Will 60 spoke wire wheels fit 100-6 ?
wolf
I have a 100-6 with F & R drum brakes . I am looking at some 60 spoke 15 X 4.5 wire wheels on Ebay . I told him I have drum brakes , guy says his book says they will fit but I have read that I need 48 or 72 spoke wheels . Do some brands of 60 spoke wheels fit drum brakes ?
bob hughes
You should be fine with 60 spoke wheels, 48 were standard at one time but yuou need the extra spokes for strength if your going to corner fast.
Bob
RJA
Call Allen Hendrix at Hendrix Wire Wheel for this wheel issue. Some wheels will
fit but not all. Tele# 336-852-8909.
wheelguy
60 spoke 15x4.5 will NOT fit front drums on a BN-4 or BN-6.
However a DB60155 custom build Dayton 15x5 60 spoke will. Some work MAY still be required on the drums on the front only. As in a little grinding and a balance. I have done this alot.
A Dayton 459 15x5 72 spoke will fit. A standard 457F Dayton 15x5 72 spoke will NOT fit.
Soooo Here are your choices. D450 48 spoke 15x4 Dayton or Dunlop
D459 72 spoke 15x5 Dayton
DB60155 72 spoke 15x5 Dayton
I hope that answers your question. If not ...you can call me at the number in above post. WHEELGUY
I'll vouch for them NOT fitting. My brother put them on my car and MANY broken spokes were the result! Twenty-one (21) on the left front, and eleven (11) on the right front.
I replaced them with 72 spoke wheels from a TR6 and they cleared the drums (fr/rr) just fine.
wheelguy
Randy is correct.. A TR-6 wheel will work also.. However... It is a 15x6 inch wide rim. That is 2 inches wider than the original wheel. The two inches are to the outside. That is perfect for running fat tires. If you just want a daily driver it may be too much for you.. Wheelguy
bighealeysource
Bronze
Hey Wolf,
Like Randy and Wheel Guy said, 60 spoke wheels will not fit the front drum
brakes of a BN4 or BN6. I know as I mistakenly put 60 spoke on a BN4
with the results - not as bad thankfully - as Randy mentioned. IMHO,
unless you are racing your 100-6, stick with the original type wheels.
Regards,
Mike
nevets
60s won't fit. I wanted to replace my 48s with 60s and found out it doesn't work. 72s will fit. I stayed with the 48s because the 72s looked too busy to me.
W
wolf
thanks for all the help guys , you saved me from spending funds that I do not have , I will kept my search to 48 spoke wheels .
wheelguy
If you are staying with 48 spoke.... The Dunlops of today for the painted wheels are excellant. Moss sells them and they cost less than the Daytons. If you are going for chrome.. the Daytons have a far better plating than the Dunlops and will stay rust free longer. Wheel guy
bob hughes
Woops, guess that has taught me a lesson to double check first.
Bob
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
D Wanted TR6 72 Spoke Wire Wheels (painted) Wanted Triumph Classifieds 0
M 60 vs 72 Spoke Wire Wheels Austin Healey 19
Zimmycobra For Sale Original 1966 TR4A 60 Spoke painted wire wheels Triumph Classifieds 0
Marvin Gruber TR5/TR250 TR250 wire wheels, 60 or 72 spoke? Triumph 6
T 60 spoke wire wheels Triumph 17
B TR6 Dunlop 72 spoke wire wheels TR6 Triumph 6
D 48 spoke wire wheels AH MKI, What to do with them? Austin Healey 11
TR6Canuck TR6 Wire spoke rims to fit Michelin Red Line Tires on TR6 Triumph 12
D new member with spoke wire wheel questions Triumph 12
Tinkerman Wire Wheel Spoke Removal Triumph 4
F Caliper to wire wheel spoke clearance. Austin Healey 12
Tinkerman Spoke Length, 60 Spoke Wire Wheel Triumph 5
G Wire wheel leaks at spoke Jaguar 10
B wire wheel spoke tuneing Austin Healey 8
tahoe healey wire spoke wrench Austin Healey 1
R For Sale FS: Revolution 5 Spoke Wheels (Triumph) Other British Classifieds 4
Jim_Gruber And Bugsy Spoke for the first time in 18 Months tonight Spridgets 15
T TR2/3/3A Seeking advice on how to repair TR3 steering wheel broken spoke. Triumph 8
R Spoke wheels - bugeye Spridgets 7
J TR6 spoke wheel paint color Triumph 3
simon1966 Does anyone use 48 spoke wheels on a 100? Austin Healey 21
M Spoke count 60 vs 72 Austin Healey 18
J 48 Spoke Wheel - San Diego Austin Healey 0
P New tires, missing spoke Triumph 4
AH67 Paint code spoke wheels? Austin Healey 8
A I spoke too soon Triumph 8
tahoe healey broken spoke Austin Healey 12
BN6_2197 Problem with spoke rims On BN6 Austin Healey 26
R TR4/4A Tire options tr4a 60 spoke wheels 4.5 inch wide Triumph 43
doughairfield 72 vs 60 spoke wheels Triumph 6
bighealeysource 72 spoke wheels on 59 BN6 Austin Healey 4
L Street Tire size for 60 spoke wheels Austin Healey 15
highlandracer Information needed: 3-spoke alloy wheels Other British Cars 0
J Spoke Too Soon MG 5
jlaird Just spoke to my trailer guy Spridgets 0
H Chrome spoke wheel for spare Austin Healey 7
J spoke wheel adjustments MG 13
boxofparts Revolution 5 spoke wheels Triumph 7
AUSMHLY broken spoke Austin Healey 2
jlaird Maybe I spoke to soon Spridgets 40
R TR4/4A whitewall tires on spoke wheels TR4A? Triumph 8
M 69 XKE tire tubes and rubber spoke end strips Jaguar 2
K TR2/3/3A head gasket repair wire Randall Triumph 1
Todd78d Wire wheel cleaner Spridgets 1
scottkilpatrick TR4/4A Knock off wire wheels procedure..basic questions Triumph 9
K 1068 mkIII wire wheel rub Spridgets 1
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
