General Tech Timing chain replacement
rooster
Hi,
This may be a stupid question...
I'm going to replace the timing chain on my TR6. Is there any trick that I can use to keep the cam and crank from moving so I don't have to degree them?
Thanks
Geo Hahn
I have never worked on a TR6 but... should be pretty easy to immobilize the crank, then I would carefully mark the position of the cam sprocket. There should be marks already there and it would be good to take some detailed pictures of their orientation.
glemon
There should be marks on the sprockets, like you may be able to barely see here. IM005739.jpg remove with the aligned in a perfectly straight line and make sure they are the same when you put them back on. You can make your own marks if you don't have them. Ideally at top dead center on piston/cylinder 1, but for purposes of maintaining cam timing only that is not absolutely required.
When I was young and didn't know any better I replaced a chain by popping a link off. and squeezing the ends of the little dowel to hold it back on, thus being careful not to turn anything and thereby not having to remove any gears. I drove the car for many years after with no problems, but would not recommend doing it that way...
R
rooster
Hi,
I understand about the marks on the sprockets, but the procedure in Bently calls to remove both sprockets and chain as an assembly. For the crank there is the key, so it's sprocket can only go on one way, so it's easy to get is lined up correctly. It's when removing/installing the cam sprocket and the cam then turning as a result that I am concerned about. I think that the cam sprocket can go on 2 ways, though I could be wrong. Is there a way to either keep the cam from turning (or is it held by the distributor), or marks on it so you can put its sprocket on the correct way?
Oh, and this is for a TR6, don't know if its different for other TR's.
Thanks
P.S. My "googlefu" hasn't turned up much info on this, maybe it's obvious once I get the into it...
poolboy
It is a good idea to replace the 2 sprockets if you are going to put on a new chain.
You should be able to remove the cam sprocket without moving or rotating anything.
Then before removing the crank sprocket, make your own index marks on the crank and engine plate.
But in reality, I'd do the cam timing procedure and maybe advance it a few but no more than 4 degrees.
glemon
Yes make the marks on the cam sprocket so you are sure it goes back on the same. Neither the crank nor the cam spin very freely in a fully assembled engine, so if you are not working on anything else it is pretty easy to keep them in place.
Replace the timing chain tensioner while you are in there, they are a cheap little strip of spring metal that pushes against the chain. They are known to wear out.
J TR2/3/3A TR3A Timing Chain Seal and Gasket Replacement Triumph 7
M Timing Chain Replacement Austin Healey 2
M Timing Chain Replacement..... Spridgets 2
K TR2/3/3A How to tell if the timing chain has slipped...... Triumph 12
Got_All_4 TR5/TR250 Timing chain tensioner completely shot Triumph 11
mt10flyer TR2/3/3A Timing Chain Tensioner - again Triumph 13
K TR2/3/3A Timing chain rattle on start up? Triumph 2
LAW75 Timing Chain Cover Gasket Austin Healey 12
J Crankshaft dog nut and timing chain cover removal advice Austin Healey 30
D TR2/3/3A Timing chain tensioner. Triumph 3
doc50 Metro 1500 Has Slack Timing Chain? Other British Cars 20
Got_All_4 TR6 Timing chain Triumph 10
Got_All_4 TR6 Double row timing chain in a 69? Triumph 2
Michael Oritt Replacing timing chain tensioner and more Austin Healey 24
DornTRoriginal TR2/3/3A Checking if Timing Chain is Installed Correctly Triumph 6
D BT7 Timing chain install Austin Healey 2
M Timing Chain on 948 Rebuild Spridgets 1
RJS TR4/4A Timing Chain Oil Seal Triumph 6
B TR2/3/3A Timing chain cover goop location Triumph 4
B Timing chain tensioner help Austin Healey 15
G Timing Chain - Slackend Austin Healey 5
T TR2/3/3A Is there any reason there is a stud bolt at top of timing chain cover? Triumph 7
GTP1960 TR2/3/3A Cleaning/degreasing timing chain Triumph 11
S TR2/3/3A timing chain cover and woodruff key Triumph 4
G TR4/4A timing chain and sprockets Triumph 9
DanLewis Looking for a good timing chain cover Spridgets 1
B Timing Chain Tension Ring for BN2 Austin Healey 5
J TR2/3/3A Timing chain pin Triumph 1
L 100 timing chain worn? Austin Healey 7
mt10flyer TR2/3/3A Timing Chain Tensioner - 1959 TR3 Triumph 32
DornTRoriginal TR2/3/3A Timing Chain Installation Procedures [TR3 engine TS 36161E] Triumph 5
T Timing Chain Wear? Austin Healey 5
RJS Timing chain oil seal Triumph 12
K TR2/3/3A Timing Chain Cover Crack TR3...#%€£¥^% Triumph 10
K TR2/3/3A TR3 Timing chain cover scroll seal...... Triumph 5
Geo Hahn Timing Chain Noise Triumph 25
kyreb1862 Is It Best to Go With A double Row Timing Chain? MG 1
K TR2/3/3A Tr3:installing a speedi sleeve timing chain cover? Triumph 4
K TR2/3/3A TR3 Oil Pressure Timing Chain Tensioner? Triumph 0
TulsaFred Timing chain Spridgets 22
6 timing chain sprocket Triumph 5
Darrell_Walker Timing chain tensioner wear Triumph 8
6 timing chain cover Triumph 4
bugedd Anyone have a timing chain cover? Spridgets 10
rikiwho123 timing chain to gear drive? Triumph 4
eschneider TR2/3/3A TR2/3/4 timing chain tensioner Triumph 4
M TR4/4A tr4A timing chain procedure? Triumph 9
c5racer 1500 Timing Chain Upgrade to TR6 Spridgets 1
W TR6 TR6 Timing chain oil seal question Triumph 3
doughairfield Install oil seal timing chain cover Triumph 9
