Brake Fluid Triumph 7
NutmegCT Brake fluid - flush and replace. Why? Restoration & Tools 8
tahoe healey Brake Fluid Austin Healey 6
2 TR2/3/3A DOT5 brake fluid Triumph 3
Got_All_4 General TR Someone asked where to get DOT5 silicon brake fluid a while back Triumph 4
M Brake fluid on tire - cylinder need replaced? Spridgets 19
B General MG Brake fluid MG 7
R TR2/3/3A Brake Fluid Triumph 6
glemon General Tech Follow up on Master Cylinder and Brake Fluid Triumph 11
G Brake fluid missing Austin Healey 6
Joe Schlosser Brake Fluid Spridgets 5
steveg Silicone brake fluid conversion - existing system Austin Healey 41
simon1966 Brake fluid Canister on a RHD 100 Austin Healey 10
Rut Brake fluid Spridgets 11
M TR2/3/3A Intermix of Silicone and Dot 3 brake fluid Triumph 7
L 100/6 BN4 Brake fluid Austin Healey 17
M Losing Brake Fluid Austin Healey 8
H Adviced asked on unscrewing lid brake fluid reservoir Austin Healey 9
petnatcar BRAKE FLUID CONTAINER for BT7 Austin Healey 0
GTP1960 TR2/3/3A Recommended brake fluid for a 3A? Triumph 16
F Replacing brake master cylinder, fluid reservoir and flexible brake pipes - order? Austin Healey 4
tomshobby brake fluid leak? Spridgets 1
S Clutch Fluid / Brake Fluid consumption Spridgets 3
B TR2/3/3A Gaskets for Brake/Clutch Fluid Reservoir? Triumph 15
C Brake fluid? Austin Healey 10
C TR6 TR6 with dot 5 brake fluid Triumph 8
K TR2/3/3A TR3 brake fluid reservoir outlet at the bottom..... Triumph 0
DNK Copper in Brake Fluid Other Cars 2
PatGalvin TR2/3/3A Brake Master Cylinder Fluid Reservoir Bracket needed, TR3A Triumph 6
Crankshaft TR2/3/3A Brake/Clutch fluid question Triumph 6
nevets Replacing the brake/clutch fluid reservoir Austin Healey 21
vette Silicone DOT-5 Brake & Clutch Fluid Austin Healey 17
Jim_Newman brake/clutch fluid reservoir Austin Healey 4
