Max. bore w/ liner
ChrisS
What is the maximum that you can bore a 1275 block that has liners? I have a block with a deep score that will require 0.060" overbore but the cylinders have the liners. Will the liner move or warp at this overbore size. Thanks
If the sleeves are installed correctly you should have no problem replacing it. The proper way to install a sleeve is to overbore the cylinder leaving a shelf at the bottom for the sleeve to rest on. then the sleeve is pressed in to rest against the shoulder. The top of the sleeve is then milled even with the deck. A good machinist can cut the old sleeve out and just press in a new sleeve. Most sleeves I see are installed wrong. the machist will bore all the way through the length of the cylinder and press the sleeve in leaving a bit hanging out in the crank case. Done this way the sleeve CAN and will slide to and fro at the worst possible time.(well there is no good time)
I've seen a couple of 1380 engines that started as 1275s.
I *think* the boring has to be done off-center (of the original bores) to make this work.
Thanks for the replies, I think I found the answer. The machine shop was comfortable with 0.020", Davis Anton / APT said no more than 0.030", and downward movement of the sleeve without a lower lip is a real possibility, as Jolly stated, and Vizard’s books makes reference to A plus block in the early 80's that were factory sleeved and only really good for 0.020" or 0.040" for moderate performance engines but not race. So Split the difference and call it 0.030". As far as the 1380 borings, that will completely remove the sleeve and is what I will end up doing with this block later. I stripped another block today that doesn't have liners and it will go to the machine shop Monday.
B Max Dia for Cylinder Bore for a 3000 Austin Healey 5
Darwin Spitfire Max tire width Triumph 4
R TR2/3/3A Normal vs Max acceptable coolant temperature? Triumph 14
S Max RPM Austin Healey 15
R What is max ID of rear drum? Spridgets 7
S TR2/3/3A Mad Max seal Triumph 34
Jim_Gruber Max size for BE Tires Spridgets 11
red57 Max safe EGT Racing 9
T what max size tires & wheels fit a tr4,tr4a,tr250? Racing 3
dondel Oil between MIN and MAX Austin Healey 5
George Zeck Max speed 45mph [or so] ???? Spridgets 10
J TR6 max horsepower from a TR6? Triumph 18
R Max Tire Size for 8" Wheels [how big is too big] Austin Healey 6
C Max Hoffmann Biography Jaguar 3
J Z Max MG 7
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
SNClocks Master Cylinder Bore Diameter Spridgets 0
K TR2/3/3A Installing Brake Caliper pistons into the bore? Triumph 21
B For Sale 1956 Austin Healey 100-4 SCCA big bore race car plus parts lot engine trans etc Austin Healey Classifieds 0
R 3/4" Bore or 7/8" Bore Master Cylinder For Disc Brakes? Spridgets 4
Rut TR4/4A Master cylinder bore diameters Triumph 2
S T-Series lip on bore of td MG 6
tinman58 General Tech Cam bearing line bore Triumph 20
Bremer TR4/4A 92mm bore engine pros and cons Triumph 9
K Rough patch inside bore of SU? Triumph 2
dougie Small Bore at Summit Point - Michael Oritt Racing 5
Bremer TR2/3/3A Hypothetical: Big bore TR3/4 engine Triumph 13
PatGalvin TR2/3/3A TR3 Compression Ratio with larger bore liners? Triumph 5
K TR4/4A TR4A brake MC .70 bore = SP2102 ? Triumph 6
B 89 mm big bore kit Triumph 3
davidb Healey 3000 cylinder bore Austin Healey 25
Hap Waldrop For you small bore lovers Spridgets 45
TR6oldtimer Need a machine shop in N. Calif to bore for cam Triumph 5
Dadandson Cylinder Bore/Hone Spridgets 4
drooartz Clutch slave for 3/4" master bore Spridgets 5
J clutch slave bore size Spridgets 1
J Piston to bore clearance. Austin Healey 23
B MGA MGA Big Bore Exhaust. MG 3
Bruce_B Spec. Needed for 1275 Line-boring - "Housing Bore" Spridgets 13
Bruce_B Line-Bore Question for 1275 Spridgets 0
Shealey Anyone Know master cylinder bore size? Spridgets 15
J clutch master cylinder bore diameter? Triumph 1
John_Mc Master Cylinder with oversize bore Triumph 1
Morris Cylinder bore question Spridgets 14
Gatheringtree TR2/3/3A Changing out the battery liner Triumph 11
KVH General Tech ARP Head Studs/Liner Protrusion Triumph 10
Rob Glasgow Boot Liner Edge Finish Austin Healey 11
S Boot Liner - BJ8 Austin Healey 19
L TR2/3/3A Liner spigot fit? Triumph 13
aero3113 100-4 trunk liner kit Austin Healey 4
