TR2/3/3A TR3 electrical problem ignition or generator???
58Triumph tr3
I'm in the final stages of a complete restoration of a 1959 TR3 . I've installed a new wire harness, new control box regulator and new generator. Engine starts and runs well. No generator light come on when starting, but the engine will not turn off when the ignition is turned off. The yellow wire to the generator light on the dash gets hot? Engine will stop when this yellow wire is disconnected. I've had the generator tor the shop and checked out ok. New control box adjusted from Moss installed no change. Traced the wiring out several times can't fine anything. Any suggestions would be helpful.
So the light doesn't come on, even when you first turn the key on? Does the ammeter go full negative at that point?
My guess, the bulb holder for the warning light on the dash is shorted out or not wired properly. One side should be connected to the ignition switch, the other to the generator output. So when you turn the key off, power is flowing from the generator output (which also gets connected to the battery) through the short and into the ignition.
No light at all. The ammeter goes to full positive .
I don't know what it is, but you have a miswiring problem. Get a decent diagram and go over the wiring again, starting behind the dash panel. The swing to full positive with the key on (assume the engine not running) also indicates that your polarity is backward.
Bob
Sure sounds like a short (or miswiring) at the dash lamp. Your ammeter wiring also doesn't match the battery polarity. If you have converted to negative ground, the leads at the ammeter need to be swapped to get it to read the right way.
thanks. I have a good diagram and will start from scratch going over the wiring behind the dash . I'll have to wait until this sub zero weather changes here in western NY.
Peter
thanks. I have a good diagram...
Be aware that there were some changes along the way and be sure the diagram you have matches your car & harness. In addition to obvious changes (like the brake light and turn signals) there are others that are less noticeable and perhaps counter-intuitive (like the windscreen wiper switch & motor).
Finally got out to the garage in the cold and checked the wiring to the generator light on the dash. Sure enough the two wires were shorted to each other . The light know comes on with the ignition turned on. Wasn't able to start the car, battery too low and still too cold.
Quite true, but the charging circuit was always the same, even to the TR4A.
Let us know how the engine starts and runs. It's below zero here in Connecticut; my TR has been in hibernation for two weeks.
Assume you know about the TR wiring diagrams here:
https://www.advanceautowire.com/schematics.htm
Tom
Temperature much warmer just about 32 so took the chance to start the TR3. All seems to be working fine. Generator light comes on with ignition, then off with engine running, amp meter looks good also. Thanks for the help, it always amazes me how such a little thing can cause such headaches.
Peter
Shorts are pretty much always Bad Things. At least it didn't let the smoke out.
These days replacement smoke is available, so it's not a big problem. :glee:
M TR2/3/3A TR3 A Electrical problem Triumph 8
R TR2/3/3A Early TR3 electrical system Triumph 12
BillyB62 TR2/3/3A TR3 Electrical issue - anything obvious? Triumph 11
prb51 TR2/3/3A TR3 Electrical issue flasher unit Triumph 3
prb51 TR2/3/3A TR3 simple electrical question Triumph 5
S TR2/3/3A tr3 electrical question Triumph 9
S For Sale FREE - TR3 engine and transmission Triumph Classifieds 0
W TR2/3/3A TR3 Seat Belts Triumph 3
R TR2/3/3A TR3 Timminge Triumph 11
J For Sale Triumph TR2 TR3 rocker panels, right and left Triumph Classifieds 0
J SOLD!! Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 1
J For Sale TR2 TR3 Tie Member Triumph Classifieds 0
S TR2/3/3A tr3 valve spring compressor Triumph 5
