Spec. Needed for 1275 Line-boring - "Housing Bore"
Bruce_B
The machine shop wanted to know the 'Housing Bore' for the 1275 engine to do a line-bore.
It's also referred to as the housing bearing O.D.
I searched on the Web...can't locate it. Anybody know it?
JerryB
Re: Spec. Needed for 1275 Line-boring - "Housing Bore"
Bruce......
sez....
"""""""The machine shop wanted to know the 'Housing Bore' for the 1275 engine to do a line-bore.""""""""
First thing to do is get all the parts and pieces you have at that "machine shop" and remove them to a competent shop.
They should be TELLING you ..not ASKING you.
2.1460/2.1465"
jlaird
God I should guess. Run away fast.
I agree with Jerry, all that info is in any bearing book, and if a machine shop doesn't have a bearing book, run as fast as you can.
Bugeye58
Hap Waldrop said:
... all that info is in any bearing book, and if a machine shop doesn't have a bearing book, run as fast as you can.
That was my first thought as well. Run, Forrest, run!!
Jeff
Bruce_B
Bruce_B
Well, Stupid is as Stupid does.
Think I'll be switching shops.
HAP -open a franchise up in NJ/PA area. We need it!
GB1
I think Nial has one in North Western NJ, Newton or Sparta?, I would check with him.
If you ship to Hap, pack appropriately /bcforum/images/%%GRAEMLIN_URL%%/laugh.gif
Pat
aeronca65t
Bruce:
Call Pete at 973-383-8859. He is in the area of Fredon, NJ.
He does not do this type of machine work himself, but he has a buddy down the street (Rich J.) that does it.
Rich is good with Brit cars and Porsches.
Rich did my block and it has worked out great
Bruce_B
Bruce_B
Thanks everyone. I found a new machine shop nearby, that when I mentioned the line-bore for a 1275 he knew all about and the scroll and its importance on oil leaks.
Dropping it off this Saturday.
GB1
Bruce
That is good news.
Pat
jlaird
Excellent, questions are always good. Act a bit dumb and see what kind of answers you get.
Grats on finding a compatant shop.
steveg TR6 Spec needed for correct ride height Triumph 28
G Spitfire 1500 Spit ring gap spec needed please Triumph 1
J TR 4 Norris Cam 342S Spec Sheet Racing 1
drooartz MGB Toe-in spec in degrees? MG 6
Pep Daimler SP250 A-spec vs B-spec chassis Other British Cars 9
P TR6 British spec TR6 Triumph 8
S Locknut - rear wire wheel - torque spec? Austin Healey 15
T Dockers Light Green Metallic Paint Spec Austin Healey 2
MikeAH100M 100S Spec Question Austin Healey 5
T Works Healey colour spec? Austin Healey 4
T TR2/3/3A Question on A type overdrive spec for "clutch movement from direct to overdrive" Triumph 7
Healey Nut Another "le mans" spec for sale Austin Healey 2
K TR4/4A Gearbox front cover[Moss 848-000] torque spec? Triumph 1
K TR2/3/3A Oil Pan bolt torque spec? Triumph 2
C Drive/Propshaft Bolt Torque Spec? Austin Healey 8
CinneaghTR General TR Thread spec for AC Fuel Pump Triumph 0
S Bell housing to gearbox - torque spec? Austin Healey 4
smaceng BE heater valve packing spec. Spridgets 10
TRdarrel4 '66 BJ8 brake drum spec? Austin Healey 12
brgrmyster GT6 Anyone Parting a 67-68 GT6 Mk1 US spec Triumph 2
R Spitfire Lbs of compression Spec for 1979 Spitfire. Triumph 3
R degreeing cam spec question and procedure Spridgets 23
T M Spec Distributor Austin Healey 3
Darrell_Walker Torque spec for front crank bolt [TR 4 cyl engine] Triumph 2
RedTR3 TR2/3/3A TR3 Wheel Track Spec Triumph 14
A TR6 TR6 UK Spec lights Triumph 16
go_inbroke Torque sequence and spec MG 8
Ed Sweeney TR2/3/3A 1962 Triumph TR3B Original Tire spec? Triumph 7
H "Special engine" spec 290 Austin Healey 1
M Bugeye rally spec rear springs? Spridgets 9
aeronca65t Spec-Miata Racing Other Cars 3
startech47 1979 Midget rear hub bearing nut torque spec. Spridgets 3
D TR6 HVDA TR6 Installation and SPEC Clutch [Cross post] Triumph 2
K TR2/3/3A TR3 Wishbone bush ream spec? Triumph 8
C Timing spec and curve Spridgets 4
kyreb1862 MGB MGB Plug Wire Spec's MG 1
D Wiper Motor Color Spec Triumph 9
B torque spec pressure plate Austin Healey 4
L Where to find BJ8 Cam Spec's? Austin Healey 3
ChrisS Spec E30 Stolen - Ohio Racing 2
A steering wheel torque spec Triumph 3
Brosky Finally got my red distributor cap and spec plate Triumph 7
PAUL161 Where to find, Concourse / Point car spec. sheets? MG 2
TypeRboy Anybody know what an RS spec Escort is? Other British Cars 16
S pitman arm torque spec Triumph 0
A TR4/4A TR4 wheel bolt spec Triumph 5
V TR6 TR6 Wheel Spec's Triumph 4
G Mech Spec Vendor MG 2
Mickey Richaud TR2/3/3A Front End Spec for TR3A Triumph 5
Patrick67BJ8 Healey Mechanic Needed - El Paso, Texas Area Austin Healey 0
