What is max ID of rear drum?
G
Should be marke don them. Most of the time the bevel on the edge serves as a good wear guide. When it's been turned out it's at max. Drums are cheap na dif you are just cleaning them up I wouldn't worry about it. It sounds like you have far bigger fish to fry anyway. I wouldn't waste time on the drums right now.
nomad
If you are changing to the later back plates and cylinders you will have to machine or grind off a bit on the edge of the drum. Also may have a bit of interference on the bearing housing and the back of the stud's in the hb should be relieved a bit. Not all that difficult to get correctly proportioned brakes with disc front's.
Kurt.
Jim_Gruber
So if I decide to go with new drums for my BE will I still need to trim for clearance with later backing plates? Do new drums eliminate bearing / hub issues?
Rut
Jim,
The drums need to be ground a very small amount...an angle grinder works well for this project. I've had a couple of drums that fit without scraping, but most do.
Rut
Jim_Gruber
Thanks Rut. Rear end now out and on a dolly. On the list to do and fix. Need more room in the garage. An ungainly and painful thing to trip over. Utility trailer will be making a trip to our cottage soon. Rear end may join the BE Bonnet and seats in storage there.
Rut
Jim,
Easy way to do it is mount them backwards and turn as you grind or wait until the car is running and do it then.
Rut
nomad
Jim,
Rut
Good idea Rut! Didn't think of that and had a friend chuck them up in a lathe. Your solution sound's much simpler.
Kurt.
B Max Dia for Cylinder Bore for a 3000 Austin Healey 5
Darwin Spitfire Max tire width Triumph 4
R TR2/3/3A Normal vs Max acceptable coolant temperature? Triumph 14
S Max RPM Austin Healey 15
S TR2/3/3A Mad Max seal Triumph 34
Jim_Gruber Max size for BE Tires Spridgets 11
red57 Max safe EGT Racing 9
T what max size tires & wheels fit a tr4,tr4a,tr250? Racing 3
dondel Oil between MIN and MAX Austin Healey 5
George Zeck Max speed 45mph [or so] ???? Spridgets 10
J TR6 max horsepower from a TR6? Triumph 18
R Max Tire Size for 8" Wheels [how big is too big] Austin Healey 6
C Max Hoffmann Biography Jaguar 3
ChrisS Max. bore w/ liner Spridgets 3
J Z Max MG 7
J SOLD!! Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 1
petnatcar Rear View Mirror Relocation Austin Healey 0
Carlbanan56 MGB Rear axel torque? MG 4
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Carlbanan56 MGB Rear wheelbearing clicking MG 8
Carlbanan56 MGB MGB rear break rebuild MG 6
bigjones TR2/3/3A Rear tail light not budging Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
Michael Oritt Rear Crank Seal Kit Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
O Jaguar rear window trim repair Jaguar 1
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
S Leaking HD6 Rear Carb Austin Healey 10
Joel Lester TR2/3/3A Do rear leaf springs wear out? Triumph 11
J TR2/3/3A Rear Fuel Line Clips Triumph 3
60BN7 Rear Wheel Opening Austin Healey 9
S TR2/3/3A rear wheel cylinder Triumph 1
T Rear/Differential "Clunk" Austin Healey 2
J 3000 Rear Seats Austin Healey 6
KVH General TR Rear Brake Shoe Orientation Triumph 12
Popeye TR4/4A Rear fender attachment: wing to lamp housing clip? Triumph 7
KVH General Tech Rear Brakes and Solid Axle Triumph 2
P Rear Springs Austin Healey 2
