TR6 Timing chain
Got_All_4
Looking at timing chains for my Tr6 engine rebuild. Moss has 2 listed. One for $8 and a upgrade to $40. What a huge difference. What is the difference, who makes it and is it worth the extra $. they are both double row too and don't what a cheap one it's got to last.
Gliderman8
When I did the resto on my 6 approx eight years ago I ordered a new timing chain from a major supplier. When it arrived it had a sticker that said “Made in India”. I returned it and kept the original.
Alfred E. Neuman
Timing chain is just a roller chain, like any bike chain. When I managed a bike service shop, I'd always tell people to get the best chain they could afford because what you're paying for is materials and machining/tolerances. Chains "stretch" by the pin the rollers ride on wearing, and letting the end plates wear grooves into them so the effective length between each link gets slightly larger. On better chains, the pins are a much harder steel so they wear slower than a cheaper chain with softer metal in the pins.
If you can get the spec on the more expensive chain and make sure it's got better steel and higher tolerances, I'd go with the more expensive chain. What's an extra $30-40 in the scheme of an engine rebuild?
Got_All_4
Got_All_4
yep I agree Alfred but there is such a difference in price and I'm with you on the cost of the rebuild but also understand what Elliot is saying. A lot of discussion about the quality of our parts anymore and who is to say that the uprated chain isn't made in a lessor quality in a plant in India, China or the like. If you see a TRW, Beck Arnley, Cloyes, ITM or any more recognizable name is it best to by that one?
TR3driver
Great Pumpkin - R.I.P
It says on the Moss website that the expensive chain is made by Iwis in Germany. The Iwis name is not as recognizable as, say, TRW; but they are known for quality timing components and are OEM suppliers to the likes of BMW and Mercedes. In Stag circles, they are known as the gold standard, as the cheap chains have been known to fail in as little as 20,000 miles. The Stag motor is an interference design, so a broken chain is major damage.
IMO, Moss has a markup of around 40-50%, so that are paying about $4 wholesale for that $8 chain. Now count the number of parts involved. I don't know how many links a TR6 uses offhand, but each link involves 2 side plates, a center plate, two rollers and a pin; all of which are critical to long life. The pins and rollers should be a quality steel alloy, hardened and tempered to the right hardness. The plates have to be just the right length between the holes, and the holes have to fit the pins. Add some tooling, and now how much is left over for inspection?
I'd pop for the $40 version.
In fact, I've got a pair of Iwis chains on the shelf for my Stag motor, and they cost me a lot more than $40.
My Dad used to say "There's a certain price you have to pay for hay. Of course, it's cheaper after it's been through the horse!"
Joe Schlosser
Just think of the time and effort to replace a timing chain. Buy the best available.
titanic
Another problem with the "pride of India" timing chains is the side plates have a rough edge that tend to wear a groove in the equally crappy 3rd world tensioner. The "economy sprocket set was also a disappointment as the crank sprocket ID required honing to fit and the steel seemed softer than the original. The parts didn't come from Moss, but probably from the same source.
Berry
Down Under Bill
Having been involved with chain sales for many years let me make one statement. The best chain I have ever dealt with was German and Iwis was the brand. Finis
JagConsult2
used to do a plethora of Jaguar engines--always used the Italian REGINA EXTRA brand--never a probleem. the India and China chains use substandard steel--also why TR motor liners were a problem not that many years ago--cheap steel. to solve the TR bore issue- we rebored the original liners and had new piston ordered from Jahns or Venolia in Cal. in proper oversize. BTW- we kept the $$$ in the USA!!!
K TR2/3/3A How to tell if the timing chain has slipped...... Triumph 12
Got_All_4 TR5/TR250 Timing chain tensioner completely shot Triumph 11
mt10flyer TR2/3/3A Timing Chain Tensioner - again Triumph 13
K TR2/3/3A Timing chain rattle on start up? Triumph 2
LAW75 Timing Chain Cover Gasket Austin Healey 12
J Crankshaft dog nut and timing chain cover removal advice Austin Healey 30
D TR2/3/3A Timing chain tensioner. Triumph 3
doc50 Metro 1500 Has Slack Timing Chain? Other British Cars 20
Got_All_4 TR6 Double row timing chain in a 69? Triumph 2
Michael Oritt Replacing timing chain tensioner and more Austin Healey 24
DornTRoriginal TR2/3/3A Checking if Timing Chain is Installed Correctly Triumph 6
D BT7 Timing chain install Austin Healey 2
M Timing Chain on 948 Rebuild Spridgets 1
R General Tech Timing chain replacement Triumph 5
RJS TR4/4A Timing Chain Oil Seal Triumph 6
B TR2/3/3A Timing chain cover goop location Triumph 4
B Timing chain tensioner help Austin Healey 15
G Timing Chain - Slackend Austin Healey 5
T TR2/3/3A Is there any reason there is a stud bolt at top of timing chain cover? Triumph 7
GTP1960 TR2/3/3A Cleaning/degreasing timing chain Triumph 11
S TR2/3/3A timing chain cover and woodruff key Triumph 4
G TR4/4A timing chain and sprockets Triumph 9
DanLewis Looking for a good timing chain cover Spridgets 1
B Timing Chain Tension Ring for BN2 Austin Healey 5
J TR2/3/3A Timing chain pin Triumph 1
L 100 timing chain worn? Austin Healey 7
mt10flyer TR2/3/3A Timing Chain Tensioner - 1959 TR3 Triumph 32
DornTRoriginal TR2/3/3A Timing Chain Installation Procedures [TR3 engine TS 36161E] Triumph 5
T Timing Chain Wear? Austin Healey 5
J TR2/3/3A TR3A Timing Chain Seal and Gasket Replacement Triumph 7
RJS Timing chain oil seal Triumph 12
K TR2/3/3A Timing Chain Cover Crack TR3...#%€£¥^% Triumph 10
K TR2/3/3A TR3 Timing chain cover scroll seal...... Triumph 5
Geo Hahn Timing Chain Noise Triumph 25
kyreb1862 Is It Best to Go With A double Row Timing Chain? MG 1
K TR2/3/3A Tr3:installing a speedi sleeve timing chain cover? Triumph 4
K TR2/3/3A TR3 Oil Pressure Timing Chain Tensioner? Triumph 0
TulsaFred Timing chain Spridgets 22
6 timing chain sprocket Triumph 5
Darrell_Walker Timing chain tensioner wear Triumph 8
6 timing chain cover Triumph 4
bugedd Anyone have a timing chain cover? Spridgets 10
rikiwho123 timing chain to gear drive? Triumph 4
eschneider TR2/3/3A TR2/3/4 timing chain tensioner Triumph 4
M TR4/4A tr4A timing chain procedure? Triumph 9
c5racer 1500 Timing Chain Upgrade to TR6 Spridgets 1
W TR6 TR6 Timing chain oil seal question Triumph 3
doughairfield Install oil seal timing chain cover Triumph 9
doughairfield Timing chain sprocket to camshaft Triumph 9
T TR2/3/3A tr3 timing chain question [master link] Triumph 2
