I got to work on car a bit today. I checked for vacum leaks and I think I have them all sealed up except a small one at the rear carb shaft seal.
Got the idle down to about 800 rpm but the car is still runn ing rough and the rpm fluctuates between about 800 and 1100 rpm.
I also checked the timing and it seems like the timing mark is moving around again. Could this be because the car is running or the the reason for it?
As I said earlier I just got the dizzy back from Jeff at Advance Dist. He mentioned that the timing chain tensioner was not put back properly when I re-assembled the engine. I am 99.5 percent sure that I got it back properly. I have the sore fingers to prove it.
HELP!!!
HELP!!!
