Brake fluid Canister on a RHD 100
simon1966
Does anyone have a good photo of the location of the brake fluid canister on a RHD 100. I want to make sure we put it back in the correct location. It was not mounted in my car as a result of a PO bodge job. Thanks much.
Clausager shows one in right rear corner of engine compartment opening - on a 100S. I have a friend with a RHD BN-1 but it was converted from LHD so he isn't willing to swear by the reservoir location as it was moved to that position. Sorry not much help.
Other possibility would be to observe LHD BN-1/2s and just do the mirror image - can't think of any reason the factory cars wouldn't have been that way.
Also - check out the British AH clubs online and you may be able to connect with RHD owners and get the photo you need.
How about because it would be the logical thing to do :smile:
Thanks for the suggestions. I was able to get a photo from an Australian owner via a FB group. So I am all set. Thankyou.
May be this will help you a little! But it's taken from my RHD BJ8 '67. I don't know if the container was located some where else on a 100.
If you need a picture taken a little closer let me know.
This might put a grin on your face Steveg
Here are some more Fotos. I'd rather go for the upper position of the brake fluid canister, because this way you are very close to the brake and clutch master cylinders.
UNADJUSTEDNONRAW_thumb_4eec.jpgUNADJUSTEDNONRAW_thumb_4eee.jpgUNADJUSTEDNONRAW_thumb_4eef.jpg
A brake fluid canister Austin Healey 4
Randy Harris Brake fluid canister - how full? Austin Healey 5
H Which Part of the Brake Fluid Canister for Clutch? Austin Healey 8
6 Brake Fluid Spridgets 4
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
SherpaPilot TR6 Brake Fluid in Servo? Triumph 0
prb51 Girling Brake Fluid Reservoir Cap Austin Healey 6
KVH General Tech Brake Fluid Triumph 5
Lin Brake/Clutch Fluid Austin Healey 11
AUSMHLY Castrol DOT4 Brake Fluid Austin Healey 6
craigshealey3000 Castrol Girling Amber Brake Fluid vs. Silicone Austin Healey 14
P TR6 Brake fluid leak? Triumph 6
F Girling Brake Fluid Reservoirs Leaking Austin Healey 12
D TR2/3/3A Why it is important to change brake fluid Triumph 4
D TR2/3/3A Brake fluid identification by colour. Triumph 4
R TR2/3/3A DOT 5 Brake Fluid Triumph 5
Martinld123 Brake Fluid Austin Healey 49
Bayless Brake fluid recommendations Restoration & Tools 6
fpstude TR4/4A Brake / Clutch Fluid for TR-4A Triumph 8
C DOT 5 Silicone-Based Brake Fluid Austin Healey 10
KVH General TR Dot 4 Brake Fluid Triumph 7
NutmegCT Brake fluid - flush and replace. Why? Restoration & Tools 8
tahoe healey Brake Fluid Austin Healey 6
2 TR2/3/3A DOT5 brake fluid Triumph 3
Got_All_4 General TR Someone asked where to get DOT5 silicon brake fluid a while back Triumph 4
M Brake fluid on tire - cylinder need replaced? Spridgets 19
B General MG Brake fluid MG 7
R TR2/3/3A Brake Fluid Triumph 6
glemon General Tech Follow up on Master Cylinder and Brake Fluid Triumph 11
G Brake fluid missing Austin Healey 6
Joe Schlosser Brake Fluid Spridgets 5
steveg Silicone brake fluid conversion - existing system Austin Healey 41
Rut Brake fluid Spridgets 11
M TR2/3/3A Intermix of Silicone and Dot 3 brake fluid Triumph 7
L 100/6 BN4 Brake fluid Austin Healey 17
M Losing Brake Fluid Austin Healey 8
H Adviced asked on unscrewing lid brake fluid reservoir Austin Healey 9
petnatcar BRAKE FLUID CONTAINER for BT7 Austin Healey 0
GTP1960 TR2/3/3A Recommended brake fluid for a 3A? Triumph 16
F Replacing brake master cylinder, fluid reservoir and flexible brake pipes - order? Austin Healey 4
tomshobby brake fluid leak? Spridgets 1
S Clutch Fluid / Brake Fluid consumption Spridgets 3
B TR2/3/3A Gaskets for Brake/Clutch Fluid Reservoir? Triumph 15
C Brake fluid? Austin Healey 10
C TR6 TR6 with dot 5 brake fluid Triumph 8
K TR2/3/3A TR3 brake fluid reservoir outlet at the bottom..... Triumph 0
DNK Copper in Brake Fluid Other Cars 2
PatGalvin TR2/3/3A Brake Master Cylinder Fluid Reservoir Bracket needed, TR3A Triumph 6
Crankshaft TR2/3/3A Brake/Clutch fluid question Triumph 6
nevets Replacing the brake/clutch fluid reservoir Austin Healey 21
