TR2/3/3A TR3 simple electrical question
prb51
I have a 56 TR3 with the original harness set up (works fine) and need to tie in some original SLR spot driving lamps. Where did the Factory/dealerships of the day tie into power?
Thanks
G
For Fogs we Recommend,
[ QUOTE ]
STEADY POWER SOURCE: If it is preferred to wire the
relays to a steady power source, there are two options -
switched or un-switched power. In a British car, switched
power can be found by connecting to any convenient green
wire. Un-switched power in a British car can be found by
connecting to any convenient purple wire.
[/ QUOTE ]
For Headlights:
Cheers!
Mike
Banjo
I normally run the main power feed from one of the the feed side terminals of the starter solenoid (first connection off the battery), then have an inline fuse for the driving lights.
Definatly use a relay setup. It's safer.
MDCanaday
It wont matter how you hook it up, the generator will quit when you try to run at night. Get an alternator. I like the relay suggestion,and for looks add a second fuse block like the original, inline fuses are tacky.
MD(mad dog)
prb51
prb51
Thanks Gents. I know the factory rally TR3's ran the spot/fog set up on the generator. I do have an alternator but have not put it in as yet. I'll try the gen first for fun but will fuse it (The senior Lucas on his death bed to his son..."Don't drive at night, it's dangerous")
TomMull TR2/3/3A TR3 pushrods; Nothing seems simple any more Triumph 2
R TR2/3/3A TR3 Timminge Triumph 11
J For Sale Triumph TR2 TR3 rocker panels, right and left Triumph Classifieds 0
J SOLD!! Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 1
J For Sale TR2 TR3 Tie Member Triumph Classifieds 0
S TR2/3/3A tr3 valve spring compressor Triumph 5
jfarris For Sale TR3 Stock Fan used (1956) Triumph Classifieds 0
jfarris For Sale TR3 Speedometer SOLD Triumph Classifieds 3
S TR2/3/3A My tr3 was stuck in reverse after a short drive Triumph 3
