jlaird
Fulcrum pins will not go into the A frame wishbone far enough, lack about an 1/8 of an inch from makeing a fit.
With my trusty flash light I can see they are threaded all the way to the bottom (other side) and the threads on the fulcrum pins are clean and straight. Pleanty of room left to screw in, it is not hitting the other side and both wishbones are the same no matter which pin I use. This is a fit with out the swivel pin even. They just do a hard stop.
Any ideas??
Any ideas??
