boxofparts
I am helping a friend with a TR6 that is fitted with a set of Revolution 5 spoke wheels. The ftony wheels rub on the upper ball joint while turning. Compared to the spare steel wheel that is in the trunk the hub offset difference is about .75". There are currently .25" spacers on the front which appear to be the max combination we can go and still have good lug nut-thread engagement.
Are the studs commmon with anything I could get at the local NAPA or Pepeboys -- Just longer?
How hard are they to remove?
Does the front rotor-hub need to be taken apart to install longer ones?
What about the rear axle?
How much is a set of used Revolution rims and tires worth?
Does anybody have a set of center caps for sale?
