New tires, missing spoke
pdplot
On good advice, on my TR6, after 17 years, I finally replaced my old 185 Michelins with new Michelin Defenders - 205/70/15. Rides a bit better and steers much better. Only problem - found out I was missing a spoke on right rear rim. I have 4 choices;1) replace the rim (expensive), 2) switch with my spare rim which appears to be in better shape, 3) If it's possible to buy a new spoke, replace the missing spoke which means stripping off the plastic or whatever is inside the tire protecting the tube and hoping the new rim band will be just as good or 4) just drive it as is. Is there any problem with option number 4?
trrdster2000
PDplot, Is the whole thing missing or is it broken off? My concern would be the part that's inside the tire, is it moving and rubbing on the tube. If it's missing completely then drive with care until you can replace it.
Did the tire changers tell you about it, I hope they did and it sounds like you may need a wheel tuneup, these things are 30 years old or more, give them the old wrench test and see how loose they are. A dull thud is not good.
Wayne
Geo Hahn
If you want to avoid the expense of replacing the wheel then you should replace the spoke. I wouldn't worry about disturbing the bands inside the rim as these can be easily replaced (I use plumbers' PVC tape from Ace Hardware et al for a non-gooey wrap).
I would not drive with a broken spoke, as noted this will encourage others to break.
Mostly just some hard work, the worst of which can be farmed out if your tire place will unmount and remount the tire & tube.
TR3driver
Great Pumpkin - R.I.P
B Wheels and Tires Selection Austin Healey 10
Lutz Kramer Tires Squeaking on Curves Austin Healey 4
Got_All_4 For Sale 2 Vredestein Sprint + S80 Tires 165 R 15 86S Triumph Classifieds 0
red57 Michelin XAS Tires Austin Healey 38
D Vredestein Tires Austin Healey 11
tinman58 TR2/3/3A New Tires Triumph 10
AngliaGT General TR You Might Need Snow Tires for This - Drive Your Triumph Day 2023 Triumph 5
luke44 TR2/3/3A TR3 inside the tires track dimension Triumph 5
drooartz New wheels and tires for Penny Spridgets 16
TR6Canuck TR6 Wire spoke rims to fit Michelin Red Line Tires on TR6 Triumph 12
johnrip Wedge tr7 tires Triumph 1
vette North East Tires Austin Healey 16
F TR6 Wheels and tires Triumph 10
johnrip Wedge Tires for TR7 stock alloy wheels Triumph 1
S TR2/3/3A Tires Triumph 19
B Tubes in radial tires on wire wheels - what do you do? Austin Healey 27
69MGC MGC What size tires will fit nicely MG 2
danstr6 For Sale Redline tires for sale Triumph Classifieds 0
Jayplum TR2/3/3A Wheels, tires, hubs and axles Triumph 22
edkap2002 TR6 wider tires Triumph 9
pbraun Ideas on tires for Bugeye with 13x6" wheels Spridgets 3
Bayless What tires for '67 Sprite? Spridgets 5
CessnaTPA New Tires or Keep Old Ones Austin Healey 36
5 Sumitomo 13 inch Tires Spridgets 19
madhouse Need Dunlop 165/R15 tires Austin Healey 8
P For Sale Five 6.50-13 Bias ply US Royal Safety 800 tires for sale Spridgets Classified 0
Joe Schlosser Wheels and tires Spridgets 15
T TR2/3/3A What air pressure is recommended in my Hoosier tires? Triumph 1
I For Sale Minilite replicas with Michelin tires $400 Triumph Classifieds 16
P MGB MGB tires MG 11
B XK-120 tires Jaguar 7
aero3113 Vredstein Sprint Classic Tires Austin Healey 28
davidb TR6 TR6 tires Triumph 13
S Michelin XAS tires for my '67 Austin Healey 3000 Austin Healey 16
Jim_Gruber New Wheels and New Tires for Bugsy IV Spridgets 5
D T-Series T is for Tires MG 10
H 280i Tires TVR 7
E Tires for BT7 Austin Healey 22
Jim_Gruber 13" Tires - What's out there right now Spridgets 21
Basil Vredestine Tires Restoration & Tools 5
CJD TR2/3/3A Latest Tires Triumph 38
K TR6 Wheels and tires Triumph 3
tinman58 TR5/TR250 tires, hubcaps and rims for sale Triumph 0
J Heidenau tires Austin Healey 0
Michael Oritt Does anyone drive with bias-ply tires? Austin Healey 40
rjc157 TR6 tires Triumph 8
maxwedge5281 advice on tires for v8 healey Austin Healey 7
B Tires - 185-65R15 for BT7 or BJ7? Austin Healey 19
S TR6 new wheels and tires Triumph 18
